Question about Maax Shower Drain 10000041-105
The shower door guide broke. Novello #3577 is the shower that we have.
How do i instal a LaToscana Novello thermostatic control system?
This faucet set will require extensive work on the bath tub or shower area of your bathroom. Skills required will most likely include; soldering, wall repair and tiling.
Jul 31, 2014 | Latoscana TCSHOWER4NOCP Novello Shower 4...
I have a shower glass door which has three doors. One of the door always comes off when I slide d open
most shower doors are held in by the rollers some are adjustable if yours arent check to see if the spring is still holding wheels out firm if not spring probably broke
Dec 12, 2012 | Home
I have a steerling shower door and lost the installmanual
You did not indicate a specific model. Following is the general site for Sterling Shower doors:
http://www.sterlingplumbing.com/shower-doors/shower-doors/
If you look around you can find Ower's Manuals, Installation Guides, and Install Animations.
If you have problems finding the information for your model, reply and I will help with the links.
Mar 27, 2011 | Home
After indtallation shower water leks under door. The base does not seem to fit flush against the threshold. Irv Smith
The chanel at the bottom of the door that guides the doors has drain slits in it make sure the are not plunged up and also make sure the door are not to high off that chanel.
Feb 07, 2011 | Kohler 701129 Focal Bypass Framed Shower...
Installing cd rom drive on a acer5100-3577
this about the only service guide for an acer laptop.
download and review.
I hope it helps you getting the cd rom drive replaced.
Mar 26, 2010 | Acer Computers & Internet
Broken rollers on shower door
The rollers for most shower doors are a stamdard size and are available at most hardware stores. The Bigbox stores might even carry rollers for you specific make and model.
Feb 25, 2010 | Aqua Brass Prestige Shower Kit #2 AQUA...
Need installation instructions for sliding shower door...probably #5475. When reinstalling, the inside door is swinging with nothing to secure the bottom.
not sure what you mean when inside door "swings" on a "sliding" door,...i'll assume you need the "inside door guide", a little plastic piece that screws with one screw to the main threshold,.....
Nov 02, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Maax Shower Drain  10000041-105 Logo
82 people viewed this question
Top Maax Plumbing Experts
Donni Steen
Steve
Andrew Bugbee
Are you a Maax Plumbing Expert? Answer questions, earn points and help others
