Question about Bionaire BDQ24 Quietech Dehumidifier
Hi i knocked over my dehumidifier at it started to make a noise while running after standing upright now it has stopped working altogether is this common and can it be fixed?
GE dehumidifer fan making loud knocking noise
possibly have to take motor and fan out as a unit to get fan off .
Sep 19, 2015 | General Electric AHH40LH Dehumidifier
I HAVE A WHIRLPOOL 25 Pint Dehumidifier model AD25BBL2 serial starts with QM. Anyway it Seems to work ok as water does collect in water tray. About every 30 minutes it makes a single KNOCK NOISE. Unsu
Hello, Consumer. We're sorry to hear about the difficulty with your dehumidifier. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps! http://bit.ly/112Lu7q
May 21, 2014 | Whirlpool 25-Pint Dehumidifier
The unit still makes a running noise but seems to collect no water. this unit is about 4 years old but stopped collecting water about 2 years after purchase
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 30, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Dehumidifiercomprosser starts runs about 15 to 30 sec.then stops fan keeps running comprosser starts again after abot 2 to 3 min.
Hi, the unit is low on charge and has a refrigerant leak...
heatman101
Apr 15, 2011 | Heat Controller BHD-501 Dehumidifier
My dehumidifier is no longer making any noise and is not extracting water. The lights still come on, and when I first plug it in it starts to work for about twenty seconds and then quits. Is this fixable?
heatman101
Apr 04, 2011 | LG LHD45EL Dehumidifier
Will not shut off in the off position Starts and
heatman101
Jan 23, 2011 | Kenmore 54351 Dehumidifier
Unit keeps trying to run, but stops, then trys again. this happens 2 or 3 times until unit finally starts.
Hi, The compressor is taking a few tries to start...the capacitor is probably bad...this does not give the compressor the kick it needs to get started...
heatman101
Sep 28, 2010 | Haier 45-Pint Dehumidifier
Whirlpool dehumidifier makes a lot of noise when running and vibrating, dehumidifier is only 4 years old it does take out the water but very noisey any way to quiet it down?
When the compressors start to go bad they often start to get very loud also...the cost to replace the compressor will probably be more then a new unit...
Also check out this tip about dehumidifier problems...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
May 02, 2010 | Whirlpool AD50USS Dehumidifier
Will not run or turn on light will not turn on
Had a similar problem with Goldstar model DH305. A solution was already posted about cutting the two white wire going to humidity control, and it works until tray fills up (no control). However, if you want a complete fix which allows you to control by selecting humidity level go to the following site:
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=282871&modelsID=&typeName=dehumidifier
Part number is 6877A30013L
May 27, 2009 | Goldstar DH304 Dehumidifier
My HDN455 45 pint Dehumidifier did not work
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
May 17, 2009 | Haier HDN455E 45 Pint Dehumidifier...
Bionaire BDQ24 Quietech Dehumidifier Logo
110 people viewed this question
Top Bionaire Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Bionaire Dehumidifier Expert? Answer questions, earn points and help others
