Question about Ovens
I am trying to clean my oven. I pushed the cleaning button, it locked and said it would take 4 hours. One hour into it, it is beeping F2. What does that mean?
  • Ovens Master
  • 43,501 Answers
It means that somwthing went bad in there.... shut it down and read this tip....
Before you go working too hard to get your oven to go into the self clean mode (self destruct mode)....check out this tip...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Posted on Nov 13, 2010
Closed door, pushed clean button, but door lock button keeps flashing and door won't lock.
Hello there and welcome to Fixya
This is a fairly common problem with self cleaning ovens
The problem normally is that the user has interrupted the clean cycle and the door is locked by default or the door lock assy has failed all together .
Now here is the thing these ovens have a built in memory module that stores a number of commands that the user has input in it like self clean or broil ect.ect so what you will have to do is to clear the memory and it is done like this.
First unplug the oven and do not touch it leave it sit for a minimum of 1 hour this will reset the memory module
Now only after the hour is up plug in the oven and you may hear a beep ora click if so great wait a few min then you can press the cancel button then try to open the door again.
Sep 16, 2011 | Frigidaire GLEB27S7A Electric Single Oven
We have a kenmore model# 911.47692100, oven with a self-cleaning cycle that does not want to work. Following the instructions we push CLEAN, the 4 hour display comes on, we push START and the LOCK DOOR...
The oven self clean heats the oven in excess of 450 degrees. It will not begin until the door is properly closed and the slide lock goes completely home. This is to prevent anyone being able to get into the oven until after the cleaning cycle is done. When your "door lock" indicator blinks and beeps, try the door to see if it is really locked. If not, shut off the system and try to find out why it is not locking properly. If you find the reason and fix it, it will probably work properly.
Jan 01, 2018 | Ovens
My GE drop electric range will not turn on the self cleaning unit. I set the time and push start and it flashes clean oven, door lock, however, the door will not lock. I hear a clicking sounds, it beeps...
You will need to press the stop/cancel button, next press the self clean button, you do not have to set the time the cleaning cycle takes approx 3-1/2 to 4 hours and the cool down takes another 45 minutes to one hour, it will clean and cool down and you do not need to interrupt this cycle, it will let you know when it is complete.
Nov 14, 2009 | GE Profile JTP18 Electric Single Oven
F2 error
F2 is a bad temp sensor, needs to be replaced.
Jun 23, 2009 | GE JKS06BFBB Electric Single Oven
Beeping with 'f2' & 'f3' message when cleaning but did not finish cleaning. Oven now cooled but still locked.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@#
May 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
GE: E Profile Single Electric Oven Model: JSP40W0WJWW
First press and hold the cancel/off button for 10 seconds.
If that does not work you have a bad thermal switch due to excessive heat buildup. Possibly a bad fan motor.
The 2 thermal switches are located on top of the oven behind the control panel.
Mar 18, 2009 | GE Profile JTP18 Electric Single Oven
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
F2 Beeping!!!!
F2 Oven too hot Replace oven temperature sensor
Mar 09, 2008 | Kenmore 33464 / 33465 / 33469 Gas Single...
F2 error
what is solution
Dec 08, 2007 | Ovens
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
138 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
