Question about Brother MFC-8460N All-In-One Printer
My printer is giving me a "no Paper" status and will not print even though the paper tray is full
  • Brother Expert
  • 231 Answers
Remove the paper tray and check under the printer in the paper flag is in the down position. If it is you will have to take the printer to tech to clean or replace the paper sensor.
Posted on Nov 13, 2010
Bizhub c200 giving message put paper in bypass tray
Check your default paper settings in your setup menu. Also, check the paper size is set correctly on you paper trays for the type of paper that is in them. Make sure that the documents that you are printing are set to proper paper size that is in your printer. All the issues, will cause this condition plus some. But those are the easiest, let me know if it continues. Good Luck
Jun 04, 2012 | Minolta bizhub 200 All-In-One Printer
The "add paper light" is on even though the paper
The light means that the printer is out of media, or the media did not feed properly
What you can do
-Load media into tray and press Continue button to resume printing.
-Check that the media is loaded correctly in tray
-Press Cancel button to cancel the print job.
Jun 29, 2011 | Lexmark E232 Laser Printer
HP Deskjet 3745 says "out of paper" even if there
Relace the bend papers and delete the due print in printer IQ.Restart the printer and check if problem did not solve then try it----->Remove the power plug and then--->
  1. Product with one rear access door release tab Product with two rear access door release tabs c01963694.gif Illustration of removing the rear access door. c00104514.gif Product with a rear access door release knob Product with in-tray catches c01964197.gif Illustration of a product with a release knob on the rear access door c02297019.gifIllustration of in-tray catches Product with a duplexer c01964198.gif Illustration of a product with a duplexer.
  2. Wipe each paper roller with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers upward carefully to clean all the way around. Figure 1: Paper rollersc01438859.gif
and restart the pc plug in the printer.Check the status if problem persist uninstall the driver and install the driver again.If you give A4 paper,choose the paper A4 in printer setting.I hope this will be solved.
Jun 07, 2011 | HP Office Equipment & Supplies
Two day ago i managed to print on a Konica Minolta Di1611, and now it's giving me "PRN ERR" message and "LOAD suitable paper", even though I'm using the same type of paper. I tried to...
is the driver set correctly with the type of paper you have loaded in the draw also when you select the the job to print is it correct in the properties showing the correct type of paper and what draw it is taking it from
Jan 08, 2011 | Minolta Bizhub Di1811p Copier
Status light is red and paper light blinking
Alex,
To isolate the problem, please try the steps below:
Remove and re-insert the paper tray and then click Go.
Take the drum unit out of the machine and put it back in.
Here, I provided you a link that might help you:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000070/faq000170_007.html?reg=us&c=us&lang=en&prod=hl5250dn_all
Have a great day!
May 07, 2009 | Brother HL 5250DN Laser Printer
Will not print, but ready light is on and tray is full of paper.
remove the paper and look down in the slot, sometimes the (brown) guide mylars get flipped up out of place so that the paper does not settle all the way down, and it blocks the paper path.
Mar 21, 2009 | HP LaserJet 6L Printer
Paper tray is full and the paper light keeps flashing.
First check the machine for paper jams. If not, remove the paper from the paper tray and reinstall it. Then try to print from the MP tray.If this works, check paper size settings on the printer driver, or the small black arm which hangs down next to the paper pick up roller, and is the paper sensor.
Feb 09, 2009 | Brother HL 5040 Laser Printer
Paper tray full message and not printing
there is a black tab in the center where the papers come out that is the tray full sensor arm that is more then likely stuck
Dec 26, 2007 | Kyocera FS-4000DN Laser Printer
Brother MFC-8460N All-In-One Printer Logo
102 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
