Question about Whirlpool GS465LELS Dual Fuel (Electric and Gas) Kitchen Range
I have GS465LEK that displays F4 Sometimes pressing CLEAR/OFF to clear the display solves the problem and other times the over will shut off and not come back on, and pressing the CLEAR/OFF does not work. Aster 30 -45 min. passes the oven functions will come back on.
  • 126 Answers
SOURCE: Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Posted on Dec 10, 2007
ranger25
  • 72 Answers
SOURCE: error codes e2 and f3
F3 is an open or shorted oven temperature sensor, you will have to replace this and it should be attached near one of the elements but you will have to pull it out through the back.
E2 is, sorry to say, a possible ERC or Electric Range Control, otherwise known as the brain behind it. But on the plus side, sometimes it gives this code intermittently when it can't process the information from a failed sensor, so you might get lucky.
Posted on Jan 29, 2008
aborcass
  • 2651 Answers
SOURCE: whirlpool gold electric range control panel blinks w/all lights powers oven off
you say after 5 min of plugging in , is this brand new and still covered under your 1st year warr???if so get an authorized servicer out there to take a look at why should you be responsible for their problem
Posted on Mar 17, 2008
var-pun
  • 331 Answers
SOURCE: electronic oven control malfuntion
Is your oven new??????????????
the display is in Hex as far as i can guess may be the micro controller is faulty and needs to be changed
do not switch it on and off this will not help solve the problem
Posted on Sep 10, 2008
SOURCE: Whirlpool cooktop,built in oven and range
not be funny, but I have the same problem-and/maufacturer
Wirlpool makes a pice of junk! and my range (3 years old) is going in the trash soon.
This range uses a computer and it has NO fan to cool the computqer look at you computer it has a fan.
Posted on Mar 03, 2009
How do i reset the sid display in 2008saab93turbo after replacing battery
pressing the CLEAR button for 8 seconds. on older 9-5 and 9-3 SID's, that you must press CLEAR once & release, then press CLEAR a second time, and hold for 8 seconds. While holding down CLEAR for this second time period, at the 4 second mark "CLEARED" will be displayed, and you will hear 1 beep. If you release the CLEAR button at this point, the DTE and MPG will be cleared out. If you continue holding the CLEAR button past the 4 and 8 second marks, you will hear a 2nd beep, and "SERVICE" will be displayed. This now means that you have cleared and reset the Time For Service message.
Dec 01, 2014 | 2008 Saab 9-3
What does F4 on the display mean?
If "F4" through "F16" appears on the display, there is an electrical problem with the washer. Press the "Pause/Cancel" button twice to stop the washer and press the "Drain/Spin" button to drain any excess water in the machine. Select the cycle again and press and hold "Hold to Start" to restart the washer. This should clear the error and return the washer to normal operation.
If any of the error codes persist, the problem with the washer may be serious. Contact a qualified service technician to repair the washer.
Read more : http://www.ehow.com/way_5389738_whirlpool-duet-troubleshooting.html
Jul 06, 2014 | Whirlpool Washing Machines
H4 Displays
H4 indicates "low temperature", possibly caused by a failure of the heater lamp or fuser. Sometimes this error is shown without an actual damage when the power cord is pulled without shutting down the copier first.
To cancel the error code, press [CLEAR], [AUTO], [CLEAR], [AUTO] in rapid succession. The display should go blank. Next, select 14 (clear low temperature code), press [START]. Finally, switch off and on the machine.
If there was no actual damage (i.e. power cord pulled), the machine should be OK again. If the error persists, immediately or after short time of operation, you will need to contact Sharp technical service for repair.
Jan 10, 2011 | Sharp AR-5316 Advanced Digital Imager...
The copier displays H4 What is the solution?
Jan 09, 2011 | Sharp AR-5316 Advanced Digital Imager...
Can't receive or send faxes
In case you haven't solved this yet:
  1. Press the Setup button (c01361401.gif ).
  2. Press the Right arrow button ( > ) until Tools displays on the control panel, and then press OK .
  3. Press the Right arrow button ( > ) until Fax Log displays on the control panel, and then press OK .
  4. Press the Right arrow button ( > ) until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clear displays on the control panel.
  5. Press the Cancel button ( X ) to exit.
You can go to this web page also:
Fax Log Full Message
Thanks for using Fixya.
Feb 23, 2009 | Digital Products Hewlett Packard OfficeJet...
Which function key allows to switch to tv
You need to press hold the FN key and press the F4 function key once which toggles the display to the External Display source like the television connected along with the LCD of the Notebook.
If the FN and F4 key combination is pressed again, the display will dissappear from the LCD of the Notebook and remain only on the external source.
If the FN and F4 key combination is pressed third time, the display will be back on the LCD of the Notebook and will not remain on the External display source.
Here are these details in other way :
First time pressing FN + F4    ---> Display on LCD and External display
Second time pressing FN + F4 ---> Display not on LCD but on the External Display
Third time pressing FN + F4 ---> Display back on the LCD and not available on External Display (Normal position).
Below are the details of what the Function keys in your DV1000 Notebook work :
fn + f1 Opens Help and Support Center fn + f2 Opens print options window fn + f3 Opens default Internet browser fn + f4 Switches the image among displays fn + f5 Initiates Standby fn + f6 Initiates QuickLock fn + f7 Decreases screen brightness fn + f8 Increases screen brightness fn + f9 Plays, pauses, or resumes an audio CD or DVD fn + f10 Stops an audio CD or DVD fn + f11 Plays the previous track or chapter on an audio CD or DVD fn + f12 Plays the next track or chapter on an audio CD or DVD fn + esc Displays system information.* (*To clear the system information display, press esc.)
Hope this helps...
Oct 11, 2008 | HP Pavilion dv1000 Notebook
XEROX WORKCENTRE XE80 DISPLAYS AN H3 CODE
Try this procedure.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time
Jul 17, 2008 | Xerox Office Equipment & Supplies
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Machine stops and F6 appears
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
elem_1_spacer.gifGive this a try, the code is a fuser not warming code. This could resolve it.
Jan 13, 2008 | Xerox WorkCentre XE90FX Laser Printer
MY SHARP AR5316 DISPLAY H4 WHEN I PUT IT ON
Here is the process
Dec 11, 2007 | Sharp AR-5316 Advanced Digital Imager...
Whirlpool GS465LELS Dual Fuel (Electric and Gas) Kitchen Range Logo
56 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
