Question about Sport & Outdoor - Others
Blue ridge spa - error message P51 & FC - no heat & no re-circulation - can't read model or serial #'s - only #'s available are 677-70-81576 / 76075 / 377284 - located in pickwick dam tn area - need service?
co7196
  • 3433 Answers
SOURCE: Jandy pool heater model #LT400N-L service and ES1 light blinking
The heater won't fire up if there is no or inadequate water flow. Ck water pump and filters.
Posted on Jun 01, 2009
  • 80 Answers
SOURCE: need wire schematics -circuit panel box & heat element ARIES SPA
Did you check inside the cover of the control box. Most spa's have a schematic of their components there. Hope it is there.
Posted on Aug 19, 2009
yboyandrei
  • 828 Answers
SOURCE: Error message 5C10, won't print. Need locations
I think there was a broken pieces of hardware in the print carriage.
According to the Canon Center this one cannot be fixed. If your printer is under warranty, send it to them.
Read also this online user's guide for your machine.
www.yboyandrei.com/MP830_Err5C10
Please rate me if i am helpful to you.
Posted on Oct 05, 2009
  • 969 Answers
SOURCE: Instruction & manual for service
TRYhttp://www.applianceaid.com/fault_codes.html
Posted on Nov 12, 2009
  • 760 Answers
SOURCE: ao error message in Hayward heaters
You didn't indicate exatctly which model you have. But on most the AO error code is :Blower vacuum switch
open error If the blower prover switch does not close after the blower starts the control will
stop the ignition trial go into lockout. The blower will continue to run. Automatic reset is immediate after the switch closes.Check to be sure combustion blower starts
If you don't have your manual you can download one for your exact model at : www.haywardnet.com
Posted on Jul 29, 2010
Can you help me figure out why my spa stopped heating?
Without more diagnostic info or what you may have done in your troubleshoot, or what is or isn't happening...
Try cleaning your filter!
Most common reason a spa stops heating!
May 16, 2015 | Optimus Vertical Heater, Gatsby/blue...
I have a new spa and he says an error E98 by other models it means water to hot but my water is just 13 degrees Celsius how can i fix it ?
that often happens when there is a reduced flow of water. it heats up too fast and cannot circulate to the spa causing it to overheat when the spa is in reality not hot
Apr 26, 2015 | Pool & Spa
Over heating spa
Are Jets staying on HIGH?
Are your controls mechanical or digital?
Exact Information of the spa control system, not the spa manufacturer, will help us to help you. The box below with all the wires coming in & out. Name, model, code & serial #'s will help.
When jets stay on & don't turn off, water will heat up just by circulation causing "Friction".
If mechanical, your thermostat may have failed. If digital, your temperature sensor may have failed.
Dirty filter can cause this as well, if your flow sensor is failing.
Nov 17, 2013 | Belize Spas Belize e480L Lounger Spa -...
Over heatings
Over heating?
Is water actually getting too hot?
or are you just getting an "Overheat" error message?
if water is too hot, your temperature sensor/thermostat is bad.
if water is not hot & you have an overheat error message, you could have a bad temperature sensor or you if you have a circulation pump (constant duty) that could be bad.
good luck
Jacuzzi 470 Model has '- - - - ' problem code on display.
This is called a watchdog. A number of situations can cause this situation. Check your "Sensor Plug", ensure good tight connection. Air locks not necessarily the problem, but if in the "Circulation" pump, it may. Your Circ pump may have unfortunately failed. Can you tell if it is actually pumping a good amount of water through its return fitting? If not, then either an air lock or it failed.
Dec 27, 2012 | Pool & Spa
OH error QCA spa High jets work and heat
OH is the overheat code.
Your spa temperature is set above 108, or your thermostat is faulty & not reading correctly.
Jan 23, 2012 | Qca Spas Jewel Series Topaz Plus Hot Tub
Hi have problem with canadian spa (balboa mrspa1) control panel digital reading when turned on goes to OH,circulation pump will not run
OHS, OH, or SPA TEMP LMT Message There is an "Over Heated Spa" (OHS or OH) Water Condition.
One of the Water Temp Sensors has detected 110°F (43.3°C) Incoming Water Temp and Spa Functions are Disabled. System will Auto Reset when Water Temp is below 108°F (42.2°C). Check for Extended Pump Operation or High Ambient Temp, or contact your Dealer or Service Organization.
Spa Water Cool Down
• In order for the Spa Water Overheat Error Message to Automatically Reset and Clear, the Spa Water Must Cool to below 108°F (42.2°C).
• Check the Topside Panel Display to see if the "OHS", "OH", or "SPA TEMP LMT" Spa Water Overheat Error Message has Cleared. If the Error Message has Not Cleared, the Spa Water is still too Hot to Continue Testing.
• Either Wait for the Spa Water to Cool Below 108°F (42.2°C), or Exit Now and Retest at a Later time.
You can find answers to COMMON SPA MESSAGES at the following website:
COMMON SPA PANEL MESSAGES
Hope this helps.
Mar 30, 2011 | Balboa Instruments Duplex Digital Panel 2...
Spa n a box 6 person portable hot tub pump cl250-c pump stops working error message OH on display
If the water pump is not circulating water you will want to do a simple procedure called "turning the impeller" You can call 888-997-6366 to be walked through this procedure over the phone.
Feb 26, 2011 | Comfort Line Spa 2 Go Portable Spa with...
Need wire schematics -circuit panel box & heat element ARIES SPA
May 11, 2009 | Home
Sport & Outdoor - Others Logo
325 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
