My screen is partially black, I cannot adjust or move my pages it will not fill the entire screen.
  • 6,487 Answers
It seems that your monitor is having a OSD locked that's why you cannot correct or change the settings of it.
You can correct that by doing the these, To un-lock the OSD - press and hold the MENU button while the monitor is off and then press power button to turn the monitor on. Now you can use the up or down button to change the settings of it.
Posted on Nov 13, 2010
How do I make the picture bigger so it fills the screen and not have black bands at top and bottom
Banding of the screen usually means that the aspect ratio of the broadcast is different than the screen size ratio. Most modern TVs are 16:9 ratio. Most modern TV broadcasts and movies are as well. In those cases, when in HD mode, you will see the picture fill the entire screen. Older broadcasts and many syndicated reruns are in the old 4:3 format and will be banded. Also, some movies are in larger formats than 16:9 and will reduce in size in order to get the entire picture on the screen. That being said, most TVs DO have a stretch and.or zoom feature that will expand all images to full screen size. Be advised that this can result is image distortion, especially of the 4:3 ration broadcasts. Others will have some of the picture cut off and you may see some items such as network logos, etc. partially chopped off in this mode.
Mar 13, 2015 | Televison & Video
Mitsubishi WS 55805 nothing but blue screen and black square in middle
A full service manual is available online---I will presume you tried to unplug it for a while and then power back to see if will reset itself.
This set has three hidden menus---one is the OPTION menu--in that menu with the Mitsubishi remote you can do a hard reset of the entire set= sets all back to factory except convergence adjustments which are stored in another area--cures all kinds of oddball issues.
I can give you a link to the manual and the page numbers for the OPTION menu.
Note: the other two hidden menus are Convergence and adjustment--do not go into adjustment menu as one wrong move and poof!
SD TECH
Apr 20, 2012 | Mitsubishi WS-55805 55" Rear Projection...
I have an IBM ThinkPad running Windows 98 Second Edition used to program older radios so it needs the older version of Windows. The display power on showing IBM Thinkpad full size, but when windows or DOS...
I've seen this before, the main problem is that the resolution is set too low, so it only fills part of the screen.
two ways to solve it.
1. Adjust the resolution to the optimal setting so it fills the entire screen.
2. Find the Picture Scaling option and have it Scale the picture to the entire screen.
To adjust the resolution, now its been a long time since I used windows 98, but I think you got to it by going to your desktop with the background, right click anywhere on the empty space and select properties, now on the window that opens it was the last page, settings I think, you should get an representation of your screen with a resolution lever and color options, pull the resolution lever one point to the right and hit apply and ok, do this until the picture fills the entire screen.
If your laptop has internet connectivity, I could take a look at it over remote support and solve the problem for you.
Oct 23, 2011 | IBM ThinkPad 380 Z (2635HGU) PC Notebook
My new LG Flatron E2350 does not fill the 23 inch screen only 22 inches with a black border, have updated graphics and monitor card to the latest. What do I need to do for the graphics to fill the 23 inch...
Similar to TV - you need to adjust the "H" - Horizontal and "V" - Vertical. Horizontal will move picture up or down and Vertical will adjust left to right.
Use the menu button on your monitor.
Apr 03, 2011 | LG Flatron L1515S 15" LCD Monitor
There is a black 2 1/2inch bar on leftside of screen how do i adjust is?
if your lucky it's just your H-center is off tilt. to check this Press the menu button on your monitor. scroll through the options till you see Horizontal-center option. select this setting and move the screen to the left. The entire screen should start shifting to the left and fill in the screen. now if you do this and you get a black bar on the right. Center the screen where you have the same amount of black on both sides of the screen. scroll through your menu till you see the H-size. increasing this will fill in the black area. Hope this helps.
Sep 13, 2009 | X2Gen MG19MY 19" LCD Monitor
Upgraded eMAC G4 to OS 10 and have display problem
You SHOULD be able to control the monitor adjustments in os 10. In the Displays section of the System Preferences, look for the "geometry" tab. Under this tab you should be able to control width and height so your display fills the entire screen.
If you still can't find it, try adjusting the resolution and refresh rates. Also use the "detect displays" button.
Jul 15, 2009 | Apple Computers & Internet
NEED TO ADJUST THE VERTICAL SIZE OF A PANASONIC TV
Has the image been "zoomed" into?  This is usually the result of a image that has been adjusted to fill the screen.  This is not the same as adjusting the aspect ratio as that would still show the entire image even if distorted.  When the image is cropped or is missing information, a zoom feature is usually the culprit.
If this isn't the problem, you maybe able to adjust the TV's horizontal/vertical placement through the TV's onscreen menu but only if it provides that option.  Do you see other channels that appear to fit properly?  I have seen certain channels not fit correctly while others do and this is due to the signal, not your TV.
Mar 25, 2009 | Panasonic Televison & Video
How do I move my screen image a few pixels to the left?
TV - analogue (S-Video, composite) X X X TV - analogue (component) X X VGA (with EDID) X X VGA (without EDID) X Digital (DVI, DisplayPort, or HDMI) X X Digital (HDTV via DVI, DisplayPort, or HDMI) X X LVDS (notebook display) X If the feature is supported, the corresponding tab is available on the Adjust Desktop Size and Position page. If only one feature is supported, then only the controls for that feature appear on the page and there are no other tabs.
Scaling The scaling controls let you adjust the size of the desktop to best fit your screen. The configuration that you specify may be overridden by the settings in the Resize section.
Select a scaling mode
Aspect ratio: This setting expands the desktop as much as possible while maintaining the same dimensional proportions, or aspect ratio, as the original image. There may be some black borders, but you may prefer this setting to avoid distorting the image.
Full-screen: This setting stretches the desktop to fill the entire display screen.
No scaling: This setting leaves the display image in its original size and centres it on your screen resulting in a small though crisp image. A black border may appear around the display image.
Perform Scaling on
GPU: This causes the GPU to scale the desktop from the set resolution up to the native resolution timing.
Automatic: This setting uses a combination of display and GPU scaling to scale the desktop from the set resolution up to the native resolution timing.
Override the scaling mode set by games and programs
When this check box is checked, applications cannot change the scaling mode set on this page.
Preview
Under the Preview section you can select a resolution and refresh rate, and then the preview image shows how full-screen applications will appear on the screen, using the selected scaling configuration. The available refresh rates will depend on the scaling method selected.
Resize Some displays, such as HDTVs, extend the edges of the display beyond the visible borders of the screen. This overscan is intended to hide broadcast data that is not intended for the viewer. This results in hiding useful parts of the screen for non-broadcast content, such as the Windows desktop.
The best way to resize the screen in order to view the entire content is to use the controls provided by the display hardware.
The resize controls on the NVIDIA Control Panel are provided in case satisfactory results cannot be achieved using the controls on the display.
Position Use the arrow buttons in the image under Adjust the desktop position to adjust the position of your desktop or image on your screen.
Aug 17, 2017 | Samsung SyncMaster 940BE 19" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
