Question about Neff U1721 Double circotherm Electric Oven
Hello. I am trying to replace the heating element. The third screw is located behind the fan. I have removed the nut but the fan is still fixed and will not release. Should the fan just come off after removing the center nut or is somthing else holding it in place. Thanks
  • Neff Master
  • 3,463 Answers
It should just pull off, try spraying some wd 40 onto the spindle, or apply some heat to the fan to expand it with a blow lamp or hot air dryer.
Posted on Nov 13, 2010
The fan works but no heat. Grill work
You need a new oven element. The oven element is not visible inside the oven as it is located around the fan, behind a safety panel. Its a simple DIY job if you are handy. Isolate oven from power. Look inside oven to rear panel where fan is located and there should be 4 screws holding the safety panel in place to cover the fan, Remove cover and you should be able to see the element which will probably be circular and mounted around the fan. Remove the element and take with you to ensure a correct replacement at your parts dealer.
Jul 03, 2015 | Ovens
Oven will not heat
the bake element has failed. they can be had for around 20 dollars. Unplug unit before
replacing the element. Usually will only need 1/4 inch nut driver to remove two
screws inside oven and slide out element and unplug the spade connectors.
The model and serial should be located behind the lower drawer on the left side.
An appliance parts store should carry this in stock since many models utilize the
same element. Hope this helps.
Sep 25, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
My omega europa oven is not heating up .grill fan
Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
Mar 18, 2010 | Ovens
Am trying to remove the element in my neff u1271n2gb oven but cannot get to the screw that is holding the clip that is attached to the element it is at the top mostly hidden behind the fan no-one seems to...
To undo the nut that secures the fan, unscrew it CLOCKWISE as though you were tightening it, as it is a left hand thread, and vice-versa for tightening it back up.
Please rate my solution.
Thanks.
Nov 17, 2009 | Neff U1721 Double circotherm Electric Oven
We have a hotpoint cooker UY46, our electric tripped the cooker off and , now the nob and grill works but the bottem/main oven is turning on and the fan is circulating but not getting hot ? please help ;(
You need to replace the element. Very easy job remove the back plate from inside the oven (4 screws) and you will see a circular element held in place by one screw in the centre of the fixing plate. Remove the fixing screw then remove two wires and refit new element job done.
Regards Neville
Jul 16, 2009 | Neff U1721 Double circotherm Electric Oven
Replacement of fan oven element on Nef U1721
Hi Steve...yes, these are a pain! Remove the centre fan nut (which is anti-threaded) then lever off the small locating washer underneath. If you are lucky, you will be able to now pull the fan blade off of the motor shaft. However, very often they won't budge!. If you try to knock it off, it is so easy to damage the fan motor (about £80!!). It is possible to leave the top bracket screwed to the oven and unclamp the element from it. I have come across three different typed of clamps so far. One is very easy to do. You can then remove the clamp from the new element and once the element is in place, use the old clamp. It's a fiddle but quite do-able. I have also come across these where the top clamp has been previously removed altogether by engineers on previous repairs! Hope this all helps a little....
Jun 24, 2009 | Neff U1721 Double circotherm Electric Oven
Removing a Fan
It should not be neccessery to remove fan to fit new element, I have never had to do so, but if you need to remove the fan blade, then unscrew the nut clockwise, as though you were tightening it, holding the fan blade as you are undoing the nut
Plz rate my solution.
Thanks.
Jan 25, 2009 | Neff U1421 Double circotherm Electric Oven
Neff fan element
All of this can be done with the oven in situ. Take the back off if you like, but its un-necessary, dirty and time consuming. So here we go: Power off at mains. Remove 4 screws holding plate which guards the fan. You will be faced with the fan partially obscuring the top element retaining screw. At the centre of the fan spindle is a reverse threaded nut. WD40 the nut. Wait a minute or so and using a socket wrench and a flick of the wrist, the reverse thread nut should losen v easily. Having mastered the lock nut, tap the washer and it should become loose enough to remove by hand. If not, it just needs a little gentle persuasion with a flat head screwdriver where it sits on the fan itself. The grime will loosen and it will pop off. Squirt some WD40 onto the fan spindle, and wait a couple of minutes. Ignore any advice to lock onto the threaded spindle because if you damage it, your relatively cheap repair will become pretty expensive. Simply use a locking mole grip on the fan itself where the locking nut sits against it and pull and twist gently away from the spindle. You will be surprised how easy this is. Very little chance of damage. You can then access all 5 element retaining screws. Gently lever out the left foot of the element from the oven housing. Remove the spade connectors from the old element. Reversal of these instructions to fit the new element. Restore mains power. Reset clock or main oven will not work.
image_icon_name.gifSi Boon
image_icon_date.gifSeptember 2008
Jul 13, 2008 | Neff U1721 Double circotherm Electric Oven
REMOVAL OF FAN
Ha - I found the solution myself. You need to remove the 3 screws securing the fan motor. Once you've done this, you can wiggle the fan a few mm, far enough to be able to remove the top element screw.
Jul 09, 2008 | Neff U1721 Double circotherm Electric Oven
Fan oven element - HEEELLLLPPPPP !
one element, but you will need to open the rear of the oven to access and remove the 3 screws holding the fan and with a little bit of push and shoving you will be able to remove the screw behind the fan be careful the screw does not get stuck behind the fan. Putting the new element in will require bending the securing bracket slightly but don't worry it will straighten when you replace the screw behind the fan; which is easier to replace than when you remove it
Apr 18, 2008 | Neff U1721 Double circotherm Electric Oven
Neff U1721 Double circotherm Electric Oven Logo
90 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
