Question about LG Televison & Video
HDMI problem in 26ld310 - LG Televison & Video
HDMI cables
What is the question? Get the correct cable
Feb 01, 2013 | NEC Nippon Labs Premium High Performance...
How to connect cpu to lg 26ld310 26-inch lcd
Just use a VGA cable like you would to a PC monitor. You might have to adjust the resolution a touch, but that is all.
Apr 10, 2012 | LG Televison & Video
I want to connect my pc to an Samsung LCD hdmi-hdmi
HDMI and DVI are both digital signals, therefore if you used DVI - DVI it would be the same as HDMI - HDMI.
If you really want to use HDMI - HDMI you could purchase a DVI - HDMI adaptor for your graphics card. Contact your favorite computer store.
Take care!
damnor01
Sep 08, 2011 | ATI RADEON HD 2400 PRO Graphic Card
Just set up RX-A700 two things seem wrong. 1. HDMI 1 won't show video if HDMI is plugged in, once plug on HDMI is removed from receiver HDMI 1 works perfectly. 2. HDMI output needs to be held tight or else...
sounds to me like a bad HDMI cable. Just replace it.
If HDMI still wont show, move to another HDMI port. But based on having to hold HDMI cable with hand to steady the connection, it is either a bad HDMI cable, or a bad HDMI port on the receiver. Good luck
Jan 23, 2011 | Yamaha RXA700 Receiver
Sir, i have just bought a new lg 26ld310 model. I want to connect my PC to it(my pc does not contain HDMI). Waht would be te cheapest and best way to connect my PC? Thanks in advance Regards, Vinamra
Used ur computer VGA monitor cable.Connected to the computer video card port and the other side of the VGA cable connected to the LCD tv VGA video port.This will work fine too.
Dec 02, 2010 | LG Televison & Video
What kind of cable if any can i use to make my wd52526 proj tv my pc comp monitor
Your projection TV has HDMI input so you would need to either run an HDMI-HDMI cable from an HDMI output on your computer or, more likely, a DVI-HDMI cable from the DVI output on teh computer to the HDMI input on the TV. If ycou can'T find a DVI-HDMI cable note that you can also buy DVI/HDMI adapters for one end of an HDMI-HDMI cable.
Note that DVI is HDMI minus the sound so if you do run DMI to HDMI you'll also need to route the sound to your TV or other amplifier.
If you only have a VGA output on your computer then you will not be able to easily run this to your TV as VGA is an anologue signal while DVI and HDMI are digital. To do this you'd need a converter.
Hope this helps. If so then please rate my advice.
Thanks
Sep 03, 2010 | Computers & Internet
HTMI errors on the following devices DVD Blue-ray HDMI connected; CD Not HDMI connected; VCR Not HDMI connected; satellite works OK HDMI to Yamaha - HDMI to TV NO HDMI error displayed; GUI does not display...
You have to use Component Video on this unit. HDMI will not "Handshake" and pass thru. This was HDMI's first version "1.1a" and there is no fix. Use your receiver to switch audio via Coaxial or optical then use HDMI directly from BLURAY etc to your TV. The downside to this is how many HDMI inputs your TV has. It's an awesome receiver! Don't blame Yamaha!!! This issue is directly attributable to "HDMI" and their race to shelves before truly field testing the product. The current version of HDMI is 1.3b and soon to be 1.4 which includes ethernet capabilities.
I hate to be the bearer of bad news! If you would like an "in depth" look into the world of HDMI issues, Google HDMI problems or HDMI forums, and you can read for hours. Hope this helps
May 29, 2010 | Yamaha RX-V2600 Receiver
Help HDMI Splitter Doesn't Work!
The HDMI splitter is intended to take one source to two displays. You need an HDMI switch to take two sources to one display, a device you can tell which input to select.
Jun 06, 2009 | Toshiba 26HF85 26 in. Television
Televison & Video Logo
44 people viewed this question
Computer Repairing
Computer Repairing
