Question about Canon PIXMA MP130 All-In-One InkJet Printer
How to load a MP130 cartridge? - Canon PIXMA MP130 All-In-One InkJet Printer
    President:
  • 1,216 Answers
  • 1 Turn on the printer and check the LCD screen for an indication of which ink cartridges are low. Note that recycled ink cartridges sometimes read "Ink low" even when they still have ink, so print a test page if you're not sure.
  • 2 Expose the ink tray by lifting the entire LCD control panel, which is attached to the underside of the copier tray.
  • 3 Pull out the used ink cartridge by pulling straight up from the print head,
  • 4, insert the new cartridge into the print head and push down until you feel a click. Close the printer lid and let the printer reset the ink tray.
  • 5 Print a test page to make sure the new ink works. If it doesn't, you may have forgotten to remove the protective tab under the cartridge.
  • Posted on Nov 13, 2010
    • Canon Master
    • 3,267 Answers
    Select the ink cartridge specific to your printer. Canon inks are versatile, so your selection may be as simple as choosing between black, color or a multi-pack with black and color cartridges.
    Step 2
    Turn on your Canon printer. The switch is generally located on the top right hand side of the printer. Open the printer's lid.
    Step 3
    Wait a moment. The cartridge carrier will automatically disengage.
    Step 4
    Put your hand behind the existing ink cartridge and pull the cartridge towards you until it pops out. Dispose of or recycle the used cartridge.
    Step 5
    Carefully pull the tape off the new cartridge.
    Step 6
    Position the new cartridge into the cartridge carrier. Make sure it is facing the correct position.
    Step 7
    Press the cartridge carrier gently until it clicks into place. Some cartridges have indicators to demonstrate that they are properly positioned.
    Step 8
    Close the printer's lid. Print a test page to ensure everything is working properly.
    Canon pixma mp130 service error 5100 - won't print
    Turn off printer.
    Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
    Return the cartridges and turn on the printer.
    Error 5100 means that the cartridge can not be detected by the printer.
    Hope it helps!
    Dec 17, 2010 | Canon PIXMA MP130 All-In-One InkJet...
    Changed black in tank. Says load cartridge. Did
    Double check to make sure that you have seated the ink into the head correctly and that the printhead is locked in correctly. Sounds like the printhead isn't in properly and the printer can't read the inks as it normally does.
    Jan 10, 2010 | Canon PIXMA MP130 All-In-One InkJet...
    I have a canon pixma mp130 and it keeps saying cart. jammed
    Press menu to maintenance.....go to cleaning roller....repeat cleaning 3 times....return to copying...hope this helps
    Aug 04, 2009 | Canon PIXMA MP130 All-In-One InkJet...
    My mp130 does not print and says put in cartridge
    call a technical support to fix your printer... its a mechanical or board problem inside...
    Jun 17, 2009 | Canon PIXMA MP130 All-In-One InkJet...
    I changed ink my printer showing wrong cartridge
    Make sure you are using factory new Canon ink cartridges.
    If you purchased re-filled cartridges or third party cartridges that is most likely your problem.
    Don
    Jun 14, 2009 | Canon PIXMA MP130 All-In-One InkJet...
    Cartridge jamb Pixma MP130
    i always go into the clean the printer and it works, usually. I have also tried the align printer head, it has worked at least once.
    Aug 28, 2008 | Canon PIXMA MP130 All-In-One InkJet...
    Canon pixma MP130 is not working
    The cartridge seem to be jammed at the extreme right end of my machine. Pulled the ribbon to bring the cartridge slots to the centre. Then removed the cartridges. Unplug the power behind. After a minute, plug back the power. Load back the cartridges. Printer resumes back to working mode.
    Jun 03, 2008 | Canon PIXMA MP130 All-In-One InkJet...
    Canon PIXMA MP130 All-In-One InkJet Printer Logo
    96 people viewed this question
    old marine
    old marine
