MC347 Scan (All in One) reports this error cod e(Code 2.145.50 when scanning from the Canon Scan Utility or directly pushing the scan from the scanner. Laptop is Sony M126 and doesnt have any memory issues Error message says: Cannot communicate with scanner for these reasons: - Scanner is turned off - Scanner is disconnected Please check and try again (Scanner driver will be closed) Code 2.145.50 Have tried restarting the laptop and the scan/all-in-one.
SOURCE: error 21550 pixma mp160
I found a solution for this problem
change your usb cable.
you must use a Anti noise usb cable
it's only solution
Posted on Nov 19, 2007
SOURCE: Canon mp610 scanning problem
The readme says that some USB hubs have an issue.
I was having problems and was connected via a hub. I removed the hub and connected the printer directly to the back of the PC and voila scanning is all good.
ALex.
Posted on Apr 23, 2008
SOURCE: Scanning error - cannot scan error code 2,155,0 ???
I had the same problem with a new Canon MP970. Printed ok, but couldn't communicate with the scanner - error 2,155,0.
Canon phone support didn't help, and suggested it was a firewall problem. I uninstalled, and re-installed, turning off firewall, virus software, and everything. No luck. Tried several USB cables, no luck.
Then I uninstalled again - as well as a couple of old drivers and software associated with two now deceased printer/scanners.
This time I plugged the (same) USB in and turned on the device, using Windows' own hardware install wizard.
Now it works fine (at least for now... touch wood).
So - the problem might be either conflict with other printer/scanner devices installed, or with Canon's installation software.
Posted on Aug 02, 2008
Hi
I had the same problem, at first I thought that it was the original drivers (the ones I got with the printer) so I donwloaded the drivers from the canon website, this did not resolve the problem. What I also tried and it worked for me was connecting the printer to the computer with it's original usb cable. I bought a couple of weekes ago a usb extension cable (about 5 m long). With this extension cable I can print but I can't scan any document, it just gives me the same error. Hope this works also for you.
Bye
PS: My printer is a Canon Pixma MP190
Posted on Mar 09, 2009
  • 9 Answers
SOURCE: cannon mx310 won't scan
Go to this link. It is Canon's Support page. It can answer this question.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15603
Posted on Mar 25, 2009
CODE 162,0,0 ON CANON D1350
This happens across the range of Canon Printers. The fix is to push the right button! Yeh I have a differing model, but the answer is the same. Go to the printer and select remote scan. Then invoke computer program. Some one has to be boss either the printer or the computer for scanning.
I can make the scanner printer the boss and issue a TIFF scan to the computer. Just push scan on the printer and select computer (it does a push data)
I can make the computer the boss by selecting the steps below:
Please choose what option you require. Ignore the model number.
The error codes 162,0,0, or 255,0,0, usually indicate that you have not selected a scan type at the machine. Please follow the steps below to perform a scan from the image I-SENSYS MF8230Cn:
Verify that MF Toolbox is closed on the computer and press the [SCAN] button on the printer.
Highlight [Remote Scanner] and press [OK]. The screen will show, "Remote Scanner. Waiting online...".
On the computer, open the MF Toolbox and select [PDF].
Click the green [START] button on the [PDF] window. The machine will start processing the scan.
If you receive any errors or need further assistance with the I-SENSYS MF8230Cn, we recommend that you contact us at 1-800-OK-CANON (1-800-652-2666).
Sep 29, 2014 | Canon imageCLASS D1350
Why does my canon PIXMA 452 say pc not connected when I hit the start scan button
Hi, several things i would be asking
Do you get an error code?
Is the error on the PC or Printer?
Can you print?
How is the Printer connected USB or Wireless
the first is the error code will determine where the fault lies.. if in the 5000 range.. its a hardware problem and would need to be repaired by a service center or repairer.
if you get the printer error.. check the cable or wireless connections
if the PC error it could relate to software you are using to scan too, even if you acquire the correct twain driver (select source).. some are not compatible.. try the scan function in your Canon Utilities IJ Scan Utility. Scan it there first and save it as a PDF or image file.
if you can print its not a connection problem if you cannot print try another USB/printer cable Or make sure your device is setup for wireless run the installation software again and complete the wireless procedures in setup. I hope this helps.. or post me the error code and i can give you a definite answer.. Cheers!
Jun 09, 2014 | Canon Pixma MX452
Meaning of error flag code 4,252,0
Cannot write or read file. - Code : 2,252,0
and because of it stops the scanning.
The following fixed the problem on all computers:
Activate the utility "MP navigator EX"
On the left-top click on Scan/Import
Click on "specify" (i.e. the settting for scan import) and change them to 75dpi and uncheck everything (I only needed to uncheck the "unsharp mask").
Test it now and it will work.
After that wills start working even restoring the settings.
Good luck.
Jan 15, 2012 | Canon Office Equipment & Supplies
Canon MP495 Pixma scanner says this when I try to scan something. Cannot comunicate with scanner for these reasons: -Scanner is turned off -Scanner is disconnected (It is disconnected from LAN, if...
Regarding the Cannon scanner error 2145,50. The MG5220 does this also. The actual problem is that the scanner will not communicate with the computer correctly if it is connected through a USB hub. A direct connection to the computer cures it, for me at least.
I know, I had that problem. I am a retired electronics design engineer.
Jun 30, 2011 | Office Equipment & Supplies
I have a canon MG5220 printer and unable to scan properly the messages I receive are saying Scanner turned off, disconnected from LAN, code 2,145,50. Printing pictures and all other printing jobs work...
Regarding the Cannon scanner error 2145,50. I note you have tried to fix this, but failed. The actual problem is that the scanner will not communicate with the computer correctly if it is connected through a USB hub. A direct connection to the computer cures it.
I know, I had that problem. I am a retired elctronics design engineer.
Mar 07, 2011 | Canon Pixma MG5220 InkJet Printer
How do you use the scanner?
Hi woolyj,
I'm not familiar with this model, but the manual should have this information. I've put direct links to the manual for both Windows and Mac below.
In Windows 7 and Windows XP, there is an included Scan utility. In Windows 7, click start and type scan into the search box. This will locate the scanning software. Choose file, new scan to start scanning. The process is similar in Windows XP.
Feb 28, 2011 | Canon PIXMA MX310 All-In-One Printer
403 people viewed this question
jasbo
jasbo
