Question about Briggs & Stratton 190cc 875 Series OHV Walk Behind Lawn Mower Engine 25mm x 3532Inch Length Crankshaft 12S5020025B1
Brand new B&S series 550. 2nd time trying to start, runs for 5 seconds and stops. Pumping the primer will keep it running for 5 seconds at a time. First use, 4 weeks earlier, ran like a dream! What is the problem?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 338 Answers
Water will cause problems like this. Ethanol in the fuel causes the water in the air to pool in the tank. 2011 engines will be equipped with a better orfice that will not corrode from the water. You might contact a local dealer like www.arcolawn.com and get the updated tube.
good luck
Posted on Mar 01, 2011
Craftsman gas pressure model#580-752220 willnot stay running. Only after you push the primer 10-20 times it will start &run for 5-10sec..It will run if you pour gas in carburetor.If you quit with the...
Sounds like the idle jet in the carb is plugged up.
It only stays running from the primer load, then dies when that is used up, as the gas can not get from the float bowl through the idle jet.
Did you store it for a while with the gas still in it?
If so, what happens is the gas starts to go bad, and over time it can get almost like a varnish.
When this happens, it starts plugging up the small ports in the carb, starting with the smallest, which is the idle jet.
Before storing for any length of time, your best bet is to drain the gas and run the float bowl dry.
If not that, at least add some fuel stabilizer to the gas left in it, and run it for about 5 minutes with the stabilizer in the fuel.
May 31, 2014 | Cars & Trucks
Not pumping enough water
Sounds like you have an air leak in the pump inlet. If it has worked in the past the pump is designed to lift the 12 Psi required. The other problem might be a plugged inlet line. When you remove it look at the actual pump inlet for some blockage.
Nov 08, 2013 | Honda Engines GX200 Series General Purpose...
I have a 345 e Series 18" (I think it's 18). It's a couple of years old and probably no more than 3-5 total hours usage. Normally starts and runs perfect. Today it won't run, seems to be starving for gas....
If stale fuel has been left in the saw then try draining the tank and re filling with fresh fuel, also hook the fuel line out of the fuel tank and replace the filter on the end.
Apr 15, 2017 | Husqvarna 18" 502cc Prosumer Chain Saw ...
Edger will not stay running
Your diagfram is bad replace it in your carb and you will be ok
Apr 12, 2010 | Yard Machines Red Edger
Have polan md 1950 14'' changed fuel primer pump and lines plus gas line. now it only runs for short time and stops. only runs as long as I keep pumping primer
Sounds like the diagphram pump in the carb might be stuck, been dried out or has a hole in it. Im not to certian what carb is on it but some have a line that runs from the carb to the crank case might check for that.
Nov 29, 2009 | Garden
Lawn mower starts and stops right away
take bowl off bottom of carb....clean and reassemble
Nov 16, 2009 | Garden
My homelite tiller stalls after 30-60 seconds of running. i changed plug and checked filter. gas is new
I'm assuming a 2-stroke engine. Does the fuel system have a primer button? Assuming that the answer is yes, the carburetor is not pumping fuel, but starting on the primer charge. Is the carburetor a Walbro brand? If so, got to: http://www.drystacked.com for a 12 page PDF on theory and repair of these carburetors. If the primer works, the main fuel line should be ok.
Sep 17, 2009 | Garden
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Briggs & Stratton 190cc 875 Series OHV Walk Behind Lawn Mower Engine 25mm x 3532Inch Length Crankshaft 12S5020025B1 Logo
184 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
