Question about Sharp Copier Cabinet Printer
What does an error code H4-01 mean on a Sharp MX4501N copier? The machine no longer copies, simply displays: Call for service Code H4-01.
  • Anonymous Mar 28, 2014
    How to fix this problem
  • 1,110 Answers
Fuser Heater failure. The fuser is the part of your machine that heats up and "fuses" the toner onto the paper. It is located right near where the paper exits the copier. This error code means that the fusing unit is not heating up as it should. The most common failures in order of ocurance are thermal fuse, thermister and heater lamp. In any case you are going to need a service person to come out and diagnoe which part has failed, replace the part and reset the code for you. Should not be more than say $200 to repair.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Nov 13, 2010
How do you check the color cartridge usage on Sharp Mx4501n printer if there is no alert?
Hold down the copy button. These are approximate values and are calculated so they are not right on.
Jan 14, 2013 | Sharp Mx-4501n mx4501n
SHARP AL-1665CS SYSTEM ERROR H4-00. DON'T HAVE THE MANUAL WHAT IS THE ERROR? wHAT DO I NEED TO DO TO FIX IT?
This error indicates a problem with the fuser on the machine. You will need to replace the fuser unit and reset the code. The fuser is fairly simple to get out, you will need to remove the back cover and the jam access door on the right side of the machine. At that point, the fuser is simply held in with three screws and a connector.
To reset the code you have to go into service mode by pressing this sequence of keys ("C" -> "Exposure" -> "C" -> "Exposure"). You will need to press them fairly quickly, about a second between each press, and confidently. You will know you are in service mode because the display will change to "--" and flash. At this point, enter "14" as though you were making 14 copies, and press the green start button, then press the "CA" key to exit service mode. The machine will begin restarting itself and if the problem is resolved it will come to ready.
These machines were notorious for giving H4 errors randomly and without a real reason, so I would suggest that you try resetting the code one time before calling it in for service. If the code comes back after you reset it once, or comes back on a fairly regular basis (meaning more often than once a month), I highly recommend calling a professional repair technician in for service.
Feb 28, 2011 | Sharp AL-1655CS Copier
SHARP-235, F5-02 CALL FOR SERVICE CODE
Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service u9-99 what dos it mean and how can i
Sep 04, 2010 | Sharp AR-235 Copier
My Sharp AR - 2005 copier flashes H and 4 alternately on the number of copies screen What can I do to resolve this?
A H4 code on this machine means a Thermistor issue.
The thermistor messures how hot the hot section gets indide your machine. This code is re-setable though =]..
If it is the machine im thinking of, it is actually a AR-205.
To get into service mode press
*** c, (int), 0, (int) ***
>> (Clear, Interrupt, Zero, Interrupt)
The screen should then go blank,
Simply enter "14" then press the copy button.
The machine will reset, and the code will be gone.
If there is something seriously wrong with the thermistor though. The code will come back fairly soon, and in that case you will have to get a Authorized Sharp Agent to replace this part =]
ta!
Aug 18, 2009 | Sharp Office Equipment & Supplies
L 6 CODE ON SHARP ARM205 HOW DO I REPAIR PLEASE
L6 is a Polygon Motor Lock.
Unfortuantly there isn't a whole lot you can do. You can try and reset the code, but most likely you will need a Certified Sharp Rep to replace your LSU.
To reset,
Make sure your machine is awake and ready to copy.
Simply press,
c, *int*, 0, *int*
(Clear, interrupt, zero, interupt)
The machines screen will flash blank.
Simply type in
'14'
and press copy.
The machine will reset the code and restart.
If this does not work enter sp modes again.
and try code '16'
Ta!
Willi Williams
Service Engineer.
Aug 17, 2009 | Sharp Office Equipment & Supplies
SHARP AR 275 PROBLEM E1 15 ERROR AFTER SOLVING THE U2 40 PROMLEM
Porfavor ayudenme necesito su ayuda urgentemente. este problema ya lleva 2 semanas asi y no me permite ni scanear ni imprimir ni nada.
Aug 06, 2009 | Sharp AR-275 Copier
Service code H2-01
Press "#" "Interrupt" "Clear" "Interrupt" then hit "14" "Start" then go to sub code "0" or it may ask to clear code.... Good Luck..
May 13, 2008 | Sharp AR-M237 Digital Copier
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp Copier Cabinet Printer Logo
814 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
