Fn\f1 key will not turn network on - Computers & Internet
  • 53 Answers
SOURCE: cant turn on wireless capability on fujitsu siemens amilo li2727
The issue is that it isn't turned on by default in the bios. Here is a link to a how guide to set this up.
Posted on Feb 02, 2009
mahjid
  • 202 Answers
SOURCE: Unable to turn on wireless capability siemens amilo li 2727
right click on My computer and click on properties, then on network check if Broadcom Wireless is listed, if it is then make sure wireless assistenat is installed by checking for it under Drive C:/ swsetup. if it is not listed, then the wiseless adapter is not available on your computer. Good luck
Posted on Aug 19, 2009
  • 70 Answers
SOURCE: hi just in stalled windows
Get your Windows 7 drivers for your laptop.
Posted on Dec 02, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: computer is on, but screen is blank. used Fn &
If you shine a flashlight on the display, can you faintly see an image? If so, the trouble is that the backlight isn't working. This is pretty common, and it's usually because the inverter in the display goes bad.
Replacing the inverter is fairly simple. You need to open the open the display, which is normally a matter of removing screws at the corners and separating the front bezel from the back. The inverter is a small circuit board at the bottom, held in by one or two screws. A couple of cables plug into it. Unplug them, mount the replacement and reconnect it, put the display back together and you've repaired your own laptop. Of course you can also take the computer to a service shop if you don't feel up to trying the repair yourself.
Replacement inverters are pretty easy to find for the major brand computers. A few minutes searching the Web or checking on eBay will give several sources. Typically a new inverter costs $30 to $50. There are also many YouTube videos showing how to replace an inverter.
Good luck! Thanks for using Fixya.
Posted on Feb 28, 2010
drifterK
  • 4924 Answers
SOURCE: pressing fn key and f1 key to turn on wireless
some laptops have a special button for that ...take a look if you see some buttons in front of the edge ..and see the wifi symbol ..after press it look if any leds are on for wireless
Another thing you should check if the driver for the wireless card is installed and it is enabled...For that get into bios first and default all settings to the factory optimal defaults...after that save changes with f10 and restart ...now is the time to look into the device manager to see if any of the newly enabled devices are in yellow with an ask sign on them ...In this case those are the ones that need drivers to be installed
if you do not have a drivers cd for the operation system that you have in use..go to the support site of the manufacturer ,choose downloads..and look for your exact model and operating system ...Most manufacturers have all the drivers needed in free downloads on the site ..
http://downloads.medionsupport.com/files.php?cat=2
if you find your exact model on this site ..you will have all the drivers too..
Posted on Nov 06, 2010
Why the f8 key dont work in my pc?
What type of computer ?
What are you trying to do ?
Enter safe mode ?
Because of the small amount of space available, many smaller-screened Dell laptops come with a special key known as the "Function," or "Fn" key. The purpose of this key is to double the functions of multiple keys, most commonly the F1 through F12 keys. On some Dell laptops, the F1 through F12 keys are locked from use to give way to more commonly accessed commands and program shortcuts. However, unlocking an "F" key, such as F8, is not difficult.
Press and hold the "Fn" key on your laptop's keyboard. This key will usually be shaded blue and is located in the bottom row. Press the F8 key on your keyboard while still holding the "Fn" key. This will have unlocked the F8 key. Repeat steps 1 and 2 as necessary to unlock any other "F" keys you wish to use.
Apr 11, 2013 | NexxTech NPCINIC Network Adapter
My Wi-Fi on Lenova Think Pad T60 is not working. I tried to update the drivers. Still not working.
What is it doing? Still not working could mean a lot of things!!! Is the computer connected to the wireless network? You've got to connect to the network before you can do anything. And most times the problem with connecting to the network is people key the network key or password wrong so the wireless just keeps on polling trying to connect.
Do you have the wireless turned on on the notepad? Sometimes there might be a wireless switch somewhere that you have to turn on. Also most times you can toggle the wireless On and Off by hitting the FN Function key and the corresponding F1 thru F12 key that toggles the wireless. Most times the correct F1 thru F12 key will have a wireless icon signal on it sorta like ))))) or it may show a tower with the signals. Once you find the correct F1 thru F12 key to press then Press and Hold the FN Function key then hit the correct F1 thru F12 key. If you look at your screen most times it will let you know if you've toggled the wireless by displaying Wireless On or Wireless Off.
