Question about Epson Stylus Photo 1290 InkJet Printer
Epson 1290- three years old .Printer -with all correct settings applied-prints only part of the picture in both A3 and A4. Have used this printer extensively with no problem before. Have tried by rechecking all setings which are correct and preview shows it will print ALL the pic
  • 428 Answers
What you could do is uninstall the printer, shut down the PC. Reboot the system, reinstall the printer and try to print again. Since you say you have checked all settings this should correct any coding responsible for the behaviour.
Good luck & God bless!
Posted on Nov 13, 2010
Testimonial: "Thanks experts. It worked. Kind regards Martin Henfield"
Hi my new printer wont print a3 in the print section on my computer options it only gives a4 and smaller ? any help would be great
first, please understand, I don't happen to have your printer in front of me. The specifications on it say it does a3 paper, so I imagine it does. Things I would check:
1. Do you have a3 paper loaded?
2. Did you try changing the setting for paper tray to the one that has the a3 in it?
3. Do you have the current Epson driver installed in your computer, or are you using one that the OS (Windows?) might have installed when it noticed the printer? If you haven't installed the printer software, you may need to do that.
Dec 16, 2015 | Epson WF-7620DTWF - 18 ppm/10ppm
How do I get a Blow up (say 150%) PDF snapshot view of an image to print from A3 not A4 print tray
Hi Paul,
I would try and insert the PDF as an image to Powerpoint, crop the image to your desired proportions, scale it up to your preference, then print the Powerpoint slide on A3. Alternately, print the slide to PDF, then print.
Good luck
Feb 22, 2015 | Office Equipment & Supplies
A3 prints - printing on A4 - Ricoh C4500. When users print to our Ricoh C4500 using RPCS the print comes out as a cut off A4 print, so it does not seem to be detecting the fact that it is needing to use...
Enter on the computer the follow path:
1. enter start menu
2. enter printers and faxes
3. enter by right click into properties
4. enter paper size settings
5. set the paper size for the tray or trays and press update then apply and ok
after thet it will work
Also see on the printer menu enter the same paper tray settings and set the trays by size but more important is to set the compute settings
Jul 08, 2009 | Ricoh Aficio SP C410DN Laser Printer
Too expensive to run this printer
yes the inks are very expensive, but you can have a stratégie to reduce costs. make small tests before print an A4 or A3 picture. use a calibrating device to take off the color distorsion (if not, you will have alway the same cardridge empty first, usually red or blue). be carefull of the paper type, mat or glossy, they don't need the same ink quantity (specify it in the driver).
with a color calibration, you can also use generic inks, saving 50 to 70%.
However, the r1800 is a professionnal printer and the prints costs 2 to 5$...like professionnal prints!
Jan 20, 2009 | Epson Stylus Photo R1800 InkJet Printer
My Epson 1290 only prints half a page
Hello I am use in 1290 printe in epson problem in hafe page print and red led on and printing in hang pl.. uragent in
Thanxx.
Rawat
Nov 10, 2008 | Epson Stylus Photo 1290 InkJet Printer
Epson 1290 Printer
Yepperz... Here is your fix
1. Click on START, CONTROL PANEL, PRINTERS AND FAXES (or PRINTERS AND OTHER HARDWARE).
2. Right click your printer, and select PROPERTIES. (If your printer is not listed, click on VIEW INSTALLED PRINTERS first).
3. Select the ADVANCED tab.
4. Select PRINT DIRECTLY TO THE PRINTER.
5. Click on APPLY (if applicable), then OK.
6. Restart your computer.
7. Try printing now.
Aug 21, 2008 | Epson Stylus Photo 1290 InkJet Printer
A3 print problem
i would adjust the margins they are probably set at 0.75 take it down to 0.50 and maybe that will help a bit you can lower it more as well but see if it helps or if a option to fit to page is in your options do that.
you can also clean the print head.
Aug 05, 2008 | Epson Stylus Photo 1280 InkJet Printer
Printer problem
From the Printers & Faxes window, check in the i9950 Printing Preferences, Page Setup tab, for the following settings:
Page Size and Printer Paper Size are both set for the same size (both A4 or both A3).
Printing Type is set for Normal-size Printing
The graphic on the left should now show A4 (or A3) and Normal-size Printing in the legend.
Once that is set, verify from the application you're printing from that these settings are not being changed by the application (Preferences button in the print dialog box).
Jun 16, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Paper size
The problem is with the printer side. there is option in the printer, Set manualy paper size from the printer paper tray. I think this will help you.Goodluck.
Mar 10, 2008 | HP LaserJet 5550DN/EN Printer
R1800 Borderless Printing Problem
Hi Tom, Have you downloaded the latest driver from the Epson web site. Also make sure the output tray is in the correct position and that you are using the correct paper. You can use the following media with this feature: Matte Paper - Heavyweight A3+, A3, A4 Premium Glossy Photo Paper A3+, A3, A4, 10 x 15 cm (4 x 6 in.), 329 mm x 10 m, 210 mm x 10 m (Roll paper) Premium Semigloss Photo Paper A3+, A3, A4, 329 mm x 10 m, 210 mm x 10 m, 100 mm x 8 m (Roll paper) Archival Matte Paper A3+, A3, A4 Watercolor Paper-Radiant White A3+ Velvet Fine Art Paper A3+ Ensure the output tray is in the correct position as if the tray is too low and the paper "falls" down into the tray the weight of the paper could pull the last few millimeters of paper out of the exit rollers, causing the band.
Aug 15, 2007 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo 1290 InkJet Printer Logo
213 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
