Question about Intel Computers & Internet
Using Ram hi,, i have a 1gb ram and 2 gb ram. can i use it simultaneously in my pc . i mean can i insert both ram to my pci xpress slot? one of my friends said me using multiple rams may crash the system. is it true? please help me..
    Genius:
  • 2,785 Answers
If the frequecy is not same then you will have problem.it is always good to use ram of same capacity and frequency.
Posted on Jun 18, 2008
Ram issues with biostar n68sb-m2s motherboard
To determine if a 1Gb RAM module is faulty insert one RAM module in the motherboard at a time. If the both 1Gb RAM modules work then the RAM modules from different manufacturers are incompatible with each other. Try using RAM modules of the same make and speed.
Jul 09, 2012 | Biostar Computers & Internet
I have a 512 DDR2 (533 FSB) RAM in one of my slot in Intel D102GGC2 Mother board,can i put a 2 GB DDR2 ram in another slot.If yes then What FSB will match and what is the maximum capacity of ram per slot?
This motherboard will support maximum 2 GB of total system memory. so configuration is should be 1GB + 1GB or one 2GB in one slot. If you attempt to install 2GB + 512MB, this is unsupported. but you can try if might the system can read it or not. there is no serious problem for installing memory exceed than maximum system memory...
Memory supported is DDR2 533 Mhz and DDR2 400 MHz...(sometimes on the market DDR2 533 will described as module name PC2-4200 and DDR2 400 as PC2 3200)
Aug 10, 2011 | Intel D102GGC2 Motherboard
RK549AA-ABA SR2170NX problem: i think my second slot for ram is no good. i'm supposed to be able to install 2 gb max . I bought 1gb ram to install in slot # 2 but it doesn't work. can i install...
Is the 1Gb RAM you purchase the same make and speed as the original? If not, they may not be compatible with each other or the new RAM module may be faulty.
Try removing the RAM from slot 1 and insert the new 1Gb RAM module in slot and boot up your laptop to test the new 1GB RAM module.
Installing a single 2Gb RAM module should work.
Dec 29, 2010 | Computers & Internet
Hi Dear ; When I install memory RAM of 1.0GB .. get ERROR
Cant find your motherboard on the support page, is the memory your trying to install the same speed?
Jul 16, 2010 | Intel Computers & Internet
Burned RAM
just remove the 256mb ram it is the main problem only insert equal memmory of rams in 2 slots, if u insert 1gb ram in one slot try to insert also 1gb ram in other slot, donot inser 2 unequal rams in one time
Sep 28, 2009 | Computers & Internet
I have problem about ram
If the manual says this motherboard support up to 1 GB RAM, you cannot put 2 GB. You can put 2x 512 GB RAM or 1GB RAM
Also try to upgrade your bios, maybe a better bios version supports more than 1 GB RAM.
Aug 24, 2009 | AOpen MX36LE-UN (91.89Q10.101) Motherboard
Adding extra ram -Regarding
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
apolpo-1
Jun 04, 2009 | Intel Motherboard
Machine randomly restarts after upgrading RAM
Ok thats the problem.
1 module with 2gb is not possible on this board:
http://www.memoryxxl.net/mainboard::4345_36366/Intel-D102GGC2.html
Intel D102GGC2 Motherboard Mainboard Speicher Technische Beschreibung Intel D102GGC2:
Bus Architecture: - Hersteller Standard Ausrüstung: Non-ECC only, Unbuffered only, Chipset: ATI Radeon XPRESS 200 - vom Geräte Hersteller empfohlener maximaler Arbeitsspeicher: 2048MB - Speicher Upgrade: 2 (2 banks of 1) -Speicher Beschreibung: Jeder Slot kann mit DDR2 PC2-4200, DDR2 PC2-5300, DDR2 PC2-6400 und maximal 1GB Speicher aufgerüstet werden. Eine bessere Performance erziehlt man bei paarweiser Modul Installation. (USB Support: 2.x Compliant, Graphics Support: PCI Express x16) - Speicher Bus Architecture:
You have to use 2 modules with max. 1 gb per module
Dec 30, 2008 | Intel D102GGC2 Motherboard
Ram upgrades
Does'nt matter which goes where as long as they are all compatible with the motherboard.
Mar 18, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
