Question about Brother Office Equipment & Supplies
My DCP-150C Brother printer does not print magenta or yellow, despite repeated cleaning and cartridge replacement
SOURCE: Brother DCP-135C MAGENTA not printing tried
What you have to do is flush the head externally, then get an eye droper remove the plastic spout ,now you will only have the rubber resivoir. squese the rubber and place over the print head . when you release the rubber your creating a vacume wich will draw out the dried ink. repeat about 5 times on the entire head then flush with cartridge flush .....pretty messy so have lots of tissue paper and gloves.
reasemle head and case run the cleaning process 3 times and you will be smiling.
ps make sure you have lots of ink in your cartridge or you will have to redo the process again.....good luck
All Brother printer have this problem with the red ink.
Posted on Apr 27, 2009
komguy
  • 2306 Answers
SOURCE: my Brother DCP-150C cant print, displays, UNABLE TO CLEAN"
Unable to clean either means there's a paper scrap in the clean station, or the ink overflow box is full and needs to be changed by a dealer. Sorry, no quick fix...
Posted on Jul 22, 2009
komguy
  • 2306 Answers
SOURCE: brother dcp-150c Clean Unable 46
If you actually changed the flushing box, you should know how to go to the maintenance mode and reset the waste ink counter. Info. that is only available to Brother techs.
Posted on Jul 30, 2009
  • 526 Answers
SOURCE: I have a brother DCP-135c printer. the magenta ink not printing
The process to get to the print head will take you approx. 1 hour. Without being trained on it, there is a high failure rate upon completion.
The Scanner assembly needs to be taken off. Harness Cables for the Scanner need to be removed.The Upper Case Assembly needs to be taken off. Printhead casing and printhead tubing calbes need to be removed, printhead mainboard needs to be removed, and then you have access to the printhead.
Thanks
Posted on Dec 19, 2009
  • 164 Answers
SOURCE: My brother printer dcp-165C can't print black
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 08, 2010
Have two Brother DCP-145C printers and use compatible inks. Now the yellow won't print in either machine. Despite trying cleaning cycles and replacing the yellow cartridges, the test print will not show...
100% you need to replace the print head,in the future use only original cartrige brother not refill or compatible cartridge.If you want to replace the print head you need to take care is difficult to change the print head,you must to unzip the all printer.If a have been useful please give me a vote.
Mar 22, 2011 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP-135C won't print yellow
1 years?
Means still under warranty for print head. maybe print head faulty. Better send to Brother.
Jan 27, 2010 | Brother DCP-135C Flatbed Digital MFC...
I have replaced my cartridges because they were low.It now shows they are full but even though i have cleaned as instructed nothing will come from my yellow cartridge and very little from my magenta...
It sounds like the heads are clogged...may be cheaper to get a new unit than to have that unit professionally cleaned; however, if you choose to go that route, remember to go to the ink section first to check the prices of ink cartridges before you buy a printer since once you buy the printer if the ink is high, you are stuck with it. A good sight to use to check on printers is Dealtime. They give you a drop down window to select by price, or most popular...http://www.dealtime.com/xFS?KW=printers&CLT=SCH
Oct 27, 2009 | Brother DCP 115C All-In-One InkJet Printer
Magenta cartridge is empty, how can I print in
You can't.The printer need all cartridges not empty to initialized and printing.You need to replace the empty cartridges to print.
Oct 26, 2009 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP-150C
The Brother machines require all colors in order to print anything, even just black. You can put a small piece of electrical tape over the clear window on the cartridge and the machine will think it's full.
Jul 14, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Help
the colour in the cartridge are either empty or got mixed.so you r not getting proper colours. replace the colour cartridges
thanks.
Nov 05, 2008 | Brother DCP 115C All-In-One InkJet Printer
Red Menace
Try unplugging the printer for about ten to fifteen seconds; then replug.
This may clear the printer's memory about the low magenta. I had a similar thing with yellow, and when I replugged it stopped complaining about the yellow and told me that my cyan was out, and magenta low. I replaced the cyan, and voila! I can print!
Sep 05, 2008 | Brother MFC 420CN All-In-One InkJet...
Brotherdcp-130c printer
Brother DCP-130C is not printing and is refering me to the manual which is useless. It also says "Unit unable 43" .
Any help great! Cheers
Jul 26, 2008 | Brother DCP 130C All-In-One InkJet Printer
Magenta Ink Partial Printing
Try cleaning the contact pads in the print carriage behind the cartridge with the eraser on a pencil. Also clean the ones on the cartridge for good measure.
Jan 18, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother DCP 130C not printing magenta and yellow
after replacing the ink cartridges it took several cleans to come good. I have no idea how to "manually" clean the heads. So I told the printer to do it many (about 7) times. It eventually worked
Aug 11, 2007 | Brother DCP 130C All-In-One InkJet Printer
212 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
