Question about Lexmark X5150 All-In-One InkJet Printer
Printer doesn't print everything on the page - might skip 2 to 5 lines continue for about 10 then skip a portion of the next 4 lines
    Genius:
  • 2,785 Answers
Plz check by reinstalling the drivers and post your findings
Posted on Jun 18, 2008
Show error
E indicates an Error condition.
1.Without turning off the product, disconnect the USB cable from the rear of the product.
NOTE:The USB cable connects to the port on the rear of the product. The port is labeled with the USB icon ( ). If your printer has a network or wireless connection, ignore this step.
Figure 1: Example USB connection (your product might not look exactly the same as this example)
2.Remove the cartridges from the product.
3.Wait until a message to insert the cartridges displays. If you do not see a message within a few minutes, skip to the next step.
NOTE:If your printer does not have a display, wait until the cartridge lights blink. If the cartridge lights do not blink within a few minutes, skip to the next step.
4.Disconnect the power cord from the back of the product.
5.Wait 60 seconds.
6.Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7.Reinsert the cartridges, and then close any open doors on the product.
8.If you receive a prompt to print a calibration page, do so.
9.If you disconnected the USB cable, reconnect it to the rear of the product.
10. Try printing again.
5.Wait 60 seconds.
If that doesn't work you can log on to HP.com/Support and Drivers.
Find your device and search the error codes listed.
You can also download a real good Utility, HP Print and Scan Doctor.
Apr 27, 2012 | HP DeskJet F380 All-In-One Printer
My lexmark X7170 Printer Skip line when printing how do fix it
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
Jan 03, 2012 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Printer keeps skipping lines when printing. very annoying
is this a case of the dots are missing for a valid line, or do you mean a line feed is added at the end of a line, ie you get 3 lines of text occupying 4 lines of space , or 4 lines of text occupies 4 lines of space, but one line has no printed dots on it? to make it more obvious, what does a document with say text thats 3cm tall look like? as it sounds to me like contacts need cleaning.. *** note for info: do not rely on printouts from within a BROWSER as that may have unpredictable results. All text will be treated as a large block of PIXELS and Not TEXT. also Non Printer fonts could cause similar issues.
Nov 09, 2017 | HP Photosmart 2710 All-In-One InkJet...
HP J5780 Problem-Line on printed pages
most likely you have a flat spot on the roller.
that is exactly what is going to happen, when the paper hits the flat spot or a low spot. the paper stops and skips. them the print is coming out smeared.
you can get a repair kit or replacement roller from HP.
Jan 04, 2009 | HP Officejet J5780 All-In-One InkJet...
Printronix P5210 line printer HOF problem
If you are using a printer that has IGP enabled, you can set the printer to automatically go to the next TOF at the end of the print job. Only if you are using the Graphics portion (printing bar codes and graphics). The option is "Auto FF at ^PN" and you would Enable it.
Dec 29, 2008 | Printronix Line Matrix P5210 Printer
Printing problem in xp
You probably need an Epson driver for Widows XP. Win 98 just isn't going to cut it for continuous forms printing.
Aug 12, 2017 | Epson DFX-9000 Dot Matrix Printer
Full ink cartriges print a few lines and skip a few lines
well..did you run a test page?
or clean the print heads?
or recalibrate them?
recommend all these steps for you
and as my 2200th solution, you are entitled to a FREE tuneup for good. find out more about that service here
Mar 23, 2008 | Canon PIXMA iP90 Mobile Printer
Printronix p5005b line skip problem
yeah I ran into this once, set the printer up to ethernet and not auto switching, i think thats what it was.
Dec 10, 2007 | Printronix Line Matrix P5005B Printer
Yellow line
This sounds like there is a scratch in the yellow fuser roller... replace the imaging drum.
Nov 05, 2007 | Dell 5100cn Laser Printer
Lexmark X5150 All-In-One InkJet Printer Logo
140 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
