Question about Homelite ZR10926 16" Chain Saw
How to remove snap in primer bulb on homelite chainsaw
    Brigadier General:
  • 4,088 Answers
Use a set of pliers to pinch the two 'ears' together so that the bulb assembly can be removed. Try to install the new one in the same relation as the old one so that the two fuel lines don't become reversed. Good luck!
Posted on Nov 13, 2010
Is the primer bulb replacable on 200 classic chainsaw.or do I have to buy a new gas cap.
Hi Shirley:
My apologies if I'm incorrect, but I've never seen a chainsaw that had the primer bulb connected to the gas cap.
So,,,,,
I'm hoping you're asking two questions at the same time.
1) Primer bulbs are replaceable but it's extremely rare that it is necessary
2) Gas caps are replaceable but only needs to be done if they are broken.
If you reply as a comment on this post I'll be able to respond to you.
Cheers.
Oct 14, 2015 | Homelite Garden
I have a handheld blower/vac: The primer bulb is new and will not pump fuel,not even fill the bulb. I checked the fuel lines to make sure they were correct.(homelite)
I was working on a neighbor's homelite chainsaw and I replaced the primer bulb, it was not intuitive, and I hooked up the lines backwards. Also if you are replacing the primer bulb, maybe you have old fuel lines that are deteriorating and need replaced. Did you check the in tank fuel filter? If it looks dark, it may be time to change it.
I hope this helps get you going again.
Sep 01, 2011 | Homelite Consumer Products MightyLite...
Homelite chainsaw gas line diagram witch one goes where have the primer bulb
Take the primer bulb off.Look on the back side of it.Most will say tank and carb.If not try putting them on if the bulb doesen't get gas in it.Change them around.
Feb 27, 2011 | Homelite ZR10926 16" Chain Saw
My chainsaw (Homelite UT10514) will not prime fuel. I have changed the primer bulb and checked the fuel lines for damage, they seem to be in good shape.
You need to make sure the lines are connected properly to the bulb. Also, if the carburetor diaphragms are not working properly the carburetor will not prime.
Feb 12, 2011 | Homelite Garden
How to replace the fuel primer bulb and fuel lines in McCulloch 3516 chainsaw? the fuel primer bulb broke and the plastic lines have crumbled. i need to know how to run the lines from the fuel tank to...
I just did a primer bulb not too long ago, but I don't remember what equipment it was on. They are generally easy to replace. First, remove anything that is retaining the bulb assembly, such as cover plate. On my Homelite chainsaw, I simply pried it out with a small screwdriver.
The replacement part itself has two barbed stubs that the two fuel line hoses push onto.
Make sure that you keep the fuel line tubes above the fuel level at all times to prevent leakage.
Dec 05, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Replace a primer bulb on a Homelite Mighty Lite 26cc trimmer
There should be two to four screws right around the primer bulb cover, which is located around the primer bulb. Remove those and switch the primer bulb out.
Aug 12, 2010 | Homelite Mighty Lite Lawn Trimmer
Has Ryobi RCS 3535A chainsaw a fuel bulb priming
The numbers you supply don't cross to an operators manual but that is typical of Homelite/Ryobi. I'm going to make an educated guess that it does not have a primer system. Other Ryobi saws with primer systems include it in the specification. The 3535A does not. Close scrutiny reveals no primer.
IMO fuel primers on chainsaws are one more source of problems. In the USA ethanol additives attack fuel hoses. Without a primer routing is from the fuel tank directly to the carburetor and much simpler to replace. Primers on chainsaws operate differently than 4 cycle engines too. No fuel is injected into the carburetor or engine, its only purpose is to ensure the carburetor is full of fuel,
Typical Fuel hose routing:
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
HTH
Lou
Nov 14, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
How do I replace the primer bulb on a Homelite Ranger chain saw?
Most of them snap in, meaning there are two small blades that are cast into the plastic for the primer bulb housing. These tabs fit into a recess and lock when pushed in from the outside. You will need the entire replacement as you cannot just replace the bulb like is possible on a Zama or Walbro carb. Whatever you do, make sure you mark the routing of the hoses. Its always fun to get them hoses mixed up and then wonder how theyre supposed to route...
Aug 30, 2009 | Homelite Garden
Primer bulb is part of the fuel cap.
I have a Homelite Super 2 chainsaw that has a hole in the primer bulb on the fuel cap...will not prime. Where can
I find a replacement primer bulb fuel cap?
Jun 24, 2009 | Garden
Homelite ZR10926 16" Chain Saw Logo
304 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
