Question about Northstar Generator 13 Hp, 8000 Watt, Trifuel
I have a Northstar 13000 PPG Pro Series generator and the outpupt has dropped to 90V and 180V. How do I get it back up to where it belongs and what does PPG stand for?
  • parisoe1 Nov 17, 2010
    The Northstar people were able to help me. Thanks for the phone number.
5 Suggested Answers
seanpwright
  • 2030 Answers
SOURCE: I have a North Star
Filter is fine showing half full. it will never fill up fully.
The card is your issue....it needs to be taken apart and cleaned with a good carb cleaning solution...one or more of the ports are probably clogged with gum and varnish from the old fuel.
Also check the needle and seat attached to the float make sure they are not sticking.
Posted on Aug 23, 2011
  • 114 Answers
SOURCE: need the manual and instruction to startup / setup
I believe this is it. If so please rate my response and give me a thumbs up!
http://www.northerntool.com/downloads/manuals/165914.pdf
Posted on Aug 25, 2011
kel1guy2002
  • 3740 Answers
SOURCE: I am trying to find
I am just closing this out. Asker has manual.
Kelly
Posted on Aug 29, 2011
  • 61 Answers
SOURCE: how much output can i get from northstar 5500 ppg generator
there are two things in generator out put
one is max out put which is 5500 in your case and another is rated out put which should be about 4500 in your generator Max out put should be used only for a little time say half an hour otherwise generator is suppose to run on rated load or rated out put which is 4.5 kva or 4500watts in your set that also when you are in Ideal conditions means if you are at the sea level if you are above in altitude you can calculate that engine will loose its efficiency at the rate of 3% after every 1000 feet altitude inthat way you can calculate how much rated load you can put on the generator
Posted on Aug 12, 2012
Where can I get a service manual for this product. Or at least a schematic?
Free download on the internet. Search " North Star 8000 PPG owners manual". It is 11 pages long.
Aug 26, 2015 | Northstar Generator 13 Hp, 8000 Watt,...
MOTOR RUNS FINE IT PUTS OUT 110V BUT AFTER 10 MIN 0R MORE WILL DROP DOWN TO 90V
Much will depend on the design of the alternator and how the rotor is energised and/or how the output is controlled. There are various methods including the use of electronics, especially with inverter generators.
As the output drops after 10 minutes it would suggest heat is a factor and that suggests problems with electronics rather than something mechanical (brush gear if fitted) or purely electrical (windings or bearings, etc.).
Certainly it would be wise to check the brush gear, bearings and visual wiring and connections before spending money at the repair shop.
Aug 22, 2015 | Electrical Supplies
Adustments engine speed low rpm
You cannot adjust the voltage output. All generators are rated for 110-125 volt recepticals and usually have at least one 220-240 volt receptical for special appliances that require it such as water heaters, pumps, welders, air conditioners. When one of these higher draw appliances is connected and they begin to draw amperage, the gas engine will automatically increase rpm to produce enough amps. If your generator gauge is showing low voltage such as 60,80 or 90volts for example, then you have overloaded the generator and blown a capacitor, resistor or similar item.
Dec 05, 2013 | Northstar North Star Honda 13hp 8000 Ppg...
How much output can i get from northstar 5500 ppg generator
Jun 30, 2012 | Northstar Generator 9 Hp, 5500 Watt,...
Need the manual and instruction to startup / setup have a northstar 8000 ppg
Aug 25, 2011 | Northstar Generator 13 Hp, 8000 Watt,...
I have a 5500 ppg generator that won't start. I've verified the fuel lines to the engine are delivering fuel, but won't start. I've been able to pour a small amount of fuel down the carb...
Hello, ushicks/me hillybilly. One question how old is the fuel in then generator tank,Hey. If it has a fuel filter replace it. Modern gasoline is junk fuel and after a few months it looses some chemical proprieties. GB...stewbison
Aug 23, 2011 | Northstar Generator 9 Hp, 5500 Watt,...
Northstar Generator 13 Hp, 8000 Watt, Trifuel Logo
750 people viewed this question
Top Northstar Electrical Supplies Experts
John Trevino
Jim London
Jim London
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
