Question about Kenmore Dryers
When push start button there is no action drying light stays on
    President:
  • 1,554 Answers
There will be no action from the dryer when the motor is not running. The heating circuit is routed over the motor centrifugal switch. There will be no heat when the motor is not running. The problem in your case is usually a blown thermal fuse which is wires in series with the motor. Power to the motor circuit is cut when the thermal fuse is blown. Verify this condition by bypassing the thermal fuse. Access the thermal fuse on the blower housing depending on the model of your machine.The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Posted on Nov 13, 2010
I have sony dcs-h10 that wont power on, when power button pushed (with ac adapter green light stays on & speaker chirps but not lens action and no LCD light?)
As long as the power cable is in the camera, you can't switch it on. You could try another battery, or chaco if all contacts are clean and shiny. Don't forget to close the battery cover correct. As long as the cover is not closed correct, the camera can't power on. If the contacts are dirty or oxidised, only clean with a dry cloth or cotton swabs.
May 18, 2014 | Sony Cyber-shot DSC-H10/B Digital Camera
Pushed reset button and will not respond. Red on light stays on
11/6/12
Copy following link for Utilitec LW60418 timer.
Same as Westek TMDW10, and Stanley 30418
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
This timer is reset with one-button.
Unlike some timers that require 2 button push.
Push in reset button firmly with paper clip, and hold for several seconds. Repeat.
This action will clear timer memory.
If reset does not restore functionality, then timer could be bad.
This timer has 1 year limited warranty.
Suggest buying new timer at Lowes, and returning defect timer in new package.
Nov 05, 2012 | Intermatic Inc. ST01C Digital In-Wall...
The lights will blink when the door is closed and the start button is pushed
Try a reset. I have a kitchenaid. The reset is to press the sani-rinse, hea-dry, sani-rinse, heat -dry, then close the door. You can hear action the dishwasher doing something. Takes about 2-3 minutes, then stops. At this point I was able to select a wash cycle and start, close the door, and it started. Good luck
Feb 05, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
PUSH TO START BUTTON DOES NOT WORK
its not the start button check the door switch if broken or actuator is broken you get the results as you dry
Aug 21, 2009 | Kenmore Dryers
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Kitchenaid dishwasher KUDS02SRSS2 start light blinking won't start
I have this same kitchenaid model. It would not start after selecting the wash cycle and pressing start. The light would blink as if the door was open. I did the reset by pushing the sani-rinse, heat dry, sani-rinse, heat-dry and closing the door. You can hear something going on inside. After that stopped (about 3 minutes). I was able to select the wash cycle, press the start, close the door, and it started. Good luck!
Feb 22, 2008 | Dishwashers
Normal Light Blinking - Dishwasher not working
I HAD THIS SAME PROBLEM. TRY PUSHING THIS SEQUENCE OF BUTTONS: HEATED DRY, NORMAL, HEATED DRY, NORMAL. THIS RESET MY PANEL AND IT IS WORKING NORMALLY NOW. I FOUND THIS SUGGESTION ON ANOTHER SITE.
Sep 14, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dryer won't stay on.
lots of questions spring to mind, but if you have a push button type, it will only continue to turn once the motor is in motion. centripetal action allows a motor switch to keep the dryer in operation. look in that area.if you have a belt tentioner. check for continuity.
Jul 21, 2007 | Kenmore 64952 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
