Question about Bosch 2400ES LP AquaStar 6.4 GPM Indoor Tankless Liquid Propane Water Heate
I have been getting both the FA and F7 fault codes come up day after day. I don't think it's the wiring, and I don't think both the gas valve and Ionizing components are both faulty, especially since it will work for a day or two at a time without faulting. My hunch is the settings on it may need tweaking? My gas guy (my lazy, but a little bit helpful neighbor) never checked anything with a manometer or a C02 analyzer. And we converted this thing from LP to NG as well. What do you think?
  • Bosch Master
  • 2,514 Answers
You would need to check that you have the correct burner pressure that would be part of the conversion. Its NOT all ways pre-set as some think to the correct pressure .
Posted on May 29, 2017
SOURCE: fault light flashing 1 flash per second
Prior to writing the above fault I had asked the owner to turn the boiler temp controller , for the heating side, down just a fraction . I was phoned this morning to tell me that the boiler had stayed on allnight with no fault light . After consulting with the plumber who fitted the system it appears that there might not be a room stat ,
Posted on Dec 01, 2008
snap101
  • 117 Answers
SOURCE: Whistling Bosch AquaStar 2400ES-NG
if you have incorrect gas line size when it kicks on the lack of gas pressure to the unit will cause a wistling. make sure you have enough gas to the unit
Posted on Jul 29, 2009
mrhotandcold
  • 248 Answers
SOURCE: Can I convert an AquaStar 125BO convert from LP to
yes you can buy a con/kit expert job dont tackle
Posted on Oct 11, 2009
SOURCE: I have a Bosch GWH 2400 CTD EFS NG tankless water
Call qualified service technician, and ask that person questions about maintenance and tips.
Then keep service technician number in rolodex-wallet.
Resourceful do-it-yourselfer will find following links handy.
Tankless are maintenance heavy, and Bosch and Rheem etc say to call service technician for recurring problems. Especially when short-hand troubleshoot section doesn't solve problem.
People spend years learning how to service tankless.
Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
BOSCH error codes online:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Bosch manuals:
http://www.boschhotwater.com/HelpfulResources/BrochuresManuals/tabid/354/Default.aspx
Bosch problems at Fixya:
Open following links and read about tankless problems to understand the field and glean useful information.
http://www.fixya.com/support/p949576-bosch_1600h_lp_liquid_propane_aquastar_a/solutions
Install DIY tank-type gas water heater and avoid the whole headache
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Post question on pro water heater forum: This is where I go to catch up on latest info in always-evolving water heater industry.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Pay for an answer at fixya:
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 18, 2011
Bosch manuals:
Rheem water heater with White Rodgers controller FVS bad (open circuit)
I don't know.
Copy following link for general service manuals by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Ask question on pro water heater forum:
While tank water is cool, loosen and replace anode rod so tank is up-to-date on rust protection.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Oct 29, 2012 | Rheem Water Heaters
Hot water heater pilot will not light
You have red wires connected to bottom of gas control valve?
Is this a power vent model?
What model, what brand water heater?
Is new thermocouple is finger-tight plus 1/4 turn and not shorted against gas control valve?
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Copy following link for safety magnet:
Magnet will click closed when pilot is turned off. Put butane lighter on end of thermocouple and listen for clicking sound.
http://waterheatertimer.org/pdf/Safety-magnet-Gas-control-valve.pdf
Copy following link for troubleshoot by type of gas control valve:
Bad gas control valve:
Low gas pressure, air in gas line, inadequate air supply, clean the air intake, tripped FVIR system, etc.
Aug 28, 2012 | Water Heaters
Pilot goes out when dialed back to on position.....replaced thermo couple so I assume it's the gas valve (MPD91043) that need replacing??? Someone also mentioned a "motherboard", which I...
no I dont think you have a mother board. If there wasone it would be in a box of some sort on the top or right near the top mounted on the side.
If you replaced the coupler, I would say the gas valve is bad. Go to you local supply store and get a new valve. you should have 3 connection on the valve, the main gas feed and the main burner and your coupler.
Make sure you turn off the water at the main, drain it all down and when you have all the connection moved get a large channel lock or pipe wrench and turn the valve counter clock wise use tape or dope on the section that goes into the tank and tighten it up, hook up your other pipes and test for gas leak with soap and water.
Make sure when you buy the valve you get a match to the kind of gas you have natural or L P one will not work with the other.
OH check for gas leaks
Best of luck Tom
Sep 08, 2011 | RTO Water Heaters
I have an Atwood G6A-8E water heater. It stopped working last year so I took it to Camping Wprld. Their R&I'd the tube and igniter. He cleaned to tube and adjusted the igniter. The water heater...
