Question about Kwikset Professional Door Lock installation Kit
Just need owners manual for kwikset titan keying kit no.271 for professional keying of all titan residential locksets
3 Suggested Answers
rsmith972278
  • 160 Answers
SOURCE: how do i remove exterior handle kwikset titan?
You need to insert the key and turn it clockwise, then insert a stiff metal tool like a straightened out heavy paper clip into the hole on the shaft of the lock by the circular flange next to the door. Push it in until you feel it give and pull out on the handle at the same time. If you need more help please contact me.
Best of Luck,
RSMITH972278
Posted on Nov 14, 2009
SOURCE: how to reset kwikset pwerbolt 1000
6. Resetting the code: - please follow these instructions to reset the code on your Powerbolt 1000 unit:
  • Remove the inner cover plate from the lock.
  • Locate the small round program button near the left side of the circuit board (Red or Black).
  • To program, the latch should be extended out in the lock position, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. Re-enter the same 4-8 digit code to confirm, the latch should retract. This completes the programming. This signals that your code has been accepted.
  • To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
7. Replacing the batteries: - please follow these instructions to replace the batteries on your Powerbolt 1000 unit:
  • Remove inner cover plate located above the thumb turn on the inside of the door
  • Replace all 4 batteries with quality alkaline AA batteries. (Do not use rechargeable batteries.)
  • Ensure that the batteries are correctly oriented or unit will not function properly.
8. Changing the password code: - please follow these instructions:
  • Manually put the bolt in extended (lock) position. Press PROGRAM button once, enter new 4 - 8 digit code and then press LOCK.
  • Press PROGRAM button twice, enter the same new code and then press LOCK once.
  • Press PROGRAM button three times, enter the same new code and then press LOCK once.
    These stept will program only the new code you enter for your unit.
9. Why is my Powerbolt 1000 unit beeping? - To determine why your lock is beeping, please follow these steps:
  • Take out batteries and unplug powerstrip.
  • Let is sit for 1 minute then put the batteries back in and wait another minute.
  • If it does not beep, the keypad needs to be replaced (17733-1).
  • If the unit beeps, the powerboard needs to be replaced (A17734-4,3 Powerboard 1460 brass finish; A17734-4,26D Powerboard 1460 satin chrome finish; A17734-4,5 Powerboard 1460 antique brass finish; A17734-4,11P Powerboard 1460 bronze finish).
Posted on Dec 02, 2009
The back light on the key pad is dim and sometimes doesnt even come on ... I changed the batterys and that wasnt the problem... is there some sort of fuse or bulb i need to replace??
Sorry, there is no bulb or fuse to replace. For your problem, the best suggestion is to call Kwikset Customer Service 1.888.805.9837, Monday-Saturday 7am-7pm CST.
You probably have a failing circuit board internal to the lockset, and Customer Service is your best bet for pinpointing the proper component and getting the replacement part on order. Make sure you get the total cost and weigh it against the cost of a replacement lockset before you agree to have them send you replacement parts.
Jul 18, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
How do you key alike locksets
Frequently, you can purchase pared entry sets at the Ace Hardware or other fine retail hardware store ... or they can be special ordered for you if you need more than two. My preference is to support the local hardware store ... however, you should know that some of the so called BIG BOX stores can do this service for you for a fee. And of course, the lock smith in your town can perform all kinds of magic with your locks, like creating a Master Key system. One key for you roe everything, a different key for the milk man and cleaning lady, a individual key for every bedroom and closet, special key for the garage and shed etc.
Thanks for your question.
Feb 03, 2011 | Kwikset Professional Door Lock...
Professional Door Lock installation Kit: After 2-3 years all of the sudden none of our keys...
The lock is bad very common problem with them, If you got 2-3 years out of your "smartkey" lock those things are like dinosaurs most of them don't make it 3 months and this problem happens. Get the traditional pin tumbler version of the Kwikset lock and this will never happen again. Plus it will be an easy swop out since they use the same latch.
May 18, 2010 | Kwikset Professional Door Lock...
Smart key kwikset lock stopped working with the key.
I have just experienced the same problem. After 4 calls and an hour on hold, a warranty representative is going to send me replacement cylinders. I am not happy since 3 of the 4 locksets are already installed. My wife and daughter were locked out for 3 hours!!! Would not recommend this product!
Jan 19, 2010 | Kwikset Locks & Locksmithing
How do i remove exterior handle kwikset titan?
Best of Luck,
RSMITH972278
Nov 13, 2009 | Kwikset Professional Door Lock...
Constant beeping
It sounds like the lock master reset might have been inadvertantly pushed when the coverplate was removed at some point. I would suggest you remove the batteries, reinstall them and reset the lockset and enter in new pass codes (you can use the same ones as before, if you wish).
I've attached the owner's manual, just in case you've misplaced yours, so you can reprogram the lockset and have the instructions for future use and reference.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Just so you know, Weiser and Kwikset were once the same company and offerred the same lock under both names, so don't worry about the manual having the Weiser brand name on it.
Hope you find this Very Helpful - Best regards!
Aug 18, 2009 | Kwikset 907 907-L03 Lifetime Polished...
Need to have a master key for all locksets
Any locksmith can rekey the locks to a single Master. Some make house calls, but it costs less to take them off and take them if this is feasible.
Mar 01, 2009 | Kwikset 907 907-15 Satin Nickel Smart...
Kwikset smart code touchpad electronic deadbolt
I have the same problem, electronic locking system went dead but still beeps, stuck using keys now...according to the kwikset website though it says "Warranties cover the original residential user of Kwikset Products against defects in material and workmanship as long as the original user occupies the residential premises upon which the product was originally installed." so hopefully they will fix the problem
Oct 12, 2008 | Deadbolt PFK Touchpad Electronic Lockset
Lost keys to my Entry door lock
Visit your local Home Depot and purchase a Kwikset re-keying kit. They're inexpensive and work fine but stay alert and follow the instructions properly. This kit comes complete with proper pins as well as new keys. Good Luck!
Mar 07, 2008 | Kwikset Professional Door Lock...
Kwikset Professional Door Lock installation Kit Logo
294 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
