Question about Sentry Fire Safe - Safe - DS3607
My safe keeps beeping - 1 beep every 30 seconds or so. We changed the batteries - that isn't the problem. I can get into the safe without a problem and no indicator lights are on. What is the beeping/how can I get it to stop?
2 Suggested Answers
SOURCE: We have a Sentry safe
http://callitout.com/quotes/index.php/kick-it-to-the-curb/55/sentry-fire-safe-wont-open-its-broken/
Its the most reazonable answer and it worked!!!!!!! dial the code and tap on the handle so it would get lose
Posted on Feb 02, 2011
My camper has been in storage for 2 months. The carbon monoxide detector beeps every 30 seconds. I pushed the reset button and it does no longer beep. Is it still safe to use this detector?
Dale, My alarms beep like that to warn me of batteries needing replaced. What I do is hit the test button and ensure it sounds. I would still replace the battery(ies) and retest when you do.
Mar 07, 2015 | Kidde Carbon Monoxide Alarm Model Kncobb
I need to reset my combination to my mesa safe
This safe was shipped with a factory Master Code of 1-2-3-4-5-6-7-8.
If you changed the Master Code you will need to use the code you changed it to.
Deleting your current User Codes:
Input * - * lock will beep twice
input 6-6-6-# lock will beep twice
Input current Master Code - # lock will beep twice
Input user number - # lock will beep twice (not user code, user number is which user number you want to delete 1,2,3,4 or 5)
Re-input user number - # light stays green for 3 seconds
Example: * - * - 6 - 6 - 6 - # Master Code - # - 5 - # - 5 #
This will delete user 5
Unsuccessful code change: five beeps, repeat the steps.
Changing User Codes: Code length can be 3 to 8 digits long
Input 4 - 4 - 4 - # lock will beep twice
Input Current User Code - # lock will beep twice
Input User Number - #
Input New User Code - # lock will beep twice
Re-input New User Code - # light stays green for 3 seconds
Example: * - * - 3 - 3 - 3 -# - User Code 2 - # - 2 - # -New User Code - # - New User Code - #
That example will change user code 2.
Unsuccessful Code Change: five beeps, repeat the steps.
There are other things you can do with the MSL-500 lock that comes on the MFL-2014E. You can change the master code, activate user codes, change user codes, delete user codes, set single user or dual user modes (dual user modes requires two user codes to be entered each time you want to open the safe, set the time delay.
The Mesa safe company has a website which does have the operating instructions for the MSL-500 electronic lock. A Google search of "Mesa MSL-500 Operating Instructions" would get you there quickly.
Oct 18, 2013 | Mesa Safes MFL2014E Safe Depository Safe...
I turn my PS3 on and the screen is always blank. I tried holding the power button for 5 seconds as per the manual and this doesn't help, nothing happens. I also tried entering a safe mode but I can't as I...
I recommend you try to access Safe Mode again.
The way I understand it, your ps3 is supposed to turn off after the third beep as you keep holding the Power button. Then you start the sequence again, and this time you will get the double beep.
Of course, Safe mode is only available for PS3's with system software of 2.60 and higher, perhaps yours is older than that?
I hope that helps.
____________________________________
Sony PS3 Safe Mode
Apr 21, 2010 | Sony Playstation 3 (PS3) Console
KIDDE Nighthawk Carbon Monoxide alarm beeping
If detector is more then 5 years old it will beep every 30 seconde to worn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Jun 03, 2009 | Kidde Nighthawk Combo Gas/co Detector
Viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
May 10, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
30 Seconds High Beeps with Hazzars
The battery is low which is causing the alarm to activate, replace the battery. I'm going to guess that it gets pretty hot where you are between the times you listed. BMW cars have been known to be affected by heat.
Dec 17, 2008 | 2001 BMW 5 Series
Charging
It's beeping because the battery is completely dead and needs to charge. If beeping doesn't stop after a while of charging, you may need a new battery or a new charger.
Jul 21, 2008 | Motorola Mobility RAZR V3
Sentry Fire Safe -  Safe - DS3607 Logo
74 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Joseph Vernice
Joseph Vernice
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