Have you verified that you have 12 Volts DC to gas valve when it is trying to ignite? If you have the little thermal cut-off ( looks like a small diode ) inside plastic sleeve going to terminal on thermostat, remove it and connect female end on that brown wire directly to thermostat terminal and see if it lights.If it does, get a new thermal cut-off. It's a safety device so don"t go without it. It shuts off gas to valve if there is a flame up.
Aug 14, 2011 | RTO Atwood Water Heater - 6 Gal LP
Bosch GWH 715 ES flashing EA code. This unit was working fine for over a year so I am assuming gas pressure can't be the problem? The spark is flashing and the unit lights for about 2 seconds then...
http://www.digelair.net/pdfs/TECHLIT/BOSCH/MANUALS/Bosch-ProTankless_AM.pdf
http://www.bosch-climate.us/files/201009031238250.GWH715ES_English_12.2008.pdf
Above are the manuals required to diagnose and service your error code.
EA: No flame ionization detected with water flow.
Verify that all manual gas shut off valves are open. Check gas type. Reset error code and open a water tap to cycle the heater in an effort to purge air on new installations. Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater. Check three wire connections to ignition group on the lower front of the heat exchanger are secure. Check gas pressure. Check venting specifications are met. Improper venting may cause premature failure of the flame sensor rod. Check that the minimum power fan speed has been adjusted to the proper value. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If flame is unstable or yellow with proper gas pressure.
Jul 07, 2011 | Bosch & Tankless LP Hot Water Heater
I have a Kenmore Econominder water heater. Model 153-332040 40 gal natural gas/direct vent WH. The last several days it starts up and runs for about 10 seconds 1-2 times before it stays on and heats up...
Water heater burner assembly and combustion chamber probably needs clean and maintenance.
I suggest calling sears service 1-800 469-4663 or plumber.
I'm on Sears/ American/ Rheem/ Reliance etc gas water heater websites most days, and read gas water heater manuals continually.
http://www.sears.com/shc/s/search_10153_12605?keyword=kenmore+power+miser+9+40+gallon+gas+water+heater+gas
http://www.sears.com/shc/s/s_10153_12605_Appliances_Water+Heaters_Natural+Gas
Most people don't fix air conditioning without knowledge going in, but people think water heaters are simpler, because water heaters were simpler a few years ago.
Today, gas water heaters require testing equipment, and specialized tools, plus replacement parts.
Possible problems include: Improper fuel-air mixture, dirty air intake, venting problems, gas control valve problems, air in gas line, low gas pressure, dirty combustion parts, Water condensate dripping on burner, chemicals stored inside same room. Service technician will review all these things during troubleshoot, and you can watch technician and glean information for keeping water heater working longer than warranty.
http://waterheatertimer.org/Replace-anode-rod.html
If repairs are going to cost more than $400, then install new gas water heater yourself same day:
Upvote the help.
And take advantage of fixya expert assistance live.
May 23, 2011 | Water Heaters
My rheem water heater is flashing an error code of AO and 52. no hot water. what does this mean.
This means the solenoid to the modulating gas valve is sharing a fault. You will need to inspect the wiring to the solenoid to make sure it's ok. You can ohm out the solenoid to make sure it's not open. If it is, you will need to replace it.
Dec 23, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
No central heating back boiler
back boiler run from a gas fire? check the instructions to operate the gas heat to the back boiler not just the fire
I presume that this a fully pumped system - air lock doubtful There maybe on/off valves on the pipes to and from the back boiler [situate close to cylinder] make sure they are on - anticlockwise turn
or there could be a blockage in the outlet from header tank usually in the loft. or If there is no water in it maybe the mains cold feed it is off.
Note if no water in it DO NOT USE the back boiler
May 03, 2009 | Bosch & Power Vent Water Heater
BOSCH AQUASTAR 2400ES NATURAL GAS TANKLESS HOT WATER HEATER
the A3 & E3 codes are for the back flow sensor on the heater. Could be disconnected or a bad sensor. Call bosch tech support and they will help you with this.
Dec 30, 2008 | Bosch AquaStar 2400ES-NG
Rheem RTG 53 PVN with fault codes C4 or C7
I had the same problem with my tankless waterheater (flashing c4 76 alternately). I called Rheem
tech support and they had me 1 power down the remotepanel 2 unplug the unit from the wall 3 remove the cover 4 remove the wires for the remote panel from the circuit board and pull the twisted pair that goes to the remote out from the bottom of the unit. 5 reinstall the cover 6 plug the unit back
into the wall and turn on the hot water see if it works. It did in my case and they are sending me a new remote panel. I hope it helps.........
Nov 21, 2008 | Rheem RTG-53PVN Indoor Natural Gas...
Bosch 2400ES LP AquaStar 6.4 GPM Indoor Tankless Liquid Propane Water Heate Logo
57 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
