Question about Indesit W 123 Front Load Washer
I have replace bushes but it still is spraking
  • Indesit Master
  • 3,463 Answers
If it is still sparking, then the motor armature could be worn, or a segment missing, also there is a wrong and right way to fit the brushes, make sure you have them the right way round.
Posted on Nov 13, 2010
Trouble shooting ford fusion
trouble shooting on a 1993 merecry topz i have fire to alll the car but no fire to the sprake plugs
Aug 22, 2017 | Ford Cars & Trucks
My bushings are going and I was wondering if I have to replace the whole axle with the bushings or if I can just replace the bushings?
axles and bushings are two totally different things. when you say bushings I think of upper and lower control arms that have bushing pressed in by machines that can be pressed out the old ones and press in the new bushings. Axles I think of constant velocity joints and boots which also can be replace with new ones.
please tell me what you are asking?
Oct 03, 2013 | 2009 Chevrolet Aveo
Speed queen washer
You should go speak to an employee of lowes or home depot or maybe even an appliance store in your area...
Explain to them what has happened and will be able to help you and tell you which replacement you may need...
It's likely to be a fuse or burnt wiring..
Also check the breaker in your home...
I hope this helps....
May 15, 2013 | Washing Machines
Replace rear swaybar bushings
Yes, it is quite easy. These bushings are a very common source of rear end rattles. Remove the bushing retainers, replace the bushing, and then the retainers and bolts. Torque is low, 14 ft-lb
Aug 26, 2012 | 1997 Toyota Camry
Front end bushings what are they how are they
Well there are stabilizer bar bushings, control arm bushings and strut mount bushings. The stabilizer bushings are usally bolted around the the stabilizer bar and attach to the frame. The control arm bushings are usally pressed into the control arms. The strut mount bushings are on top of the struts. Normally they are replaced as needed. The strut mount bushings are good to do when replacing the struts.
Mar 12, 2010 | 2005 Subaru Outback
Control arm bushings
Special tools are required. Definitely not for the novice. An alignment will be needed after the required work is performed
Apr 03, 2009 | 2000 Buick LeSabre
No power on key
There's a gas module located above the spare tire . This is famous for shorting out causing the problems I described and blowing a fuse in the panel, the fuse number is f43 which causes the vehicle to shut down, Hope this helps someone else. Thanks
Jan 28, 2009 | 1996 Ford Explorer
2004 Nissan Quest front control arm bushing replacement.
Sorry guys not a solution but I too have an 04 Quest, which supposedly has worn controller arm bushings and Nissan says I need both controller arms replaced. For a total of $950!!! I was told that they need to replace the whole arm and cannot replace only the bushings. Now reading the posts on this site I find that to be untrue. Seems all I need to spend is anywhere from $25 to $35 per bushing.
Nov 30, 2008 | 2004 Nissan Quest
Indesit W 123 Front Load Washer Logo
55 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
