Question about Toshiba Office Equipment & Supplies
DEVELOPER e-STUDIO 450 PUMPING DEVELOPER INTO WASTE BOTTLE
  • Toshiba Expert
  • 1,326 Answers
Did you set the developer up right in service mode??
Posted on Jun 19, 2008
How developer material fall in wastage box to repair it?
Is normal for excessive toner/developer go inside waste toner box...Once the waste toner box full, u need to dispose it and make sure the sensor detection surface on the box is not dirty...
Mar 13, 2015 | Toshiba E-studio 452 Digital Copier...
My thoshiba e-studio 352 giving an error "latch the developer unit". Please help to resolve this issue. Thanks Roy Robinson
I think the cable is not connected properly on the developer unit...Open front cover, take out the waste toner box, and u will see the connector.
Oct 02, 2013 | Toshiba e-Studio 350 Copier
I have a ricoh aficio MPC2050 copier V2295900860 and it is saying that the waste toner bottle is full and needs to changed how do i do this and where is the waste toner bottle located.
Hello!
Your machine have 2 waste bottles.
The bottle 1 is placed in the front door. (See the picture). You can empty it or replace it.
(is less expencive to empty it)
The secund waste bottle is in the left. See this picture
Now, you just need to make sure what waste bottle is mentioned in the display.
Hope this helps
Sep 12, 2011 | Ricoh Aficio 450 Copier
Toshiba estudio 450 Used toner cartridge is empty and I have put it back in but machine keeps stating to dispose of used toner...replace the ic of toner cart. is till problem how will solv..?
Hello
You will have to remove the waste toner bottle, put some cleaning solvent in the bottle and wash the toner out of the bottle.
Please the bottle out to dry before you replace it in the machine.
Regards
Jul 24, 2011 | Toshiba E-STUDIO 450 Copier
Our imagistics 8130 has the replace waste toner bottle error message on but the waste bottle is empty and I turned a wheel above the waste toner bottle and nothing.
Hi how are you this is jack ... jack_pak@hotmail.com
Dear you wash the waste toner bottle clearly. But error still your copier you check the waste toner bottle dection SENCER OR IS DIRTY CLEAN IT..
PLEASE VOTE ME .
Thanks
Best Regards,
Aug 14, 2010 | Toshiba E-Studio 3511 Color Copier
How to change devolper
Remove the waste bottle then the drum unit from the front of the machine.**Cover the drum unit so it is not exposed to the light.
Remove the Developing unit and empty the developer from the dev unit into waste bag. Once all the developer is removed...take the new bottle of developer and pour it all into the dev unit. Replace the plastic cover back onto the top of the dev unit. Re-install the dev unit back into the machine, then replace the drum unit back into the machine then replace the waste toner bottle. Close the front door. Enter the copier adjustment mode on the keypad by pressing "user preset,Orig size(Ledger), and Multi-copy key #3 in sequence.
Then press Multi-copy key #8 , then press the Print key.
Now select th code "09" and Press Print.
The machine will run for approx 2 minutes to initialize the new developer. Press Clear/stop and User preset to escape from the service mode. You are done.
Jun 07, 2010 | Panasonic FP-7750 Black and White Copier
I dispose of toner and still keep getting messages
I assume when you say you dispose of toner you are emptying out the waste toner bottle and putting it back in the machine. if so here's your problem.
There is a sensor, mounted to the copier, just behind the waste toner bottle (on the upper righthand side). This sensor shoots a beam of light through a small portion of the waste bottle - if the beam is not received on the other side then the copier thinks the waste bottle is full. NOW...even if you have emptied it the interior of the bottle may still be dirty/black enough (leftover residue) to stop the beam from making it through the bottle - this gives you the message. You will need to put in a new bottle.
Jan 23, 2010 | Toshiba e-Studio 350 Copier
How do I add developer to a E-Studio 350
The developer should be change by a tech. You have to dump the old and replace with new and then set the developer calibration. Waste toner is right in front, a black container that you remove, dump, then put back in place, try to do that each time you add toner so that it never fills all the way full. I do service your area if you need help. Email me at Lbcoaster@aol.com
Hope that helps...
Lbcoaster
Jul 29, 2008 | Toshiba e-Studio 350 Copier
Toshiba estudio 35
What is the copy count on the machine?
Toshiba copiers have service intervals to replace the drum, cleanerblade, corona wires and developer material.
That could resolve your printing problem.
May 09, 2008 | Toshiba e-Studio 350 Copier
80 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
