Question about kawasaki PVS1080
Can this model be connected to a TV so that DVD's can be played on the TV?
    Welcome Back:
    Visited the website for 2 consecutive days.
Yes, but you need to get an adapter, Radio Shack has them. The audio and video outs are 1/8" plugs. You need the adapter that goes from the 1/8" plug to the RCA plugs. Then turn the little switch on the right hand side from "DVD" to "AV IN".
Posted on Nov 25, 2010
How do I play my dvd camcorder sc-dc171 on my new tv. model # UN50F6300AF I know I have it connected properly and it worked on my old tv. Any help would be appreciated.
You can connect the A/V out to the inputs of the TV.
if you have any HDMI out in the camera, you can connect the same to the HDMI IN of the TV.
Last option is if you have RF modulator, you can modulate the AV out to RF and then connect the same to the TV tuner RF in of the TV.
Oct 19, 2014 | Sony Handycam Video Cameras
Our new Toshiba SDV398KC2 will not play a DVD. It is like it is on the wrong channel. It shows the DVD playing with the counter but does not show it on the TV. Can you help?
I've seen this behavior before.
For this model, I *think* that you need to use the component connections/input in order to view the DVDs. If VCR shows ok when using the cable, but not the DVD (and it seems to work since it goes up as if playing), try to connect the component (blue/green/red connectors) and it should work.
Don't forget to switch input on your TV to component.
P.S. If you have HDMI on both this dvd/vcr & your TV, it should work with that too.
Nov 18, 2010 | Toshiba SD-3980 DVD Player
Liteon dvd recorder won't play or record from disk or cable tv
You should be able to connect with the AV input, Y, Video R, W. Audio, they go to same color on DVD & TV.
Feb 18, 2010 | Lite On LVW-5005 DVD Recorder
Having trouble connecting Protron Model PD-007 to cable tv
are all your connections correct, (is tv on ch 3) dvd output to tv (coaxial or digital in) using tv remote make sure the source is air (or cable/sat ).. put dvd into player press play let load a picture should show (unless you are connecting with RCA wires then the tv would be on ch "video" this would be below ch 2
Jan 26, 2009 | Protron PD-DVR100 DVD Recorder
Cannot get dvd to play through tv
Check Your Remote For A Tv/Video Button.
Jan 22, 2009 | Televison & Video
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
How do you get DVD player SOUND to play through the TV speakers
plug the stereo headphone jack to your dvd headphone output then connect it to your tv audio/video in and press the tv/video switch in your tv remote control.
Trying to hookup and play standard DVD player
Yellow is video and red&white audio ,so when you hook up dvd does picture preview of dvd come on?You may have to switch to aux for dvd or different channel try checking each channel .
Dec 12, 2008 | RCA F25441 25" TV
Can not use the 5.1 surround sound system
stupid question, but you do have an optical lead connected? the hdmi will only produce stereo sound, you must also have an optical lead (aka tos link cable) connected to produce 5.1
Aug 12, 2008 | LG (GDR8164B) Internal DVD Drive
Older ge tv but cable ready-no remote.... need to find channel to play dvd player on.Recently connected dvd player but can't play a dvd.The tv is connected to a cable box.
Hey wegodsky,
If you're not able to find the right channel on your TV to use your DVD player, you may want to try changing the TV's input source instead. Many TV models will require that the TV be set to an external antenna in order for any other device (like a VCR or DVD player) to function correctly. This can usually be done by pressing the menu button on the TV itself and selecting an option similar to "Input," "Source" or "Antenna" if you do not have a remote control for your TV.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 19, 2008 | Televison & Video
kawasaki PVS1080 Logo
Top kawasaki Televison & Video Experts
wayne chamberlain
Jaime Hernandez
Davor Krstevski
Davor Krstevski
Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
