Question about Car Audio & Video
Cant put the code in my cdr 2005 vdo all it does is say 5 safe no bleeps and other buttons dont seem to do anything.tried lots of ways on internet,but nothing happens just says 5 safe,can you help. kind regards MR t.grace
SOURCE: Safe mode. Need to know where i can download code
Just had the same problem. Removing the radio is first problem - you need a special kit which you can buy from halfords, or get friendly mechanic to do it for you. Then get your Code by inputting serial number (written on metal of radio NOT label) into one of the websites (I got mine from IRC UK) but you will probably have to pay for this. When you have the code do this: 1. switch radio off (with keys in ignition) so date and time are showing. 2. Hold down main volume/on/off button at same time as holding AS button for about 5 secs. 3. Insert your Code by pressing button 1 for first number (ie if first number is 6 you need to press button 1 six times), button 2 for second number, etc. 4. when you have inserted all 4 number of the code you got from the website/garage hold down the AS button on its own.
This worked for me!
Posted on Jul 17, 2009
  • 4930 Answers
SOURCE: NEED CODE FOR VDO CDR 2005
Unfortunately codes for the majority of  SIEMENS/VDO/DELCO radios (including your CDR2005) are not available for free from anywhere on the Internet.
Only available from your Main Dealer or a Decoding Service
Posted on Dec 05, 2009
aymantn
  • 109 Answers
SOURCE: siemens cdr 2005 vdo code problems
Just see hear :
http://car-radio-unlock.blogspot.com/2009/12/code-calculator-for-renault-radios.html
Posted on Mar 17, 2010
  • 4930 Answers
SOURCE: code for car radio vauxhall vectra radio cdr 2005
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Unfortunately the majority of SIEMENS/VDO codes (including your CDR2005) will NOT be available for free (or cheap) from anywhere on the Internet as access is required to the original factory database…which is not commercially available..
Try your Main Dealer or a Decoding Service or your local Car Radio / Audio Shop (who are normally the cheapest option) who will connect it to a laptop to read/recode the memory chip (EEPROM)
Posted on May 01, 2010
SOURCE: cd stuck in siemens vdo
I have exactly the same problem. I also had my unit taken out, but couldn't find emergency hole.
Posted on Jun 12, 2010
Hi ive got a 2003 vectra sri 2.2 ,4th owner, ive just swapped the battery and no ive got the stero in safe mode .i dont have the code ;( . its a cdr 2005 vdo . can you help , thanks
Unfortunately CDR2005 codes are only available from your Main Vauxhall dealer or a Radio Decoding Service as access is required to the original factory database which is not commercially available....Sorry
Feb 24, 2011 | Car Audio & Video
VAUXHALL RADIO CDR 2005-VDO. DO NOT KNOW THE MAKE
The CDR2005 is made by SIEMENS/VDO and unfortunately the code cannot be calculated using any program (from Ebay and elsewhere) as it has to be looked up on the original Vauxhall database which is only available at a main Vauxhall Dealer
The alternative is to take it into a Radio Decoding Service who will open it up and wire it into a laptop to read the memory chip (EEPROM) using special dump reading sofware.
Sorry
Jan 16, 2011 | Car Audio & Video
Require a user manual for in-car siemens vdo cdr 2005
i need a code foe cdr 2005 siemens vdo it is on safe mode
and i have not passcode for the car
which has all the codes
Sep 13, 2010 | Car Audio & Video
How do you enter the radio code, for a siemens vdo cdr 500. please can you advise
Vauxhall Delco CDR 500 Code Entry
Press and hold the [ AS ] key and switch on.
'SAFE' will display followed by '10 - - - - '
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ AS ] key to accept
Sep 01, 2010 | Car Audio & Video
Opel factory fitted radio codes i have a siemens cdr 2005 the serial number on the side is GM020543462810 i need the safe code but it is stuck saying 7 safe and wont let me enter another code
Unfortunately the majority of SIEMENS/VDO codes (including your CDR 2005 )  will  NOT  be available for free (or cheap)  from anywhere on the Internet as access is required to the original factory database…which is not commercially available..
To reset from 7SAFE  then LEAVE SWITCHED ON ....UNDISTURBED for as long as it takes to automatically reset itself (usually an hour or two)
Dec 07, 2009 | Car Audio & Video
NEED CODE FOR VDO CDR 2005 SERIEL NUMBER GM020532487959
Dec 04, 2009 | Car Audio & Video
VECTRA CDR 2005 (E)
Your radio is made be SIEMENS/VDO and nfortunately the majority of SIEMENS/VDO codes (including yours) will NOT be available for free (or cheap) from anywhere on the Internet as access is required to the original factory database…which is not commercially available..
Try your Main Dealer or a Decoding Service or your local Car Radio / Audio Shop (who are normally the cheapest option) who will connect it to a laptop to electronically read/recode the memory chip (EEPROM)
Sep 20, 2009 | Car Audio & Video
Code siemens vdo cdr2005 sn:13 122 932
i have lost my code due to battery going flat siemens vdo cdr 2005
Mar 21, 2009 | Car Audio & Video
Car Audio & Video Logo
77 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
