Question about Canon iR 2016i Black and White Copier
Hello, About 3 or 4 dark lines appear on photocopies that I make. What could explain this, especially that the drum unit does not seem to have a problem? The problem occurs at anytime. The first 3 pages may have the dark vertical marks, but these may not appear in subsequent pages. The drum has been replaced and the a new toner replace, yet the problem persists.
  • Canon Expert
  • 242 Answers
You will have to check the transfer roller and the fuser unit.
Posted on Nov 13, 2010
My photocopy np6020 produce a dark background what can be the cause
Hello
I think your photocopy cleaner(the cleaner is a part that eraser drum in photocopy)is too old .you must change it to make better picture.
Dec 11, 2017 | The Office Equipment & Supplies
Mysterious fluctuation in quality of copies.
fuser drum is bad. photocopier use electricity to transfer the toner to the paper, then it is heat fused to paper. it appears that the problem is occurring around the time that the toner is attracted to the paper.
Mar 07, 2014 | Canon PC-940 Black and White Copier
There is a thin black line that run down the left hand side of the page2.5 cm in. all the photocopier & still the line is appearing. Your help would be greatly appreciated.
This sound like problem with your drum unit(Open the printer and pull it out).The drum unit should be near the toner cartridges.When you pull it out the color of the drum(Big metal roller)should be all the same.If there`s a brown line around the drum you need to buy a new one.Please replay if you need any futher help!!!!
Nov 08, 2010 | Samsung Office Equipment & Supplies
Minolta EP1085 copier - replaced drum but need to make adjustments for auto darkness, etc please help
After replace the photocopier drum you need perform the F5 Auto Image Density Control.Enter in the service mode:press Stop key - 0 - 0 -Stop key - 0 - 1 and press 1.In the LCD appear E and press 5 and the copy(start) button for perform the F5.Begining place A3 sheet paper in the original glass.To replace the OPC drum clean the optical section(glass,mirrors,lens,sensors) and change the OPC drum cleaning blade.Clean the quenqing lamp and erasure lamp amd the transfer/separator corona unit(holders,wires) and the charge corona unit.
Oct 03, 2009 | Minolta EP1083 CS/PRO Copier
Copier NP6216 produces thick dark strips
Hello sir; I suggest you either replace drum blade or replace whole drum cartridge.
Aug 20, 2009 | Canon Office Equipment & Supplies
Fault code J50 & dark strip.
This is for a Mita 1560 Photocopier (analog)
J50 was caused by exit sensor not sitting correctly in its bracket,I fixed this by pushing it until it
clicked back in.
The dark lines & double imaging can be caused light getting onto the drum ,or if the drum gets
cold (so I have been advised) which one it was for sure I will never know because when I
returned the next day & fixed the exit sensor the copy was OK.
May 18, 2009 | Office Equipment & Supplies
Canon photocopier 1600 Cleaning Blade not cleaning properly
Perhaps the pblm is not in "the drum unit"... check the mirrors may be are dirty.
Jan 12, 2009 | Office Equipment & Supplies
We have a Canon iR2200 photocopier in our office but unfortunately everytime it photocopies something thick black lines appear on the copy. Can you please tell me how to solve this without calling out an...
You may want to check your drum unit.and your developer unit
your drum may cost about 60.00 or above
and your developer unit may cost about 250.00 or above
you can also check for white-out left on the scanner.This can also cost problem on printing effect.
Good luck
Jul 25, 2008 | Canon Office Equipment & Supplies
Canon iR 2016i Black and White Copier Logo
71 people viewed this question
old marine
old marine
