Question about Avanti WDE98PS Hot Cold Water Dispenser with Digital Display
Water cooler Avanti WDE98PS Cold water flow is very thin and and extremely slow. Power is on. Cold setting is at 7 degrees. There is adequate water supply and the hot water flow is normal. I tried power off and on, and still the same result. There does not seem to have any obstructions in the recipient.
  • 1314 Answers
SOURCE: Avanti EWC28 Wine Cooler TOO Cool
contact avanti cust svc they are easy to work with and want you happy tell them your promb but i suspect you need a new themostat
Posted on Jan 01, 2008
SOURCE: cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
Posted on Jul 24, 2009
shastalaker7
  • 1515 Answers
SOURCE: Avanti Beverage cooler gets too cold
Hi, sounds to me as though your temperature control is faulty, and the unit is running all the time. This control will have to be replaced. This is something you can do if you take your time and draw a wiring diagram in case you forget. It will have a long coiled up wire with a bulb on the end of it mounted in the evaporator section in the refrigerator section. This all comes out together. This is the only thing that would cause this problem. Get all of the numbers, model, serial, and part numbers when you go to the appliance parts house to get one. You should have no problems in doing this. Please keep me posted as I am sure this unit is worth changing out the stat.
Sincerely,
Shastalaker7
Posted on Feb 02, 2010
SOURCE: hot water valve stuck
Your problem may re related to the recall of that model due to the child proof hot water handle. Go to:
http://www.cpsc.gov/cpscpub/prerel/prhtml05/05018.html
Posted on Jun 29, 2010
eventwholesa
SOURCE: avanti water cooler
Water Despencer Avanti wd29ec, the blue water release valve is leaking. It has a constant drip that overflows the water catcher on the 5 gallon water dispenser. what should i do
Posted on Feb 24, 2014
Why does my water cooler keep freezing up
Your thermostat is set to cold or is stuck in the on position, replace or turn it down
Jun 10, 2014 | Avanti Hot and Cold Water Cooler
Hot water valve stuck
Jun 28, 2010 | Avanti Hot and Cold Water Cooler
Cold water flow is extremely slow. have checked
REMOVE THE COLD WATER HOSE FROM THE WASHER, AN LOOK INSIDE THE VALVE, AN CHECK THE SCREEN, FOR BLOCKAGE, SPECIALLY IF YOU HAVE HARD WATER IN YOUR AREA.,
I HOPE THIS FIX YOUR PROBLEM LEAVE SOME FEEDBACK!
Feb 03, 2010 | GE Profile WPRE6100G Top Load Washer
Cold water filling of tub is extremely slow. No kinks
turn cold water off and remove hose from washer,next remove the screen from the water inlet and clean it and place it back in the valve, place hose back on the inlet,turn cold water back on and test cold setting,you should have good flow.
Dec 25, 2009 | Roper RTW4300SQ Top Load Washer
Avanti N252BG beverage cooler does not get cold enough
Brand new installed avanti beverage cooler. In a basement undercounter so room temp. around 65 degrees. Only gets to around 45 degrees inside even though temp is set to 34 degrees. Most of the time it sits for days without being opened but still not cold. Any suggestions on how to fix this problem?
Mar 26, 2009 | Avanti N252BG Beverage Cooler
Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Feb 21, 2009 | Avanti WC492D Wine Cooler
It is freezing up inside the cooler
Turn the screw on the back of the unit so that the water is not chilled to such an extreme cold
Jun 20, 2008 | Avanti Hot and Cold Water Cooler
Avanti WDE98PS Hot Cold Water Dispenser with Digital Display Logo
46 people viewed this question
Top Avanti Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you an Avanti Kitchen Appliances - Other Expert? Answer questions, earn points and help others
