Question about Dryers
Whirlpool Electronic Gas Dryer
I have a Whirlpool Electronic gas dryer model GGW9250PW0 and it does not dry cloths completly in a cycle. Sometimes takes two cycles. I have cleaned the trap and vent tubes and they are and were very clean. Any ideas?
  • 246 Answers
I would suggest cleaning your moisture sensors. If you stick your head inside the open door and look straight back towards your lint screen, you will see 2 silver bars. These are your moisture sensors. They can get a coating on them over time. Once this occours, the moisture can't reach the sensor and the machine thinks the load is dry and shuts down. Using the abrasive side of a sponge or even some fine grit sand paper, run it back and forth each of them. You should be good to go if you've already cleaned the area underneath the lint screen, made sure the hose from the dryer to the wall is not kinked, folded over or smashed and you have good airflow coming to the outside of the building.
Posted on Jun 19, 2008
Whirlpool gas dryer doesn't dry
Make sure vent hose in back of dryer is not blocked or stopped up.
Mar 16, 2014 | Whirlpool WGD94HEXR Duet Steam Dryer gas
Dryer does not dry clothes completely
If your machine is taking that long to dry. You either have a clogged vent to the outside or your gas valve coils are bad. You can check to see if it is your vent by disconnecting it for one cycle. If the unit drys in time then clean your vent. Click Here to see what a clogged vent can do. Click here to see gas valve coils.
Apr 01, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
What is automatic dry miser
What the automatic dry miser is, is a sensor that measure how dry the clothes are and will adjust the time its going to take to dry the clothes throughout the entire cycle. If at the beginning it estimate it will take 40 minutes to sry a load but they are dry in only 25 minutes the dryer knows the clothes are dry and cuts the dryer off. Saving 15 minutes of unneeded gas and electric that it would run and waste power and gas since the clothes were dry already.
GENE
Aug 18, 2011 | Whirlpool GGW9868K Gas Dryer
Clothes not drying completely; takes about 5 cycles to get them dry. Was previously drying completely with one cycle. I believe I need a new heating element and would like assistance on getting...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 20, 2011 | Whirlpool Dryers
Kenmore Gas Clothes Dryer does not heat sufficiently
Ok, first and foremost, make sure your vent is clean and clear.
If the vent is clean and free of obstructions the most likely culprit is your gas valve coils. When they fail the typical symptom is heat at the beginning of the cycle and no heat about 20 minutes later.
If you can, post the complete model number from the dryer and I will give you step by step tear-down and replacement of parts instructions.
Jun 27, 2010 | Kenmore 63942 Dryer
GE DBSR453GB Gas Dryer doesn't dry on 1st cycle.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 30, 2010 | GE DBSR453GB Gas Dryer
Dryer is slow dryng takes two cycles compared to regular dryer
As the model number you provided indicates this is a gas dryer, you need to open up the access panel, above the washer compartment, to clean out the dryer compartment.
It is likely that either the gas burner components have been covered in lint and dust and are getting shut off sooner than they should because of overheating of the thermocouple safety device, etc.
First, make sure that the power is turned off to the washer/dryer unit and turn off the gas supply valve, so you don't have any issues with getting a electric shock or getting a gas leak/build up.
Once you've done that, you can remove the two (2) access screws that will let you get into the lower dryer compartment where the gas burner and control devices are located (this is the panel just above the washer lid, the angled section).
Now vaccum out all the lint and dust buildup you can see and check that everything is free of dust and lint inside this area. Pay special attention to the gas burner and gas inlet orifices, as anything in there can and will cause the dryer to shut off and thus, not operate properly in getting your clothes dry in a normal drying cycle.
Also, check to see that the dryness sensors inside the dryer drum (silver bars up near the top left or right of the dryer drum) are clean and don't have any residue or buildup on them. This can also cause the dryer to register erraticly when using the automatic drying cycles versus the timed drying cycle. Use a good glass cleaner and wipe these sensors with a clean cloth rubbing them briskly to remove any residue or contaminent that might be deposited on the sensors.
Now completely clean out the exhaust vent all the way from the dryer to the outside location of the vent. Having any blockage of the vent can and will cause the thermal overload protective device to function and turn off the gas burner that provides the heat to dry your clothes. So be absolutely certain that the entire vent exhaust is clean and free of any lint buildup from the dryer all the way to the outside vent (yes I mean't to repeat that!) You'll have to remove the outside vent grate/cover to check for any buildup/obstructions there.
Now you can run a load to see if you've gotten the problem solved, if not, it could be a control module, but 80% of the time, it is nothing more than a "housekeeping" issue that causes loads not to completely dry on the first cycle. So please do some cleaning and checking and you should be back getting your clothes dry on the first cycle!
Hope you find this Very Helpful and best regards!
Oct 20, 2009 | Whirlpool WGT3300SQ Dryer
I have a gas Whirlpool Duet dryer and sometimes the cycle wont complete and the clothes arent dry ( very damp). when i use the timed dry option i ave the same result. last week my washer overflowed and i...
Check your exit vent outside of your house... what you can do is remove vent hose on back of your dryer... run dryer and feel the air coming out of the vent right behind your dryer.. now reinstall your vent line and check outside,,, see if you feel the same or about the same air flow... if your air flow is block, then your heat will not come on regularly to dry clothes... good luck
Jan 19, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
250 people viewed this question
Top Dryers Experts
