Question about Kenmore 500 6952 Dryer
Have power the light inside is on but will not start
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Nov 13, 2010
What is wrong with my vw jetta it wont start but the battey is good?
If you mean it won't crank, have you checked the neutral safety switch or clutch pedal switch ?
Jul 28, 2014 | Volkswagen Jetta Cars & Trucks
50 cc automatic scooter wont start its electrical has power to light horn blinkers but turn key wont start
might pay to check the brushes inside the startermotor, and check connections to it.
Feb 21, 2013 | Motorcycles
2001 dodge stratus 2.7l no crank no start. No codes present with diagnostic tool. When ignition switch is open cil light comes on but the wipers the Radio and the most of the dash lights do not come on....
look inside the fuse/relay box under the hood . remove the lid from fuse/relay box and look inside the lid. the location for the ignition system and the start system (fuse/relay) will be marked. check the fuses with a testing light for faulty fuse or relay. also check battery voltage with ohm meter for correct voltage. remove relay and use test light to check for power at the plugs with key on.
Apr 11, 2010 | Dodge Stratus Cars & Trucks
I have headlights but no power inside or to start
Lights will work with a weak battery. Try jumping the truck with another vehicle first. If it starts watch your volt meter and see if it charges up. If you have a indicator light instead watch that. If it flickers the diode is bad in the altenator. If the gauge is present and not charging the altentor is bad. Chack all wiring to the battery and the altenator for loose or corroded connections first. It maybe an easy fix
Jan 08, 2010 | 1990 Chevrolet K1500
My PLV-Z2,globe will not light up,power up to
ballast and/or lamp is bad and needs to be replaced. the ringing sound is high voltage issue.
Oct 04, 2009 | Sanyo PLV-Z2 Multimedia Projector
Has power but won't start. the light inside the
First, go to your circuit panel and turn off then back on the dryer breaker.Second, check for a broken belt. The belt switch will be open if the belt is broken and the dryer will not start. Next.Replace the thermal fuse located on the top right of the heater canister located in the inside rear of the dryer.
Aug 28, 2009 | Hotpoint Dryers
Overcrank error message
The 'overcrank' error simply means it tried to start but never actually started. It cranked for an extended period. Check the fuel and starting issues you would normally check to start the engine.
Mar 31, 2009 | Kohler 12 kW Emergency Power System -...
Kenmore 500 6952 Dryer Logo
50 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
