Question about GE DVL223EBWW Electric Dryer
What year and wattage is my GE electric dryer model number 572D561
SOURCE: How to open the dryer and replace the belt
all dryers open from the top so open the dryer door and look inside the top edge you will see two screws . remove the screws and lift the top panel . the front panel has two screws on the top one on the left and one on the right remove them both and lift up the front panel to remove it. the only way you can install the new belt is removeing the front panel because the belt goes around the drum from the front. once you remove the old belt out put the new one in . the belt goes around the drum from the front and then to the motor and idle roller . you can reach the idle roller from the front left corner or from the back of the dyer? i like to install them from the back cause its more easy. in the back of the dyer where the hose goes connected to the blower is the top with four screws remove the hose from the blower tube and remove the four screws. after you remove everything you should be able to see the dryer motor and idle rooler put the belt over the motor first then over the idle rooler .always make sure when you do this the dyer is unpluged and after your done plug it back and turn it on to make sure it runs correctly . if it runs ok put everything back together again.
Posted on Jan 11, 2008
  • 178 Answers
SOURCE: HOW TO FIX A NO HEAT ON A GE ELECTRIC DRYER OVER 10 YEAR OLD
Either one of 2 ways to get to the thermostat on a GE dryer.....
depending on your model, you will have an access point on the back of the dryer to get to the heating element which has attached to it, the thermostat.
If there isn't an access point on the rear of the unit, open the front door of the dryer and remove the 2 screws in the top of the door opening. Using a small prybar, slightly apply pressure prying up the lid. On the inside of the face of the dryer in the corners will be 2 more screws, remove those and pull the face of the dryer outwards to you to about a 45 degree angle. From there, you will be able to lift off the face. Be cautious to unplug the wires for the door switch before pulling the face all the way out. There isn't much to a 10 yr old dryer, just take your time, study the parts and put it back just as you took it apart. For the replacement thermostat or heating element look at
www.marcone.com
www.partstoday.com
Good luck and let me know if there is any more trouble I can help with.
Posted on Mar 18, 2008
aborcass
  • 2651 Answers
SOURCE: Opening a GE electric dryer
there are 2 screws directly under the main top. open the door and look up 2 phillips screws, this will release the top and from there 2 screws on inside lip of front panel will allow front to came off
  • 686 Answers
SOURCE: GE gas dryer gets hot but doesn't dry clothes like it used to
rule number one take everything off of it and never store clothes or anything that can insulate the top it overheats them. It kind of fools all your sensors when you store stuff on top
Posted on Feb 27, 2009
rogrrabbit
  • 986 Answers
SOURCE: Dryer 6 years old Stopped heating up
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Nov 06, 2009
What does a blinking green light on a GE stackable washer/dryer mean
Can you provide more information on the year of your stackables and if you have the exact model or serial number, that would be helpful. Thanks.
Jun 02, 2016 | GE Spacemaker Washer and Dryer Electric...
Ge cycle electric dryer model number dde7200ralwh
take a neddle and put it in your reset button now you will lose your games but it worth it
Jan 02, 2014 | General Electric Dryers
I need to know how old this dryer is Model 66814690 serial MG 1316480
The date of manufacture (month and year) are calculated by the first two letters of the serial number. The first letter being the month and the second letter is the year. The year letter code rolls over each 12 years so you have to know the age within 12 years. The link below will give you the guide to calculate.
Date Codes
Sep 23, 2009 | GE DWSR405EBWW Electric Dryer
Feb 27, 2009 | GE DBLR333EE Electric Dryer
Dryer drum causing squeak
Most likely the front support bearing. If this is the problem you will likely have to replace the slides too. The wizards have a ten year warranty. The bearing is part number WE3M26 and the slides probably need 3 or 4 of them are we1m333. Hope this helps.
Dec 11, 2008 | GE Profile Wizard DPSE592EAWW Electric...
Ge dryer
Jim; without the model number it is hard to give specific advise. (model number is usually on the frame just inside the door) To open top, try pushing a putty knife in the seam between the dryer front and the dryer top, a few inches in from each side.
Nov 06, 2008 | GE DBSR453EBWW Electric Dryer
GE dryer
if you can get the correct model number of the dryer I can find the part number for you. the number you have in not the model number of the dryer. look in the door or on the back of the consol for it and get back to me. thanks
Jul 20, 2007 | GE DCSR483EA Electric Dryer
GE DVL223EBWW Electric Dryer Logo
171 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
