Question about Saeco Magic De Luxe Espresso Machine
Where can I down load the instruction manual for Saeco Magic Profi model. I have lights turn on that I do not know what it meant.
espressodoc
  • 29 Answers
SOURCE: saeco magic de luxe cleaning grinder
I don't know what you mean by disarming the grinder. Unless you are talking about using the bypass. If that is the case there is a button on the panel that has waht looks like a scoop. Push that button and put a scoop in the bypass door and then push the button for what cup size you whant. Regarding the taste of the coffee. It may need a cleaning and service. Try googling "saeco repair" and find an authroized Saeco repair center and have a good service done on it.
Posted on Aug 27, 2007
mirran
  • 515 Answers
SOURCE: help saeco deluxe sup 012
I have in Italian
Posted on Jul 13, 2008
  • 11 Answers
SOURCE: saeco magic de luxe espresso machine
Ok, so you can download a new user manual for your saeco coffee machine here http://www.coffeeshrine.com.au/user-manuals/
let me know if you have any specific question following this.
Posted on Nov 13, 2008
SOURCE: Need Instruction Manual for Saeco Magic Comfort Plus
http://products.saeco.com/index.asp?id_paese=7
follow the link to the instruction manual
Posted on Jan 02, 2009
  • 1089 Answers
SOURCE: Magic Comfort Plus Espresso Machine: how to descale saeco magic comfort...
  • The first thing you need to do is go to your menu. Scroll down to water hardness and push the enter button. Use your up arrow and move the number to 4 if it is not already there. Push the enter button. Once it is on 4, then scroll up to descale machine and push enter. Have your solution (NOT VINEGAR) Citric Acid dissolved in solution and put into water tank. Now open the knob for steam and let the machine do its thing. When it is all done it will say "Finished descaling". Rinse out the water tank and put in fresh water. Close the knob and then reopen it again. When it finished rinsing scroll down to "Reset Descale" Push enter and choose "Yes" with the arrow and push enter. This will bring up a message when it needs to be descaled again. You can also see how many coffee’s you have made. It’s just above the Descale Machine in your menu. Descale more often than Not Enough will keep your machine working well into the future.
Posted on May 07, 2010
Saeco rio profi making a loud noise no water coming out
Someone onCoffee Geek had this to say and it sounds like it could be the same problem:When I first got my machine--a steal from a fellow barista friend for $40!--It had been sitting dry for about 18 months, and I had the same problem with the pump. After trying some things myself, I eventually called the manufacturer's help line and was told I needed to manually prime it. I used a little squeeze bottle full of water to slowly fill the intake tubing with water and turned on the machine and opened the steam/hot water valve which turned on the pump. After some stuttering, it caught and has been fine ever since. So yes, I would recommend manually priming and then running water through the pump, boiler, and steam wand until all air is out of the system. Hopefully that will fix you up.
Aug 05, 2012 | Saeco RIO Profi
Trouble light goes on when we turn machine on
This light tells you you need to descale the machine.  It is all explained in the instruction manual.  Once descaled you turn it off by holding down the steam button for more than 5 seconds.
Jan 31, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco magic de luxe espresso machine
Nov 07, 2008 | Saeco Magic De Luxe Espresso Machine
Estro Profi - Green Light not coming on
It is vapor lock possibly,
1. Soak the steam wand in some hot water for a few minutes
2. Using a cup at the bottom run the brew function and open up the steamer valve until it starts pulling water through. May take a bit of time. Be careful with the steam.
Hope this helps
my white profi of 12 years has been acting up and will not even turn on.
Good luck
Aug 09, 2008 | Coffee Makers & Espresso Machines
I inherited the saeco magic but no instructions on use
There are a manual on Fixya under Saeco/ Magic de luxe
Jul 18, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe dregs light problem
Make sure that both the tray and dump box are placed correctly- otherwise the machine will not start. Both have a switch and when that switches are not engaged, the machine will not turn on.
Mar 09, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic 2nd light to the left (ON RED LIT)
Sound like descaling warning light, need to run descaling solution through the machine (follow instructions, you can download a manual on saeco's website) this light can be turned off by pressing and holding the steam button for 5 seconds.
Jan 21, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
165 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
