Question about Dishwashers
Air dry, washing. drying,sanitize, clean and 6 hout delay lights continuously flashing. Do not know how to reset. Turned power off and back on but did not help;. Kenmore Dishwasher Model # 587-15173400
  • 3 more comments
  • firebar Nov 13, 2010
    I tried that and it did not work but the machine did start t make some noise briefly.
    All of the lights are flashing at the same time and the delay 6 hour light is also blinking. There is no 0 delay option , only 2,4,and 6.
    All of the lights are flashing together including the 6 hour delay light. There is no 0 hour delay light, only 2,4,and 6.
    There is no heated dry button but there is an air dry button and I held it for 5 seconds with no results. Thank you anyway for the help. Do I have to get this board from Sears?
    Do you know of any place that I could get a control board. I really hate having to pay Sears three times what something is worth.
  • 10,515 Answers
It sounds like your delay start has been depressed.Have you tried setting it to 0 hours by pressing the delay start repeatedly until 0 is displayed.
Let me know,once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 13, 2010
  • 1 more comment
  • taran_2005
    taran_2005 Nov 13, 2010
    Thanks for your response!!
    This seems to be a problem wit control board. Kindly provide few more details :-
    1. Are the lights blinking or steady? If blinking, any particular sequence?
    2. Do the hour delay light still blinking?
    Let me know,so that we could proceed.
    Hope i helped you.
  • taran_2005
    Try hitting and holding the heated dry button for 5 seconds. If this
    does not work the control board is what will need to be replaced.
    Let me know,if needed further assistance.
    Hope i helped you.
  • taran_2005
    You could get this part from Sears.There are many other places from where you could buy this part from most of the online part stores or an appliance part store located close to your home.
    Hope i helped you.
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jan 18, 2015 | Kenmore Dishwashers
I have a kenmore dishwasher 587 model. It went through a wash, the clean light is on I unload the dishes and it won't run again unless I use the breaker in the basement. I tried holding down the heat...
It might be a safety switch on the heater in there, most of the time they usually only reset after the temperature has dropped but some will reset with the power being cycled. I am furnace repair man myself, and that's what I'd suspect. Either that or there is some other safety switch that is locking it out that only resets with the power being shut off.
Aug 23, 2013 | Dishwashers
Unknown control panel symbols bosch dishwasher super silent
Wash Cycle Options
Delay Start (model dependent):
This option allows you to delay the start time of your dishwasher up
to 19 hours.
Sanitize:
The Sanitize feature is available only in the Heavy, Auto, Normal and Half Load cycles. Press the
"Sanitize Option" button to activate the Sanitation features during these cycles. The technical sanitation
measures may also improve the drying results. The sanitize LED or The "Water Pipe" symbol will light when sanitation
requirements are met.
Note: The dishwasher automatically defaults to Auto Wash when turned off and back on. If you used the sanitize option
in your last cycle, the dishwasher will default to Auto Wash with the Sanitize option selected when you turn it on.
To achieve proper drying, always use a liquid rinse aid, even if your detergent contains a rinse aid or
drying additive.
Note: The dishwasher indicates low rinse aid by turning on the Refill Rinse Aid indicator LED (for units without
a display) or The "Spray Looking" symbol (for units with a display).
If this light is on, you need to refill the rinse aid dispenser
I got the idea that the "squiggly arrow" has something to do with the sanitize feature also. If you post your model number "on the inside right hand side of your dishwasher door" I'll go get your manual and post the link here. Hope this helps so far! :)
Jun 18, 2012 | Bosch 500 Series SHX55R55UC Fully...
Why are lights flashing on my dishwasher's control panel?
There is a button configuration that you can press to make the unit reset on some you would close the door and push normal wash heated dry then normal wash then heated dry on others it would the econo wash button then heated dry then the econo/ heated dry this pattern starts the unit and then puts it into the drain cycle and resets the control which allows you to start washing again. If you can name off all the buttons you have I can tell you exactly which ones to perform this reset in the unit. I await your reply
Rick
p.s this also happens on whirlpool models as well right after the warranty runs out so you end up paying the high service charge for a tech to walk in you door push a few buttons then collect a fee over 169.00 which is ridiculous.
Nov 17, 2011 | Maytag Dishwashers
Brand new Matytag MDB7749AWB Dishwasher does not work correctly. As soon as the power was turned on, all three cycle indicator lights ('Wash', 'Dry', and 'Clean') came on and always...
Try putting the unit into a test mode. This my clear your issues otherwise call for service.
One of two ways to do this.
In standby (no lights) Press the combination of buttons:
hi temp wash > sanitize > hi temp wash > sanitize > hi temp wash
All lights will come on and the washer will run a test cycle anywhere from 5 to 10 minutes.
If that button comb doesn't work use:
heated dry > sanitize > heated dry > sanitize > heated dry
May 27, 2011 | Maytag Dishwasher
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
Status Lights Blinking
status lights blinking is trying to tell you something in the dishwasher is bad,go to your owners manual to see the fault codes first,then you can try turning the breaker off 30 seconds an on to see if it resets its self,if that does not work i think you might have a bad mother board,thanks-mike
May 27, 2008 | Kenmore 16079 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwashers Logo
104 people viewed this question
Top Dishwashers Experts
