Question about Minolta XG-A 35mm SLR Camera
What battery does the XG-A take? - Minolta XG-A 35mm SLR Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Minolta Master
  • 102,366 Answers
The XG-A takes two 1.5V alkaline-manganese A-76 (or equivalent) or two 1.55V silver-oxide EPX-76 or S-76 (or equivalent) batteries.
Posted on Nov 13, 2010
Testimonial: "Thanks for telling me which battery it took. Someone sold me this old camera last week so I wasn't sure. I appreciate it."
XG-SF3000 has flat battery
There is NO battery on this generator! It is pull started by a handle that is built in to the machine.
Jan 12, 2013 | Cars & Trucks
How do i load batteries into my minolta xg-a camera
Use a coin to unscrew the battery cover on the base of the camera.
If you need a manual, you can download one from
http://butkus.org/chinon/minolta/minolta_xg-a/minolta_xg-a.htm
The battery replacement instructions are on page 12.
Aug 12, 2011 | Minolta XG-A 35mm SLR Camera
What type of battery does it use?
The XG-A uses two 1.5v alkaline-manganese (Eveready A-76 or equivalent) or 1.55v silver-oxide (Eveready EPX-76/S-76 or equivalent) batteries.
Do not use 1.35v mercury batteries (Eveready EPX-675 or equivalent), which have a similar shape.
Aug 22, 2010 | Minolta XG-A 35mm SLR Camera
Lacrosse xg 55 - Do I need to replace the battery? When I use the light nothing displays is this a battery issue? How do I change it if it is the problem?
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for
the small cost saving in doing it yourself.
Jul 16, 2010 | La Crosse XG-55 Wrist Watch
Does the minolta xg-a have to have batteries to use the view finder? if so, what kind of batteries does it take
The XG-A requires batteries, not just for the viewfinder, but also for the shutter. It uses two alkaline A-76 (or equivalent) or two silver-oxide EPX-76 (or equivalent).
If you need an owner's manual, you can download a PDF version from http://www.butkus.org/chinon/minolta.htm
Feb 16, 2010 | Minolta XG-A 35mm SLR Camera
My camera will not advance to the next frame and
Hello. Sounds like the camera needs new batteries.
Jan 18, 2010 | Minolta XG-A 35mm SLR Camera
The battery of my XG-55 is down. I tried with several watch repair labs, but they told me that after changing the battery, the watch doesn't start again. Any advice?
When you change the battery on this watch you have to short the circuit board. You need a fine pair of tweezers and you need to look on the circuit board for an arrow or bare spot, put 1 end of the tweezers on that place on the circuit board and the other on the battery at the same time. that should do the trick if the battery was installed correctly and the battery is good.
Nov 18, 2009 | La Crosse XG-55 Wrist Watch
How do I remove the alternator from a 2002 V6 Hyundai Sonata once I have disconnected the alternator?
Removal
  1. Remove or disconnect the following:
    Negative battery cable Radiator mounting bolts, 1.6L only Alternator drive belt Alternator wiring harness connectors Alternator. It may be necessary to raise the radiator
Fig. Exploded view of the alternator-XG 300 and XG 350
Removal & Installation
    Negative battery cable Alternator drive belt Alternator wiring harness connectors Alternator. It may be necessary to raise the radiator 5ead6d5.gif
  2. Fig. Exploded view of the alternator-XG 300 and XG 350
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    Fig. Exploded view of the alternator-XG 350
  3. Install or connect the following:
    Alternator and reposition the radiator, if raised Alternator wiring harness connectors Alternator drive belt
  4. Adjust the alternator belt and torque the bolts to the following specifications:
    1. Accent: Pivot bolt to 14-18 ft. lbs. (19-25 Nm) and adjustment bolt to 14-20 ft. lbs. (19-28 Nm).
    2. 2.0L and 2.5L Sonata, Elantra and Tiburon: Pivot bolt to 14-18 ft. lbs. (19-25 Nm) and adjustment bolt to 105-132 inch lbs. (12-15 Nm).
    3. 2.4L Sonata: Pivot bolt to 26-41 ft. lbs. (34-54 Nm) and the adjustment bolt to 14-18 ft. lbs. (19-25 Nm).
    4. 3.0L Sonata and XG 300: Pivot bolt to 14-18 ft. lbs. (19-25 Nm) and adjustment bolt to 11-16 ft. lbs. (15-22 Nm).
  5. Install the radiator mounting bolts, if removed.
  6. Connect the negative battery cable.
I hope hrlp you with this. Good luck and remember rated this help-
Aug 25, 2009 | Hyundai Sonata Cars & Trucks
MINOLTA XG-1 & XG-9
If everything lights in the camera when you test it ,it means the battery is alright,try this trick"Rotate the film advance connection at the bottom of your camera using a nickle (not the battery compartment) the one directly at the bottom of the shutter and should click if there's not you have some bigger problem.Good luck.
Sep 30, 2008 | Photography
Minolta XG-A 35mm SLR Camera Logo
179 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
