Question about Garmin nuvi 255W GPS Receiver
My garmin nuvi 255W does not charge in the car with the car charger. It freezes at the first screen and I can't get past that screen. I found my home charger and plugged it in and now the battery is charging. Do you know why it wouldn't charge in the car?
You need a genuine Garmin car charger to both charge and see directions at the same time. If it is a non - Garmin lead you can't charge and use at the same time. the Garmin at the same time. Otherwise the unit just goes into sleep/pc mode. It took a long time to get to the bottom of this, so I thought I'd pass the information on...
Posted on Jan 31, 2011
Garmin Nuvi 255w will not let me use it when being charged. Only get charge screen
Sometimes this happens because the mini USB plug of the charger is not fully pushed into the back of the satnav. It feels like it is but it's not. Pushing it in further may solve the problem.
Jul 24, 2011 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 255W Webupdate
Garmin Nuvi 255W Webupdate
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
____________________________
Download Nuvi 255W Manuals here.
Garmin Nuvi 255W Hard Reset Here.
Garmin Nuvi 255W Favorites Backup here.
on Apr 18, 2010 | Garmin nuvi 255W GPS Receiver
My garmin nuvi 255w keeps freezing up at loading maps screen...i have tried the hard reset but that doesn't work, when i push on the bottom right corner and start the gps, it doesn't even make it...
There is a hard reset button under the sticker at the bottom of the unit. It is located directly under the check mark on the sticker. Once you get it going fully charge the unit then go to the Garmin website and register and update your 255w. I will attach the link to the Garmin Site. Thanks for using FixYa
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
May 29, 2011 | Garmin nuvi 255W GPS Receiver
Just purchased a Garmin 255W. Works fine if not attached to the car charger. Attached unit to the charge and normal navigation screen disappears. Shouldn't a person be able to drive/navigate and charge...
Hi sudavis70,
yes, you should be able to use your 255w while driving...if its going to the garmin screen ( or the screen with the computer icon) when plugged in to the car charger, then the car charger is probably either bad or not compatible with your unit..if its the original charger, i would buy another one thats made for a garmin.
the only time you shouldn't be able to use your 255w, is when its hooked to your computer.
i fix these and many other gps daily so when considering my advice , please understand i do not google my solutions.
let me know if you need more help or info
bill
Standing Member of G.O.T.
Nov 04, 2010 | Garmin nuvi 255W GPS Receiver
Other than using the car, how can I charge my garmin nuvi 255W
You can charge it by connecting it to your computer with a usb cable. This takes about 8 hours to charge. Or you can buy a mains charger which takes around 4 hours to charge.
Sep 06, 2010 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi 255w won't start up. tries loading maps and then goes in a continuous circle. acts if not charging. tried reseting and charging with wall charger and car charger
You should try to manually delete the maps (after a backup ) on the device , power cycle and retry sending the maps from MapSource or the Software CD from the manufacturer. The map is a single folder onto the device (eg. gmapsupp.img)
May 25, 2010 | Garmin nuvi 255W GPS Receiver
How long does it take to charge a garmin 255W gps?
Are you charging through the computer or wall charge,I charge my Garmin 255w with a wall charger for about 3 hours and I have all the bars.There are different strengths of chargers but even so,overnight is excessive,try a different charger.
Aug 08, 2009 | Garmin nuvi 255W GPS Receiver
Charging a garmin nuvi 255w
From dead flat it takes about 9-10 hours
do not leave on charger for more than that otherwise you will overheat and burn it out.
After each use recharge for about 3-4 hours depending on whether the unit has been used for that lengthyof time
Jun 30, 2009 | Garmin nuvi 255W GPS Receiver
My new garmin 255w is not charging
I had the same problem. The plug wasn't sitting right in the charger hole.
Jun 25, 2009 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
415 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
