Question about Motorola Mobility RAZR V3
Motorola RAZR V3 Cellular
My V3 will turn it's self off and the screen turns white,I can't use it at all?
I can turn it back on and it looks ok just for a few seconds.
  • Anonymous Jun 19, 2008
    my phone is white and i can't see anything!
Yea mine does that too.
its a piece of ****.
Posted on Jun 19, 2008
Verizon Razr V3 with locked screen. Verizon
yes ,down load p2k or another flashing utility,then flash your phone
Mar 11, 2010 | Motorola Mobility RAZR V3
Lost unlock code
Depending on how many modifications, hacks, or customizations that you perform on your Motorola RAZR V3 phone, there may be situations where the phone becomes unusable or completely locks up. I have had visitors to the site report not being able to delete ring tones, text messages, or have other strange behaviors with their Motorola RAZR V3 phone.
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3:
1. Open your phone up and go to “Settings”
2. Next go to the selection for “Initial Setup”
3. Next go to the selection for “Master Clear”
4. Then select to confirm the option.
5. Now enter the security code which should be “000000”
6. Finally press select or ok and the phone will reset itself to the factory condition
Congratulation you have performed a “hard reset”, “hard reboot”, or “master reset” on your Motorola V3 RAZR and it should return to normal operating mode!
Trackbacks that led to this post:
hard reset motorolla razr v3
hard reset razr phone
wii master reset
hard reboot motorazr
how to hard reset a razor v3
master reset code for motorola v3
master reset code razr v3
master reset for v3 via pc
master reset motorola razr 2
master reset v3 razr with white screen
motorola v3m master reset
p2k commander
razor master reset
razr 3 and how to reset
razr master reset ebay
razr master reset password
razr master restart
razr screen master reset
reset razr
reset razr to factory
reset razr v3 to factory
v3 hard reset razr
v3 razr reset hard boot
Jun 14, 2009 | Motorola Mobility RAZR V3
Won't turn on, just a white screen flashes
My old phone did this, i had to get a new one, :/
Apr 17, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Motorola RAzr V3 - screen went black but key pads lights up
replaced the flexcable on the phone to have it fix
Jun 29, 2008 | Motorola Mobility RAZR V3
Screen turns white
most common prob on v3 model is its flex connector.  try replacing it or look for a technician who can handle the job. im sure your prob will be solved...
Oct 12, 2007 | Motorola Mobility RAZR V3
White screen power down disconnect
My phone was turning itself off when idle and while on calls. I deleted the videos I had taken and now it works fine.
Sep 04, 2007 | Motorola Mobility RAZR V3
Motorola v3
my phone did exactly the same,, what i did was when you see the boot loader press the red off button,hold it down then let go the key pad lights up,then the screen lights up white then all goes off and what i did was press the off button ounce quick and everthing came back on ok not sure if it was a fluke but might work phil
Aug 16, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Motorola v3
look take the battery out and let it sit over night and then u put the battery back in the phone and then put it on the charger when it finish charging cut it on it should work
Aug 11, 2007 | Motorola Mobility RAZR V3c Cellular Phone
V3 razr goes to white screen
software problem u must contact service center and do flash it
Jun 15, 2007 | Motorola Mobility RAZR V3
Motorola RAZR V3 Cellular Phone
Ok so when I close my phone I still see the time and my background picture but no light immanates (hope I spelled that right)from the screen if thats what your saying that's normal. Now as far as the inside screen if you dropped it the connection that lets the phone know it's closed may be jarred lose and offset (not sayin u dropped it)although you say it dims. When you close your phone the inside screen should turn white and then turn off just barely have your phone open to check, if it does this then the connection is working. And you need another opinion.
Dec 07, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
56 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
