Question about Bosch 52318 18 Volt Jigsaw Jig Saw Tool
Bosch pst 58pe , how do you change the blade - Bosch 52318 18 Volt Jigsaw Jig Saw Tool
  • 548 Answers
SOURCE: bought a jigsaw a bosch pst 54e how do i change
In the handle directly over the blade is a deep hole. You insert a long thin bladed screw driver into this hole all the way down. Twist slowly and it will locate with a screw. Undo the screw and then twist the remaining piece of blade 90 deg and pull. Replace new blade in the opposite way. Twist it so that the cut is to the front and then tighten up the screw. Do not tip up the unit while doing this as the screw might drop out and you might loose it
Posted on Sep 24, 2009
Testimonial: "thanks.did the trick.use you again thanks"
FixYaSteve
  • 57 Answers
SOURCE: How do I change the blade on a Bosch pst 54E Jig
There's an exploded diagram of a similar model here. Don't let it confuse you though. I mention it, because it shows the clamp screw which hold the blade in place (35 on the diagram).
Unplug the saw before you change the blade.
In the handle directly over the blade there is a hole with a clamp screw at the bottom. Use a long thin blade screw driver to loosen the clamp screw.
Once the clamp screw is loosened, twist the blade about 90 deg and you should be able to pull it out (don't cut yourself, by accident)
Put the new blade in with the same orientation and twist so the blades are facing the front of the saw.
Tighten up the clamp screw and you're good to go.
Be careful not to tip your saw over while the screw is loose. If it falls out and you lose it they're a bit of a nuisance to come by.
Posted on Jun 14, 2010
SOURCE: Changing the blade in a bosch pst 65 pae corded jigsaw
Pull up the knob on the front at the top of the machine and push the yellow bit forward. Theoretically you should turn the knob anticlockwise three turns but it doesn't seem to make any difference on my one. Then take hold of the blade, ease it forward and turn through 90 degrees. You should then be able to pull it out. Replacement is, as they say in all the best manuals, a simple reversal of the procedure. When you are turning the knob clockwise this time it's supposed to click in place but my one doesn't do this and still seems to work.
Best of luck
Gavin
Posted on Apr 10, 2009
rowdy45176
  • 2176 Answers
SOURCE: WANT TO FIND PARTS LIST FOR BOSCH PST 54 PE JIGSAW
you can trying going to Boschtools.com and you will need the exact model number, the parts list section is on the left hand side of the page towards the bottom.
Posted on Jan 28, 2010
al_kupchella
  • 843 Answers
SOURCE: how do I change the blades on a Bosch PST 2000
I couldn't find that specific model number Bosch saw, but here is the link to get user manuals from Bosch in case you mistyped it. (It's a long link that wouldn't all fit here, so I had to put a carriage return in it)
http://www.boschtools.com/Service/ProductServices/Pages/ManualsandPartsDefault.aspx
Or they may have a similar saw under a new model number. Here's the current model number of a very popular saw that has a less-than-obvious blade changing method 1587avsk
Posted on Mar 05, 2010
A bosch PST 54PE jigsaw...the blade falls out when in use
If it works like mine, you need a long, thin screw driver (flat) to tighten a screw that holds the blade. The screwdriver goes in, in line with the blade, on the opposite side.
Jun 12, 2017 | Bosch Saws
How do i change a blade for my jigsaw pst 50a
there should be a allen head bolt in a slot at the top of the blade. you loosen it and pull out blade , replace blade and tighten bolt back up. hope this helps. have a good day,
Jan 08, 2011 | Bosch 24V Jig Saw W/ 2.4 A H Battery...
How do i fit a blade on a bosch pst 52a
Saw for PST 52A: You need a screwdriver for at least 15 cm. long by 4 mm. in diameter. Insert it through the hole on the opposite side of the saw, loosen and release the saw, it is necessary to rotate a quarter turn to remove. Do the reverse for mounting the saw.
Apr 13, 2010 | Audiovox Bosch 718 World Cellular Phone
How do I change the blades on a Bosch PST 2000 jigsaw
Mar 05, 2010 | Bosch Saws
Bought a jigsaw a bosch pst 54e how do i change the blade.thanks
Sep 24, 2009 | Bosch Saws
Bosch 52318 18 Volt Jigsaw Jig Saw Tool Logo
1,044 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
