Question about Kitchen Ranges
Maytag error code f2 on electric range - Kitchen Ranges
  • Anonymous May 18, 2009
    WE4800 when the oven temp is selected the panel flashed F2. Does this require a repair person to intstall and if so what type of part?
F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor
http://www.repairclinic.com/0078.asp#Maytag4
Posted on Jun 27, 2008
Maytag gemini electric double oven, f1-f2 codes both ovens, tested both temperature sensor probes, both at 1100 ohms, called Maytag, said might be control board. Anything else to test before spending $$$...
make this test and fix it. God bless you
F1:-1 Runaway Cook Upper oven Test the temperature oven sensor replace if necessary F1:-2 Runaway Cook Lower oven Check the temperature oven sensor replace if necessary
Nov 04, 2013 | Maytag MER6772 Gemini Electric Kitchen...
F2 error code on GE Spectra JBP78
F2 indicates that temperature inside the oven has gotten to high. Pull the temp probe and check to see if it has 1100 Ohms. If it does, you will need to replace the control board.
Here is the probe to order if it is bad.
Here is the control board to order if the probe is good.
Keep me posted!
Jan 19, 2013 | GE Spectra JBP78 Electric Kitchen Range
MODEL NO.CRE9500ACL MAYTAG ERROR F2
Click Here for Maytage Most Common=> Error Codes I will be here to answer any other questions you may have. If helpul please rate this solution, Thank You, Sea Breeze
Nov 03, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Maytag electric range, older model. What is a beeping, flashing code F2
F2- oven too hot. usually due to a bad oven temperature sensor. they sense the temperature of the oven by changing resistance, and can keep the element hot, or turn it off.
Jul 06, 2011 | Maytag Ovens
Have a F1-2 error for my maytag range.. the stovetop works fine but the ovens don't
F1
Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common
problem. Refer to F1 test at the top of this page for more
information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor
(RTD). Check sensor harness.
Jan 08, 2011 | Maytag MER6772 Gemini Electric Kitchen...
F2 error for MAYTAGE CRE9500 electric range
Here is the definition for the F2 code from Maytag...
F2 Oven temperature too hot. Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness.
Jun 04, 2010 | Kitchen Ranges
F2 E0 - KITCHENAID ELECTRIC RANGE
F2-E0 Shorted Keypad Replace Keypad
Note if keypad is replaced and same code ,
replace control.
Feb 16, 2010 | KitchenAid KESA907PSS Electric Kitchen...
F2-3 keeps beeping a message code and phone number that isn't any good.. then shuts off.
Hi there
I have found the code for you and hope it helps.
F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness.thank you for writing to fix ya.
Best Regards Richard
Feb 12, 2010 | Maytag MER6772 Gemini Electric Kitchen...
F2 error code on GE built in Oven Model JKP13GOP
Your error code means this. F2 For an unknown reason, the oven temperature has exceeded a preset threshold.
Good Lock and Please Rate FixYa!
Dec 27, 2008 | GE JBP90 Electric Kitchen Range
Kitchen Ranges Logo
834 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
