Question about Hamilton Beach 50754 WaveStation 10 Speed Blender
Need to know how to put gasket back into the glass container ijones564@hotmail.com thank you Irene Jones
    Genius:
  • 1,340 Answers
First you set the plastic base on.Then you put the grinder blades on.Then put the gasket on top of that.Then screw in the glass container.All blenders are set up that way.I am including a link for your blender,just in case you do not have one or lost yours.Just click on your number and a new screen comes up.You do not have to sign up for anything,just enter the 5 digit code.This will not result in all kinds of pop up junk either.If you do not have Adobe,simply do what it asks you when prompted.It is a free safe download and is commonly used.Greg
http://www.retrevo.com/samples/Hamilton-Beach-Blender-manuals.html
Posted on Nov 14, 2010
We have an old Waring Futura 900 blender that leaks at the bottom of the glass around the beater blades. How do you repair? Is there a gasket?
Yes their is a gasket. However try to tied the hole blade kit a litle harder since it might be loose, it might be also dirty you can loose it clean it and put it back.
Have a visual insections since the glass might be broken a litle bit also.
Good luck
Aug 09, 2010 | Waring BB180 Work Top Blender
Putting glass and washer together
  1. Place glass container upside down on safe working area.
  2. Place rubber gasket/ring on top of opening first.
  3. Place stirring or mixing blade on top of rubber gasket/ring.
  4. Take the plastic retainer and screw it on over everything previously assemble.
  5. Hand tighten only enough that you can reverse the whole operation when comes cleaning and disassemble time.
Feb 13, 2010 | Elite 072-04-1198 Blender
Leaking from the bottom of the glass container through the screw
Check the rubber gasket for damage or hardening and also for chipped glass on the sealing surface. Make sure the ring is not cracked causing loss of compression of the seal.
Also check that the leak is NOT at the shaft seal. Replacement parts should be readily available,
Nov 08, 2009 | Oster 4093-8 Osterizer Classic Blender...
The handle to the pour spout on the bottom of the blender has broken off. So I can not put smoothee in my glass. I have to pour it in my glass for the top of cannister. Where can I get replacement parts?
If any body needs any parts for the villaware 5785 series I have everything available except the plastic smoothee container. I have the smoothee spout. If you need it I can send it to you and you can just reimburse me for the shipping after I have sent it to you. You can contact me at amylovescats2010@yahoo.com. Villaware is no longer selling the smoothee container, I doubt if they are selling other parts for it.
Oct 16, 2009 | VillaWare 5785 Smoothee Bar Work Top...
My jugs are leaking too at the bottom. If anybody finds the replacement jugs somewhere please let me know. I have a double smoothie maker model 5787. Thanks! email me at javstarz@hotmail.com
My blender would do that if I didn't screw the jar on firmly enough. Sometimes the action of the blades will even loosen the bottom from the jar during blending, so I always hold the jar handle while the blending is going on. That way if it starts to undo, I can twist it back tight. Before I learned that trick I had smoothies leaking out the bottom - what a mess! Also make sure you put the gasket/seal on in the right order. If it's in the wrong place it won't seal correctly.
Sep 06, 2009 | Blenders
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
40 yr. old Waring blender
plz cont -- 23051554 \ 23095757
Jun 26, 2008 | Blenders
Juicelady JL600
Call 1-800-233-9054 Found this on the web after searching for an hour looking for the same thing.
Jan 04, 2008 | Juicelady JL600 Professional Work Top...
Hamilton Beach 50754 WaveStation 10 Speed Blender Logo
70 people viewed this question
Top Hamilton Beach Blenders Experts
Henry  Thomas
Henry Thomas
John Tripp
John Tripp
eyecam
Are you a Hamilton Beach Blender Expert? Answer questions, earn points and help others
