Question about Fisher and Paykel GWL11 Top Load Washer
My 6YO washer has a small leak every time I wash. Not sure what to check, I just do not want it to get worse and want to fix it economically. The leak comes from under the front right corner.
  • firberger Dec 08, 2010
    this solution worked perfectly , Happy to have the washer working properly and NO leaks!
  • 88 Answers
Pump seal has failed. Do not use the washer until you have replaced the pump - you risk blowing the main board.
No tools required - just remove two electrical connectors, turn the pump, release white plastic tab, turn pump some more and pull out (etc).
Some water will be released - suggest you have towels ready to soak up.
*** Disconnect washer from power before attempting repair ***
Posted on Nov 14, 2010
Testimonial: "Thank You , The pump was bought on ebay and I replaced it with little effort, great help Thank YOU! "
Its leaking water while the washer is washing
Hi
If your washer leaks every time you run it, then check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
Please rate the solution if you find it useful and helpful.
Thanks
Rylee
Oct 16, 2009 | Whirlpool Washing Machines
Washer clunking
Look just inside the door. Between the door and the tub. Feel around behind the rubber boot that seals the tub to the door. See if you find a bic lighter, pocket knife or something like this.
Please rate solution if helpful
Aug 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Jul 02, 2009 | Maytag PAV2300 Top Load Washer
Fisher & paykel ilw16us leaks water when filling
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
May 03, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing machine spilling water out on the floor
t leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Apr 03, 2009 | Whirlpool LSR5132PQ Top Load Washer
Siemens Siwamat 2105 washing machine leaking
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
Dec 10, 2008 | GE Spacemaker WSLP1100D Top Load Washer
Leaking washing machine
During fill only
All the time
During fill only
All the time
Nov 12, 2008 | Danby DDW1805W Designer Series...
Frigidaire Gallery Washer GLWS1233 leaks water when after the wash cycle
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician fo Hope that helps! Should you have any further questions, please feel free to post them here.
    P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you fix your problem.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
    r further details.
Oct 11, 2008 | Frigidaire Washing Machines
My Ge washing machine is leaking from the Bottom
During fill only
All the time
During fill only
All the time
Aug 12, 2008 | GE Profile Performance WPSF4170WAA
My washing machine is not working properly!
During fill only
All the time
During fill only
All the time
Jun 02, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
306 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