Mar 29, 2012 | Computers & Internet
My wifi not working
LOL, wifi does not work off a network cable. The network cable is used for a local connection to a modem or router. Wifi doesn't not require a cable. Did it use to work? Have you checked on both sides of the laptop and in front of the laptop to make sure you have not turned the wifi switch off if there is one? Have you checked to make sure you have not hit the FN (Function Key) + (F1 thru F12 function key) that toggles the wifi on an off? When you Press the FN key and hold it down while pressing the Function Key that corresponds to toggling the wireless normally it will display on the screen Wireless On or Wireless Off. The correct key should have a wireless signal icon like )))) on it. That's the key you want to hit while holding the FN key.
Mar 18, 2012 | Computers & Internet
I need to know what the keys f1-f12 keys usage.
The uses for the function (f1-f12) keys varies based on which program you have open at the time. Different programs use them for different things.
However, your computer also has some default uses for these keys when combined with pressing the fn (function) key.
fn + f1 locks computer
fn + f2 changes our power use profile
fn + f3 puts the computer to sleep
fn + f4 puts the computer into hibernation mode
fn + f5 changes the display/output mode
fn + f6 decreases the screen brightness
fn + f7 increases the screen brightness
fn + f8 enables/disables wireless connections
fn + f9 enables/disables the touch pad
fn + f10 turns the cursor overlay on/off
fn + f11 turns the numeric overlay on/off
fn + f12 turns scroll lock on/off
May 05, 2011 | Toshiba Satellite Pro L300 Notebook
I need to connect to wireless on my laptop. There is no switch but the keyboard has the F1 key with a wireless sign. How do I turn it on? I have tried it with the Fn key without any luck. Thanks
Hi miksibanda,
Did you try Fn and F1 pressing at same time? On the right bottom side of the of the task bar a wireless signal bars? If you see that the wireless is on. double click a click view wireless network connection. The ssid of your router you will show then connect and enter the wep key or passphrase. I hope this will help you connect wirelessly.
HRH
Jan 05, 2011 | Computers & Internet
I could not know the functions of fn key. How to switch on wifi in my laptop dell vostro 1015?
pressing the fn key simultaneously press the keys marked with othr colours like orange \ or blue ..... these keys wil function whn the fn key is pressed...!!!
Dec 09, 2010 | Computers & Internet
How do i turn on the wirless network adator
To turn it ON you must press the Fn+F1 keys together
Apr 20, 2010 | Fujitsu AMILO Pro V1000 Notebook
How do I get my keyboard lights to turn on for a new gateway laptop?
Press and hold the FN key on your keyboard, While holding FN, press the F1 key one time. Then let go of FN.
FN-F1 on your system toggles the system status lights on and off.
Dec 25, 2009 | Gateway 7330GZ Notebook
How do i auto switchoff my lenovo y410 laptop
I'm not sure if your referring to sleep mode or not but I hope this helps There are several specialty key functions on the Lenovo Y410...here is a list....good Luck....please rate me ...The Fang
The following describes the features of each function key.
Fn + Esc: Turn on/off the integrated camera.
Fn + F1: Put your computer in sleep mode.
Fn + F2: Turn off the LCD screen (any subsequent operation will turn the LCD screen back on).
Fn + F3: Shift to other connected display devices.
Fn + F4: Switch between wide screen and normal mode.
Fn + F5: Enable/disable the built-in wireless networking feature.
Fn + F6: Enable/disable the bluetooth features.
Fn + F8: Enable/disable the touch pad.
Fn + F9: Enable/pause Media Player playback.
Fn + F10: Stop Media Player playback.
Fn + F11: Skip to the previous track.
Fn + F12: Skip to the next track.
Fn + Insert/NmLk: Enable/disable the Numeric keypad.
Fn + Delete/ScrLk: Enable/disable Scroll Lock.
Fn + Pause/Break: Pause to view the system information during start-up.
Fn + up/down arrow key: Increase/decrease display brightness.
Fn + right/left arrow key: Increase/decrease computer volume.
Feb 19, 2009 | Lenovo 3000 Y410 Notebook
How can I turn wireless on, on my philips laptop??
press and hold the FN key on your laptop and then press the F1, F2, or F10 key on the keyboard, any one would fix the issue
TRY FN + F1
or TRY FN + F2 ( mostly would fix)
TRY FN + F10,,
key combinations may vary from laptop to laptop
Feb 04, 2009 | Philips Audio Players & Recorders
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
