Question about LG DLE3777 Electric Dryer
My Dryer stopped spinning. I think something may be stuck in there. Does the front panel come off so I can check.
  • LG Master
  • 43,501 Answers
On most dryers the rear panel is what you want to remove tochek out driive related problems... Pull the dryer out sol you can easily work on it....
A few screws and everything is right there
Posted on Nov 14, 2010
My Kenmore front loader stops spinning and shuts off with 3 minutes to go leaving the clothes too damp for the dryer. I can hear water draining out before it stops. Any suggestions?
There might be something stuck in the pump.( Sock, ragg, etcetera.)
If there is a filter on this machine it could be plugged.
If it's not either of those then it's probably a electrical panel thats went bad.
Good luck.
Mar 09, 2015 | Kenmore Washing Machines
Duet dryer is making a humming noise when cycle starts a d during
whenever i hear a humming sound in a dryer it's usually the motor or something caught in the blower wheel stopping the motor from spinning.open the door and see if you can spin the drum.if it spins by hand try this,open the door,push in the door switch with one hand,have someone push the start button while you hold in the door switch and spin the drum by hand helping it move,if it runs you have a bad motor,if it doesn't remove the bottom panel and see if the belt is broke and stuck in the motor but like i say usually it has something to do with the motor not spinning.hope this helps
Oct 21, 2013 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
LG2701V stopped working after lint trap was not in place
Pull the dry out and clean (UNPLUG IT FIRST) out the entire exhaust vent system..
Sep 20, 2017 | LG DLE2701 Electric Dryer
Kenmore 417.99980120 stack washer/dryer won't drain.
Check for a kinked drain hose. Also, if it is an older machine it could have something stuck in the drain pump. The usually culprit is an under wire bra
Mar 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
When using the washing machine it creates a lot of smoke and smells like fire
it could be that the belt is worn out. take the front panel off and check the belt. if it is worn out at just one spot could be something stuck in the tub not make it spin freely
Nov 05, 2009 | Kenmore 98702 Stacked Washer/Dryer
Loud rattling noise, but dries ok
The drum of a dryer is supported b the front and back of the unit, spins on a felt gasket. Noise is coming from rollers or their is something stuck between drum and the felts. The pulley is a piece of springy metal with a plastic wheel on it, could also be worn. If you take off front of dryer, drum will come loose, check to see if something is stuck. Common for loose change to get jambed in felts. Also spin rollers and pulley to see if need to be replaced. I still think something is caught in felt.
Aug 17, 2009 | Kenmore 63942 Dryer
I have a frigidaire stackable washer/dryer unit. The washer works well. But, recently, the dryer started making funny noises almost every revolution like something was banging inside at a certain point....
Try to move the drum manually. if unable to run your hand along the front of drum where it meets the front panel....there are two pieces of felt. something has either gotten stuck there or something has gotten stuck in the blower housing.
Jun 09, 2009 | Dryers
Kenmore dryer front of drum rubs
Check your plastic drum slides. I get em(2) out of the drum and reverse them and that sometimes stops it.
Feb 14, 2009 | Kenmore 62602 Electric Dryer
Bosch 2460 washime machine. washed, will not drain r spin
i think thew buzz you hear maybe something stuck in the pump impellor. remove filter and check
Jul 23, 2008 | Bosch Logixx WFT 2806 Front Load...
Front load model LTF2940ES3 won't spin
I have the same washer and it will wash and drain but not spin. I replaced the door switch and the problem was solved.
May 27, 2008 | Frigidaire ATF6000ES Front Load Washer
LG DLE3777 Electric Dryer Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
