Kitchenaid Clothes washer stops and gives F22 code. After awhile it starts working agian.
  • 246 Answers
F22 is a door lock error. The easiest test is when you get the error code can you rap on the top, rear center of the washer and get it to start working again? Often the solder joints in the board start going bad. The unit reads it as a open door. Also make sure your door boot (the gray peice in the front of the washer) is smooth and not bound up. This will keep the door from closing fully and cause the same problem. Lastly, Check the connections to both your CCU and your door latch after unplugging the unit. For the CCU, remove the lid by taking out the 3 #20 torx bit screws on the back side of the top. Push the top slightly towards the rear and lift it off. The white box on the top rear center is your CCU. Make sure all of the connections are tightly in place. To check the latch, you will find a sliver wire around the gray boot in the front holding it on. Pull it off. The front of the boot will be removeable. Remove the side on the right. As you reach in. you will feel your door latch. There are 3 connectors. Make sure they are all pulgged in solidly. Now re-seat the boot (the edge fits in a gap that goes all of the way around. Once you do that, get the silver clamp you removed. Take a small flat head screw driver and put it in one of the holes next to the spring at the bottom. Next either using your hand or a tool (needle nose pliers work great) run around the sliver clamp working it into the channel for the clamp
Posted on Jun 19, 2008
Problem code F22 flashing
http://www.appliancepartsquick.com/MaytagBravosDryerFaultCodes.html exhaust thermister in simple terms is a small round can shaped sensor which turns on/off heating element as the air temp exiting machine rises or falls to stop machine getting to hot and burning out components,reletivly cheap to buy and faily easy to fit depending on youre capabilitys ,if in doubt call a friend who can help or quallified engineer
Dec 31, 2013 | Maytag MEDB400VQ Dryer
DRYER DISPLAYS CODE F22. What does this mean?
"F22" is a door lock issue Press the "Stop" button twice to cancel the cycle if "F22" shows. Check that the washer door is firmly shut--open it and shut it and try again. Make sure there aren't items blocking the closing of the door. Don't overload the basket. Try the cycle again.
Nov 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
I have a Whirlpool WFW9200SQA12. F22 light
"F22" is a Door Lock error code. This is an indication of a door latch failure and/or interconnecting wiring problem. The first step in troubleshooting the problem, however, is to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of your washing machine. Sometimes these error codes are erroneous and can be easily cleared by resetting the CCU. If the error code reappears following a CCU reset, then you have a genuine problem. In addition, if the door latch remains locked following this procedure, there is a manual release you can use to open the door. The following link explains:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
If you still have the error code displayed, inspect the door latch mechanism for any broken, loose, or missing components. Next, opne the top panel of the washer by removing the three screws in the rear of the washer that hold the panel in place. With the screws removed, the panel will slide back, then off. Locate the door latch on the right hand side behind the front panel. Inspect the wiring harness from the door lacth the to CCU. The CCU is located directly behind the wash tub in the top rear of the washer. Make sure all the connectors are snug and not loose or broken. In the majority of cases, a persistant error is a failed door lacth. If all these preliminary checks are unsuccessful, replace the door latch. The next link explains how:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
NOTE: "Fdl" is the same as an "F22" error code. This error code appears on older models.
I hope you find this information helpful. If you have questions please let me know.
Apr 12, 2009 | Whirlpool Washing Machines
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
KitchenAid Clothes Washer, Fills and then Hums, Blew Breaker
no, need to empty water theres enough room to pull to side, and yesathought it spins by hand i like to see it spin under load. its possible you have a bad capacitor
Jan 31, 2009 | Washing Machines
F22
I have search for this and found:
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
More info can be found on The Whirlpool website:
Whirlpool Front-Loading Washer
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F22 Error Code
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
Sep 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite top load washer
error code with this? f11 or f22 are control board related commucation errors.
Jun 02, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool washer F22
thats a door lock failure code try unplugging the washer then let me know shut the door firmley before operating
Mar 28, 2008 | Washing Machines
Washing Machines Logo
266 people viewed this question
Top Washing Machines Experts
