Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
2 of the lights just under on off switch(2 to the left) . were it says quantity ythere is a E symbol showing,nothing happens when you connest camera either.
  • Kodak Master
  • 3,267 Answers
You need to reset your printer. Google search for "indoreset for r230", that is the program that you can use to reset your printer. Or you can use the SSC Service Utility, just search for it in the net. You particularly need to reset the waste ink pad counter.
After you reset your printer, check the back of your r230, you will see there a small access cover with a screw. Unscrew it. Take a look inside and you will see a tube connected to the waste ink tank, try to disconnect it from the waste ink tank, carefully pulling it out the access window. Do not force it out completely, you will be able to pull out only about an inch of the tube. When the tube is out, get another tube (silicon or plastic) around 6 inches long would do (12 inches will be fine)that would fit in that tube you've just pulled out, then get an empty plastic bottle with a cover, puncture a hole in the cover and put the other end of the tube in that hole, that plastic bottle will be your new waste ink tank. You are doing all these so you wouldn't have to dismantle your printer to remove and replace the waste ink pads inside your printer.
After doing all these you can now use your printer again. You just need to empty the plastic bottle regularly. And when the time comes to reset your printer again, just use the program again and that's it.
Posted on Nov 13, 2010
HD Nook wont light up could it the LCD or power switch?
my nook tablet shows the green light that it's fully charged but when trying to turn it on nothing happens the screen does not com on or the nook symbol does not light up . can any one help me out here
Sep 28, 2013 | Nook HD+
My acer is not coming on ,there is power going into my lap top but the screen is completly blank?
Bring your laptop under sunlight. If you look very closely and can see your screen then your backlight went out. Otherwise there might be a loose/broken connection to your lcd.
Jul 03, 2012 | Acer Aspire 5535-5050 Notebook
How to switch on flash on my praktica slimpix 5200
On the 5240 similar model you press the right hand navigation button on the back of the camera. It has a flash symbol engraved on it but not very clear on mine. The screen goes blank as if nothing happens but it is charging the flash and with fresh batteries will come back in 5sec or so. Then when you shoot it will flash, and there will be a flash symbol showing on the screen.....Press again to alter to fixed rather than auto flash, and again to turn off.
Sep 17, 2010 | Praktica SlimPix Digital Camera
I have had my phone for nearly 2 yrs n have never had any probs on fri eve my battery was dead so i charged it n all was fine battery normally lasts 3 days ish. saturday morning the battery was showing...
Two years is what you can expect from many cell batteries, though I dont have any direct experience with this make.
I think if you replace the battery, your troubles will go away.
Oct 31, 2009 | Sony Ericsson K770i Purple 3G Camera...
Keep copier ready; disable powersave option
This is going to be a user program:
1) press and hold both light and dark keys
a) the 2 buttons to lighten and darken copies
b) hold both for 5 sec until indicators light up
2) use the left copy quantity key show 2
3) press your copy key
4) use the right quantity key to change to 2 (max 90 sec)
5) press the copy key
repeat step 2 but change to 3 with left quantity key
press the copy key
change right number to (4 = 60 min, 1 is default at 5 min) then press your copy key.
Once done press both light and dark key again to exit
Note*** changing shut off timer and preheat will effect copy lamp ready state. Every 60 sec or so the scanner will move and reset. Some people do not like the noise is makes all the time. If you don't you can always change it back to the defaults. 2=0 and 3=1.
Oct 12, 2009 | Sharp AL 1631 Copier
Inserting symbols into my xcel worksheets
Try reinstalling the software and see if that helps..
Oct 03, 2008 | Computers & Internet
Nokia 6280
I have a nokia 6280. My camera only randomly works now. There is a little symbol of a blue and white chequered flag and also a little camera symbol next to it, plus an empty bar, rather like a thermometer but with nothing written in it that has a - on the left and a + on the right. In addition, there is a number in the corner either placed top left or bottom left of the screen, depending on whether the screen is on portrait or landscape. When the status informs me that the camera has failed and is now on standby, there is a strike (forward slash) line running through the camera icon. This has only just started happening. The battery is full. Any ideas please?
May 19, 2008 | Cell Phones
Please send a solution asap
I have no idea what the symbol is.
I suggest that you check that your memory stick is not locked, not full and is inserted properly into the camera.
Reset the camera (button under the connector flap, below the zoom buttons on the back of the camera)
Dec 14, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
191 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
