We have a toshiba model 65 hm167 and the volume is not working on the HDMI channels for tv but does work on the video channels for games. I have re-connected the wires and everything appears to be in tact. is there another item to check or a possible fix and is this a common problem
  • 736 Answers
Yes there is another item to check. You must check the device that is on the other end of the hdmi cable. There should be an audio output setting on it that will need to be changed to hdmi or pcm. The audio output setting may also have a choice of 48/96 khz, which would have to be chosen.
Posted on Nov 15, 2010
Why did I lose the video signal from the receiver to the TV?
I assume you have tried both hdmi cables from box to tv. If both works good.Cconnect to amp. Connect cable box also on other hdmi inputs like bd, dvd, etc to make sure the spesific port is not faulty. If still no picture try to lower hdmi video display on cable box. You amp may not be able to display the higher resolution.
May 06, 2015 | Onkyo TX-NR535 Receiver 5.2 Channels, 65...
Help with insignia 24 inch flat screen? the av channel will not show the channel where i can play my ps3?at?
It sounds like yoru PS3 has stopped handshaking with your tv. It can happen. It's possible your brother disrupted the connection by unplugging the PS3 before it was shut down. You can try turning on the PS3 first, and then turning on the tv, or vice versa. If that doesn't work, you may need to invest in a cheap HDMI splitter, to plug the PS3 into, and then send the signal from the splitter to the TV. It has happened to me with a computer with the same hardware, once with an LED tv, and once with my surround sound receiver, completely out of the blue. You can try switching HDMI cables, sources, doing putting the tv into maintenance mode and resetting the software. If none of that works, your only option may be to use an HDMI splitter. I did extensive research and read numerous reviews before I settled on this model, due to many recommendations:
ViewHD 2 Port 1x2 Powered HDMI Mini Splitter for 1080P & 3D ' Model: VHD-1X2MN3D
It's available on Amazon here:
Amazon com ViewHD 2 Port 1x2 Powered HDMI Mini Splitter for 1080P 3D Model...
Just in case your HDMI cable was damaged when your brother unplugged it, go ahead and get yourself a decent HDMI cable. The Amazon HDMI cables work just fine.
Jul 07, 2017 | Video Game Consoles & Games
I have a new slimline DVD and a sony bravia HD tv. My PS3 worked with the basis cable and I recently purchased an HDMI cable and now it won't work on any of my 6 AV channels, including 1 of the 2 HDMI...
All you have to do is reset the video settings on the PS3. Hold down the power button until you hear a single beep, then press it again.
That should have reset the video settings so you can play on the new TV.
Regards.
Apr 19, 2011 | Sony Playstation 3 (PS3) Console
I just bought a PS3 slim and hooked it up to my 65'' Toshiba DLP TV using a HDMI cable. The problem is i have picture but no sound. I have tried the settings and all seems to be fine, also tried different...
not 100% sure but check the manual for your tv it may be that you need a faster hdmi cable, as with having a larger tv it will work at a faster rate so the basic hdmi cables wont work.
Nov 19, 2009 | Sony Playstation 3 (PS3) Console
My PS3 only works on my Plasma tv's HDMI channel. None of my other tv's have this HDMI channel. Why doesnt my PS3 work on any other channels or my other tv's? Could anyone help out with that?
When you have the ps3 hooked up through av cables on crt tv not hdmi. Continue to hold power until the console beeps again and this will reset which audio video output resolution back down so it can be seen and heard. Hope this helpes.
Jul 13, 2008 | Sony Playstation 3 (PS3) Console
PS3 vs Toshiba 65" 65hm117
Sorry to here about your problem. I have a 65HM167 Toshiba tv which is the same as your model, and I have my PS3 connected HDMI with no problems. Try using a different brand HDMI cable and a different HDMI input on the tv if you have not already done so. Hope this does it for you, good luck.
Mar 26, 2008 | Sony Playstation 3 (PS3) Console
Hp plazma tv
What is the make and model and what inputs work and what one does not?
Thanks,
Dan
Mar 18, 2008 | Televison & Video
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
