Sending print job show LOG BUFFER IS FULL JOB REJECTED message in OKI C9650
4 Suggested Answers
MUKHTAR
  • 2017 Answers
SOURCE: Brother mcf7220 will not print..says "cancel printing" "job cancel"
firest you swithc off all the printers and wait for some minute then clear all printers queue by going in to printer folder then restart your system.
Posted on Oct 06, 2007
SOURCE: Clearing buffer
Press the SEL or ONLINE key, then turn the printer off. Clear the print queue in the PC and then turn the printer on again.
Posted on May 05, 2008
SOURCE: X5150 and Vista print issue
I am posting this in hopes of helping others that are having issues with the Vista print spooler. In my case, I have an HP Pavilion laptop running Vista connected to a wireless hub. I also have a Minolta Konica 2300DL printer that is connected to the network via the wireless hub as well. Ever since obtaining this laptop, I have not been able to print to the printer other than stopping and starting the print spooler to obtain a single print 'job'. After about six months I found a post that contains the fix - I cannot take credit for it! Follow these instructions to get your printer to work:
1.) Go into control panel - I would suggest classic view as it is a little easier to navigate.
2.) Then go into User Accounts.
3.) From User Accounts go into Turn User Account Control On or Off
4.) UNCHECK Use User Account Control (UAC) to help protect your computer.
5.) At this point you will probably require a reboot.
Once this exercise is complete, you should be able to print. One more item off of my Honey DOO list!!!!!
Posted on Oct 28, 2008
The first 6 copies print quickly, then it goess to "slow motion" for rest of print job. How can I get the printer to print at the same speed
My guess would be that the quick printing at first is because the print job get spooled into a buffer and when the buffer is full the print job starts. The printer begins printing and using the buffer data as the computer continues to process the job and supply the buffer. At some point the buffer gets empty and the printer is waiting on the computer for more data, causing the slowdown. This rarely happens anymore, unless you have a very old printer or very old computer, as most printers have a rather large internal buffer memory. You may be experiencing issues with connectivity if the printer is being used wirelessly. Check to ensure that the wireless signal is strong to ensure maximum data throughput capability.
Oct 14, 2016 | Office Equipment & Supplies
Oki C9650 not printing Yellow
remove the unit
open the cleaning lamp cover (front of unit)
turn O.P.C drum gear and check that toner is always applied to the developer roller
Sep 27, 2012 | Oki Printing Solutions C9650 Led Printer
Just put all new image drums and toner in my Okidata C5300n, checked the IP address, the computer sees it and shows the pending print job, but the printer in not receiving the print job. I have tried...
In most laser printers, when you replace the drum, you need to reset your drum in your printer's menu options. This is to reset the page count for your printer to tell you when it will need to be replace again.
May 09, 2012 | OKI C5300n Led Printer
Oki c5150 log buffer full job rejected
This problem exist because of Job Accounting has been initiated on the printer. Just had this problem myself. Okidata was unable to help me solve, but through numerous online searches I was able to work it out. First you have to download Storage Device Manager from Oki. It is under the Utilities heading on the left of the drivers download screen. At first I couldn't find it under my printer C5200n, so I continued to the next model just after mine and found it there under C5300 and fortunately it worked. What this will do is it will clear the flash memory in the printer. Only use this if the log data is of no use, which in my situation was the case. It is easy and only takes a few seconds and now everything is back up and printing. READ the instructions first before installing.
Apr 19, 2012 | Office Equipment & Supplies
Trying to cancel a print job after it's already scrolled to printer?
Sometimes this is a right royal pain int he **** to actually do. You need to cancel from the pc that send the print job, then you might have to turn the printer off and restart it a few times. Usually just once if you leave it off for a half minute does the trick. The idea is to clear the memory or buffer.
If it will not clear on the pc then it gets annoying as you won't be able to print until it is out of the way. Cancle the job then delete it from the cue. Then try a reboot or two. If nothing else you can remove the printer from the printer menu, then reboot and add it back in. That force the OS to clear out the spooler and so on. You used to have to hunt down the print job file and manually delete it.
Sep 02, 2011 | OKI C5500n Printer
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
Okidata c9650 printer. technician told me to replace transfer belt in my unit because i was having an issue with the color print quality. It had a light streak running through it and the top of the page...
That message is indicating that you need to replace the black drum which also may have been what was causing your origanal issue. Whenever you have a print quility issue print four seperate documents each document using one of the four colors (black, yellow, magenta, cyan)used by the printer. If the problem only shows up in one color then that is where the problem is coming from.
Jan 21, 2011 | OKI C9650HDN Led Printer
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Oki ML 320 Turbo/D IBM - JetDirect 170x Print Server prolems
Check the receive buffer on the Oki. I usually set it to the highest (88k or 128k). You might also check the print head gap if you are printing multi part invoices. If the print head is too close it may overheat and stop printing. If you have a different printer, swap it out and see if it prints correctly. It may be a problem with the JetDirect 170x, not the printer.
Nov 08, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
This job is invalid ....
is this still current?
Apr 14, 2007 | OKI C3100 Led Printer
169 people viewed this question
jasbo
jasbo
