Question about Belkin Play Wireless USB Adapter (F7D4101)
Can you help me on signal strength "LOW"? - Belkin Play Wireless USB Adapter (F7D4101)
    Novelist:
  • 125 Answers
Can you tel me details about the router you are using plz
Regards,
prema
Posted on Nov 13, 2010
My tv says digital channel strength is low
Hello
If you are using this TV with Cable connection, the strength of cable signal is low. Contact the cable operator and ask him to put a signal booster at your premises. If you are using it with On Air transmissions receiving, include an antenna signal booster at the mast of your yagi antenna on roof. OK
Jul 05, 2011 | Toshiba 36A40 36" TV
I have no signal, my "service state" says "out of service". My signal strength is "0 dbm 0 asu" and "roaming" says "not roaming". Please help. I'm with...
Try cutting the phone off for 5 minutes then back on. If that don't work you'll need to call the company to see if the tower is down or if they can reset the phone.
Jul 03, 2011 | Cell Phones
My signal strength is very low
You Can Try Changing the Wireless Channel on the Router you have 11 Different Channels Available.
> Steps to change the Channel
- Open Internet Browser on Hard wired computer & Go to 192.168.2.1
- Towards your Left Corner Under Wireless Click on Channel & Ssid
- Leave the Password Blank Click on Submit
- Change the Wireless Channel To Number 1 or 6 or 11.
- Click on Submit
- Check the Signal Strength
- If you Still Have Low Signal Strength you Can Try Updating the Firmware or Changing the Wireless Mode to G only... :)
Mar 06, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Low wireless signal strength compared to other computers - the netbook consistently reports about half the wireless signal strength that a Dell laptop sitting next to it does. in low signal strength areas...
For HP Mini 1000, the wireless device can be problematic.
I will recommend the HP Mini 210-1084. This has the fastest wireless in the HP Mini range of Netbooks.
Good luck.
Jul 17, 2010 | HP Mini 1000 Netbook
Most of the channels breaking up despite auto retuning
could be one of a few things,
low signal strength, aerial out of line with transmitter.
bad coax connections losing signal strength.
coax broken inside, or old and not low loss.
Get the aerial checked for direction, half a degree out of line over a few miles and you will lose a lot of signal strength, as will old coax (aerial cable) and if you are using an unshielded coax you could be losing signal strength through the cable itself. Replace the connecters and try to use a straight run of cable instead of having joins in it as these joins, even if using connecters, will cause a weak signal. If yiu are running more than one tv off your aerial, invest in a booster.
Feb 06, 2010 | LG 32LG30 32 in. LCD HDTV
Low signal strength
Having many users connected to a single WAP (wireless access point) will not affect the signal strength. It will however, affect the speeds each user is capable of.
Most Linksys routers have a homepage address of 192.168.1.1 - Enter this in your web browser.
From there you will be able to find wireless settings and enable either a password or a WEP key for security.
If you found this helpful please leave feedback.
Feb 05, 2010 | Linksys Wireless-G WRT54G Router
Low signal strength, fluctuations in signal strength
1. probably the distance between the router and the laptop 2. Interception from other devices like cordless phones , cell phones, micro wave ovens 3. Upgrade the firmware of the router
Hope this helps
Thanks
Ranjit
Nov 04, 2009 | Buffalo Technology WHR-G54S Wireless...
Weak signal 60 feet away at neigbhoor's
Some routers just don't put out strong signals. The problems could be wiring in/around/at your house or neighbors....causing weak signal. Are the signal strengths strong in your house?
We have super signal strength on ours upstairs (we have a bi-level house) but downstairs the signal is very low. All the wiring in the house and anything electronic or otherwise can block it.
Hope this helps at least some. Good luck!
Jul 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
Low to no signal strength
Try agusting the wirless properties for your wirless card. You will need to go uder start then go to conect to and the show all conecsions. The you will need to right clcik on the wirless conecsion and go to properties. Now you will click the button that says configure. I hope this helps
Jan 01, 2009 | 2wire HomePortal 1800HG Router...
Signal strength very low. Belkin ADSL2 modem with wireless g router F 507632-4
signal is bouncing off doors and walls to get to your comp
move comp closer to modem if it increases and your signal strength increases then you know youll have to be close to modem
other problem someone taped your signal and it working off of it call your provider to come out test the wireless signal strength and or password your wireless router settings so some one cant interfere with signal
i dont like wireless myself in the home i go straight cable with ether net cord this always has strenght and cannot be tapped
May 09, 2008 | Computers & Internet
Belkin Play Wireless USB Adapter (F7D4101) Logo
49 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
