Question about Toshiba Satellite Pro L300 Notebook
I cannot open cd drawer when i go to start menu then computer it shows cd rom matshita DVD-RAM UJ880AS ATA DEVICE all the driver details are upto date from this screen menu computer when you click on DVD a big red cross appears stating that D:/ application not found can you please help i have tried to follow on screen instructions but still dont seem to be able to get it to work as iam not computer minded i need step by step instuctions many thanks
  • 33 Answers
SOURCE: cd-dvd rom error code 10. failed to start
I had similar problems with my HP computer and i found either uninstall it through device manager the reinstalling it through new hardware wizaed in control panel. Or if that doesnt work try opening your laptop up and unplugging/removing the drive itself and restarting the laptop then turn it off again and put the drive back in the computer should then register it as a new device and reinstall it. that second option worked for my drive so it should hopefully work for yours
God Bless
Braydon
Posted on Mar 28, 2008
  • 262 Answers
SOURCE: Help my Pioneer DVD-RW DVR-k17LF ATA Device isn't working
dear jnstreen,and Ifountain 127 both of you have the same promblem for jnstreen sounds like to me your system has bump your cd rom Try Http://www.slysoft.com it is very goood software
for a dvd you can download and try it for about 21 days and if it works it cost about 39 dollars or so it is wonderful for download
dvd's rewriteing movies almost everything ....It is little to hard for you to uninstall the dvd player and reinstall it if that slysoft.com doesn't work get back with me ok lala linda ifountain127 I am not sure what's going on with your pc have you tried uninstalling it ?
there should be one screw inthe back of your pc to unistall the cd
rom I would try uninstalling it first and all software ) reboot it now go to your dvd player from my computer click on dvd player scrow down to propertiesgo into your properties go to hardware then on the bottom properties again then properties again then to driver
then click on roll back to previous driver and it should work ...if it doesn't let me know lala linda we can try something else ok
Posted on Jun 11, 2008
SOURCE: GMA 4082n device driver not working properly code 39
I had the same problem with the HL-DT-ST DVDRAM GMA-4082N on a Toshiba laptop.
There is a solution here: http://sillydog.org/forum/sdt_9200.php. Recommend when you delete from your registry to make an exact note of what you deleted so that you can roll-back to what you had before just in case anything goes wrong.
The first time I rebooted when I opened "My Computer" my laptop was unresponsive but on rebooting for a second time the drive was back working and everything seems fine again.
Posted on Dec 01, 2008
lilqban010
  • 7 Answers
SOURCE: my matshita dvd-ram uj880es driver has a code 39 ,
Start>run>type in "regedit"
go to:
HKEY_LOCAL_MACHINE>SYSTEM>>current cotrol set>control>class>{4d36E965-E325-11CE-BFC1-08002BE10319}
go ahead and delete the following,
upperFilters
LowerFileters
UpperFilters.bak
LowerFilters.bak
delete them, exit registry, restart and see if that fixes it.
(Remember to always back up your registry, and files when ever messing with the registry).
Posted on Aug 17, 2009
Matshita Dvd-ram UJ-861H ATA Device Not Working
Use this link to find possible answers to your problem. It is in the Microsoft Community
HP Pavilion with Vista Matshita Dvd ram UJ 861H ATA Device is disabled...
Feb 20, 2014 | Computers & Internet
My Matshita DVD-RAM UJ880AS is not identified in my Acer laptop.
install device drivers then it will show its presence
Jan 10, 2013 | Computers & Internet
Missing Matshita DVD-RAM UJ880AS
Go into my computer, if DVD driver is shown it will run the DVD-RAM driver," may mean the unit must be replaced". If on the other hand it is missing the driver, it will need to be re-installed, or you can try a systems restore to bring the computer back to an earlier time before this became a issue.
Apr 28, 2012 | Toshiba Computers & Internet
Need drivers for a MATSHITA UJDA730 DVD/CDRW
are you sure it the drivers?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
http://download.cnet.com/matshita-dvd-ram-lf/3000-2110_4-82302.html
http://download.cnet.com/matshita-dvd-ram-lf/3000-2110_4-88634.html
http://download.cnet.com/matshita-dvd-ram-lf/3000-2110_4-82303.html
http://download.cnet.com/matshita-dvd-ram-lf/3000-2110_4-88638.html
here are 4 different model drivers
hope this helps you
Aug 30, 2011 | Panasonic UJDA730 CD-RW/DVD-ROM (Combo)...
Uninstalled matshita dvd-ram uj-8505 ata device
Go to Control Panel, Add Hardware and Windows should do it for you.
If you are PC literate go to Start click on it go to My Computer nad right click on ot go to Hardware and click on it go to Device Manager and click on that scroll down to CD/DVD and click on that select the DVD unit and select update driver
Jan 14, 2010 | Sony VAIO VGN-N365E/B Notebook
My mashita dvd-ram UJ880AS quit working. D drive
See if it gets listed in Device Manager. You can access this from Start->Control panel->System->Hardware->Device Manager.
If it gets listed with some error tag, try uninstalling & then Scan for new hardware
Jul 31, 2009 | Toshiba (P000242100) Internal 14x CD-ROM...
Matshita dvd-ram uj-831s driver missing
please go in bios check the drive is shown there.
if shown and not showing in my computer then might be the os issue.
Go to the device manager and check any yellow question mark on the dvd/cd rom drive and if not then try following
Right click and uninstall the drive.
Go to IDE ATAPI controllers in device manager and uninstall secondary controllers or ata channel 1 from there.
Go to run option>type regedit and enter then>H_KEY_LOCAL_MACHINE>SYSTEM>CURRENT CONTROL SET>CONTROL>CLASS>first entry starting with the 4D36 and single click on entry>on the right hand pane check for any lower or upper filter and if there delete both.
Restart the system twice then check if then also not working might be OS or drive faulty
Thanks.
Feb 22, 2009 | Toshiba Satellite A205-S4617 Notebook
MATSHITA DVD RAM UJ-850S Device Not Even Shown
Try a Google search for the driver. I got my printer driver that way. Prints just fine.
Feb 14, 2009 | Computers & Internet
Matshita DVD-RAM read DVD/CD but can not write.
Reformat computer to original setting. I've done this before and its working.
Nov 02, 2008 | Lenovo 3000 V100 Notebook
Toshiba Satellite Pro L300 Notebook Logo
118 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
