Question about Masterbuilt Grilling
My wood chips keep catching fire? even with flame low as can be
3 Suggested Answers
  • 22 Answers
SOURCE: I've got the 20050106 and simply can't stop my
You need to shut down the air intake, that is most likely your problem. Fire can't start without oxygen, but the wood will still smolder and make the delicious smoke you are looking for. Close all the vents, then adjust them as you smoke.
Hope this helps!
Posted on Jan 21, 2011
TheMobilian
  • 8220 Answers
SOURCE: do i put my wood
I soak wood chips then put em in the pan above the burner on very low flame:
Posted on Sep 20, 2011
Where do I put the wood chips in?
this depends on the type of appliance you are using A smoker or a charcoal barbecue will use chunks instead of chips so I'll assume you have some brand of gas broiler that does not have a drawer or cavity for wood chips engineered into the design of the appliance.
In this instance you can soak chip overnight and loosely wrap them in aluminum foil. Place the loosely wrapped chips over a burner on the radiant tray or briquette tray so the heat is directly on the wood chips.
Close the hood and keep the other burner off or low so the heat on the wood chips soaked overnight causes them so smoke and not char. You need the wood chips over the flames so they smoke.
Oct 18, 2014 | Grilling
Do i wet the wood chips.or put in dry?
always smoke with wet wood. chips are small and will burn up fast. when i use chips i soak them overnight so they're good and saturated and i still keep a water bottle handy in case they dry-out while smoking and catch on fire.
Jan 24, 2014 | Grilling
HOW DO I PLACE WOODCHIPS IN THE SMOKER FOR SMOKING
soaking wood chips in water keeps them from burning up . soak them and randomly place them over coals close vents to just being a little bit open this will keep an actual flame down yet still cook when smoking low heat is the best way to smoke. soak wood chips for 45 minutes min or up to a day. use beer apple juice or water for different flavors
Nov 22, 2012 | Grilling
How to slow cook food on a char-broil smoker, model CBBA-2750. (what temperature and length of time as well as instructions on how to cook)
Hi hcf6886...
To use your Brinkman Smoker or Other Smokers
1... Marinate or place a rub on the meat you will be smoking, and let it sit for a few hours or overnight in the refrigerator.
2...Cover your wood chips with water(and if you wish you can add some Jim Beam Whisky or other flavorfull liquids in a bowl with the water, 1 inch above the wood chips and use a flat peice of metal (pie pan,etc.)to weigh the wood chips down underwater.
You will do the wood chips at least 24 hrs before you plan to start smoking this gives the wood time to soak in the flavorfull liquids.
3...Start a fire in the smoker having the fire below the meat, but do not put the meat on yet, wait till the flames die down first.
Once they are coated with gray ash, you can place the meat on the racks and add your soaked chips to the smoker.
I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat if you are not using a water pan in that position.
4...Place the meat in the smoker on the grilling surface, and place the wood chips over the charcoal and hardwood in the main grilling area Close the lid and do not open it unless you must add wood chips during the cooking process.
5...Continue adding wood chips to the tray as needed during the time you are cooking.
If you have a Brinkmann or other smoker with one chamber for placing the wood chips and the meat, add wood chips only once per hour.
6...Apply your sauce to the meat one hour before the meat should be done.
Test your meat with a thermometer for for an internal tempreture of 160 degrees for medium and 170-180 degrees for medium well to well
Note: Apply the sauce quickly to avoid loosing the heat in your smoker if you leave it open too long it will allow the heat and smoke to escape, increasing the cooking time.
Close the lid if it needs to continue cooking till you reach the right internal tempreture
7...Test your meat with a meat thermometer after a few hours of cooking time.
Make sure your meat is at least 160 degrees internal tempreture for medium and more than 170 degrees for medium to well.
Close the lid and maintain your heat if it needs to continue cooking.
Please take time to rate me.
Sep 18, 2011 | Grilling
How to use a char-broil smoker (charcoal) with wood chips smoking briskit. ( what temature should the grill be at ?)
Hi hcf6886...
Do i put my wood chips on the flame disk bowl
Sep 11, 2011 | Masterbuilt 20050106 Propane Smoker
Do you put the wood chips directly on the heating element?
Hi bobsbbq3u...
I am sending you some smoking information on how to use your smoker..
Sep 07, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
When using chips for smokers do you dump them as soon as they start burning
Let the grill heat up first and stop flaming if using wood..
After the grill is heated up to temp your going to smoke at then you add the wood.
I will include some info for you also to help.
2...Cover your wood chips with water(and if you wish you can add some Jim Beam Whisky or other flavorfull liquids in a bowl with the water 1 inch above the wood chips and use a flat peice of metal (pie pan,etc.)to weigh the wood chips down underwater.
You will soak the wood chips at least 24 hrs before you plan to start smoking this gives the wood time to soak in the flavorfull liquids.
Sep 06, 2011 | Masterbuilt 20070106 Electric Smoker
I have never had a smoker before is the water pan the bottom one or is that the wood chip pan?
Hi
3...Start a fire in the smoker having the fire below the meat, but wait to put the meat on till the flames (if any) subside.
Use the water pan below the meat (if you use one) to catch the juices from the meat...it will be above the pan with the charcoal in it.
Use hardwood or charcoal for your fire/smoke,
Once the charcoal/wood are coated with gray ash, you can place the meat on the racks.
I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat, if you do not use a water pan.
Monitor the tempreture
Sep 04, 2011 | Grilling
The difference between the flame bowl and water bowl
You want the wood chips above the heat source and then the liquid above that. The heat source smolders the wood whilst the liquid keeps the meat moist. Remember you want a very low heat.
Dec 31, 2009 | Masterbuilt 20050106 Propane Smoker
Grilling Logo
138 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
